01-21-2015, 04:06 PM | #201 |
Member#: 406039
Vehicle:2015 WRX GBP |
Link to where you can download a PDF of the rulebook:
http://www.scca.com/solo/content.cfm?cid=44517
01-21-2015, 04:07 PM | #202 |
Member#: 250511
awesome thx, I don't know how I missed it
01-22-2015, 10:12 AM | #203 | |
Member#: 278357
Vehicle:15 WRX WRB |
01-22-2015, 10:17 AM | #204 |
Member#: 198231
Vehicle:2007 Not a Subaru |
I've put a fair number of runs on the Dunlop Z2 star spec, what you know about the old Z2 does not really carry over at all. They handle heat a ton better than the old ones, much more similar to the RS3v2. Also they finally like slip angle.
01-23-2015, 03:14 PM | #205 | |
Member#: 409824
Interesting, you're not making this decision any easier |
01-23-2015, 03:52 PM | #206 |
Member#: 381966
Vehicle:2015 WRX WRB |
Yea, I'm just becoming more unsure of what the 'right' tire decision is as time goes on. I think I'm to 245/40R17 ZIISS now... but I'm sure that will change tomorrow.
01-23-2015, 05:48 PM | #207 |
Member#: 388585
Vehicle:2015 wrx base ISM |
Going to be running the 15 in it's first autocross and in my first attendance in over 5 years. Hope to have fun and really discover the driving characteristics under load other than daily driving. Will be running on RCE yellows. Wished I could hold off on the install and just it completely stock but I'm just too antsy.
01-26-2015, 03:12 AM | #208 |
Member#: 388585
Ran my first autocross in years on Sunday and had an awesome time. Making baby steps of improvement throughout the runs. Started with 53 seconds with a chill run to learn the course and incrementally dropping it to 48, then 46, then my fastest time of 45.26. I had a hard time feeling out whether the car wanted to stay in first or second gear. Not too happy with my 1 handed driving at the end but I got caught finding gears.
01-27-2015, 07:13 PM | #209 |
Member#: 296667
NESIC
Vehicle:2011 Forester 2.5X Dark Grey Metallic |
Great thread guys! I am currently setting my car up to run in STX this year. Since there is a 8" wide wheel limitation and a 245 tire limitation I plan on buying 18x8 +35 TSW Nurburgrings (because they look bada$$ and they are 3 pounds lighter than stock.) I am a little torn on the tire though.
Since the OE Dunlops were 235 I was planning on running that width of tire. After reading this thread I wonder if I should just use the max 245 on there. What do you think? Keep in mind this car is also my daily driver so I think Michelin Pilot SS will be a solid, all around good choice. Thoughts? |
01-27-2015, 09:24 PM | #210 |
Member#: 169483
South East
Vehicle:2014 Cadillac ATS 2T Red |
8" wide wheel limitation? That sucks.
01-27-2015, 09:34 PM | #211 |
Member#: 296667
NESIC
Up until the 2015 WRX, the WRX fell into the STU category; unlimted wheel width. Now, the 2015 falls into the STX category; 8" wide limit for AWD cars. Yes, it sucks.
01-27-2015, 10:44 PM | #212 |
Member#: 31821
SCIC
Vehicle:2015 DS WRX |
Put a good 245 tire (not Michelin) on your new rims. Use your stock wheels when not racing.
01-27-2015, 11:03 PM | #213 |
Member#: 406693
Vehicle:2015 WRX ice silver |
But if you only can do one set, I think the Pilot SS would be a good choice if DD more important to you than ax. Depends on your priorities. Also PSS are killer wets.
01-27-2015, 11:36 PM | #214 |
Member#: 409824
For those who put the car on the rack, what was the stock alignment in the rear like?
Wondering if I need to plan to change it back there...if not I will just do the front at home. |
01-28-2015, 05:44 AM | #215 | |
Member#: 296667
NESIC
I am not convinced thay a 245 would look great on an 8" wheel. Seems to to me it would look a little bulky. |
01-28-2015, 08:06 AM | #216 |
Member#: 295724
Vehicle:2022 WRX WRB |
STU is not unlimited wheel width for an AWD car. As to the worry about 245 on an 8" wheel I ran that for DS on my 2011 WRX and daily drive with a 245 on 8" wheel with my BRZ. It looks and functions perfectly fine.
01-28-2015, 08:44 AM | #217 | |
Member#: 23390
Vehicle:2010 WRX STI SE WRB |
rim size
245 will look and work fine on 8" rim; on my 8.5" wide STI rims, the stock 245 sidewalls look vertical, no bulging. - Harry |
01-28-2015, 08:58 AM | #218 |
Member#: 295724
The OP was correct I had it goofy in my brain. Probably because you never really saw wider than a 9-9.5" wheel used since you were tire size limited for AWD vehicles.
01-28-2015, 09:38 AM | #219 | |
Member#: 296667
NESIC
For autox, I think the 235 will be good for now. Not reaching my max capability but good. |
01-28-2015, 10:16 AM | #220 |
Member#: 406039
Depends on the offset of your rims. If they are 45mm (or some large number) then you won't have issues with rubbing. And you can always run spacers if you want to get that "hella flush" look. lol!
But if your rims are something like 20mm, then you might have rubbing problems. Check out the wheel/tire thread for more info on what fits well. |
01-28-2015, 06:32 PM | #221 |
Member#: 296667
NESIC
I'm getting 18x8 +35 TSW Nurburgrings in matte bronze... tomorrow actually. That's the only offset in 8" wide that will will fit a 2015 and stay within the STX category wheel width rule. 235s will look great, work just fine, and more importantly look nice and flush with the fender.
01-28-2015, 07:04 PM | #222 |
Member#: 406039
Great! Sounds like a nice looking setup. :-)
Just realize that going with 35mm offset (stock is 55mm) will make your car 40mm wider (1.5 inches) which will make it a big tougher threading through the cones. |
01-28-2015, 07:06 PM | #223 |
Member#: 296667
NESIC
Really? How's that? The wheels won't be sticking past the body.
01-28-2015, 11:54 PM | #224 |
Member#: 406039
When you autocross and totally screw up, you hit cones with the front bumper. When you're just barely nicking the cones you're hitting them with your rear tires. Hard to explain.
Not saying you made a mistake, just sayin'. :-) |
01-29-2015, 10:20 AM | #225 | |
Member#: 173150
Vehicle:2015 WRX |
the cone is the widest at the base, it sticks out about 2-3" more than the cone part of the cone (i'm so good at description, lol) so unless you are driving with a front bumper so low that it could be used as a snow plow, then the only thing that would touch the base of the cone is the tires. when that happens the cone is stepped on more than pushed, but its being stepped on with lots of force moving quite fast. what i see happen all the time is the cone would wobble and fall over or be dragged just outside the box. knowing all that the question becomes, how wide is too wide? and i cant answer that at all. nor have i ever googled if there is an obvious answer. (narrow cars do very well in autocross, so if i had to guess a wider car might do rather well on long sweeping courses, but any technical section would just slow them down too much) |
