04-26-2022, 08:17 PM | #1 |
Member#: 326377
SCIC
Vehicle:2006 WRX Wagon Aspen White |
2005 LGT EZ30R Turbo kit
Building a custom turbo kit for my 2005 lgt
Header built out of 1.5” sch10 321ss primaries, and 2” secondaries. Using a Garrett gtx3584rsii. I plan on doing a front mounted turbo, and awic with a rotated custom aluminum intake manifold. I will keep this thread updated with my progress. Sent from my iPhone using Tapatalk
04-26-2022, 08:28 PM | #2 |
Member#: 508105
NWIC
Vehicle:Link G4X flex tuned 02' EJ205 20G 6MT wagon |
Very nice stuff.
What's your power goal? |
04-26-2022, 08:33 PM | #3 |
Member#: 326377
SCIC
04-29-2022, 06:01 AM | #4 |
Member#: 478524
NESIC
Vehicle:1995 EZ30 Coupe Green |
Holy gorgeous manifolds!
I would think 500 on the stock block is doable, but she ain't gonna like it. It would probably survive if driven conservatively and ALL the supporting mods are done. 750 on a built one some be no problem. Idk if you're interested, but this dude has a turbo ez30 in his LGT. https://youtu.be/OyWe1_sxEE4 |
04-29-2022, 10:11 PM | #5 | |
Member#: 326377
SCIC
Yeah I don’t have to high of expectations out of a stock block. Brandon is the man! He’s actually helping me out with my wiring. Super cool dude! Sent from my iPhone using Tapatalk |
04-30-2022, 08:35 AM | #6 |
Member#: 478524
NESIC
That's awesome! Can't wait to see the progress!
05-09-2022, 09:21 PM | #7 |
Member#: 326377
SCIC
Turbo is hanging in its new home. Talking with turbosmart and haltech about possibly using the new electronic straight gate. Sent from my iPhone using Tapatalk |
06-02-2022, 10:43 PM | #8 |
Member#: 326377
SCIC
Got the “up-pipe” fit and welded. Left it long so I can cut it to fit. Working on the wastegate
06-16-2022, 11:33 PM | #9 |
Member#: 326377
SCIC
Finally got something done. A lot of work goes into this stuff Sent from my iPhone using Tapatalk |
06-19-2022, 08:17 PM | #10 |
Member#: 326377
SCIC
06-24-2022, 01:42 AM | #11 |
Member#: 326377
SCIC
Added a small bend to move the turbo closer to the engine. Much happier with the placement now! Time to finish the last couple welds on the header
07-23-2022, 07:28 PM | #12 |
Member#: 515308
Room under there for for twins bolted as close to the ex flange as possible? And oil sump/pump
07-25-2022, 11:55 PM | #13 |
Member#: 326377
SCIC
08-06-2022, 12:34 AM | #14 |
Member#: 326377
SCIC
So close. Just need some free time! Sent from my iPhone using Tapatalk |
09-19-2022, 10:35 PM | #15 |
Member#: 326377
SCIC
Had some time to work on the car this past couple weeks. Header just needs the vband for the wastegate welded (need to machine a heat sink before welding it). Welded the oil return bung in the front cover (welded from the inside). Fuel lines complete up to the firewall. Can’t wait to drop the motor in and keep rolling! Sent from my iPhone using Tapatalk |
11-10-2022, 09:01 PM | #16 |
Member#: 326377
SCIC
Downpipe ready to finish weld Sent from my iPhone using Tapatalk |
11-16-2022, 09:31 PM | #17 |
Member#: 326377
SCIC
Just need to add a hanger and she’s done. Deciding if I want to recirc the wastegate into the downpipe or just make a straight dump for it. Sent from my iPhone using Tapatalk |
11-18-2022, 11:47 PM | #18 |
Member#: 326377
SCIC
I need to talk to some professionals in the cooling department. I need to decide what size radiator is needed and if I should do awic or not. Any recommendations?
12-11-2022, 11:54 PM | #19 |
Member#: 326377
SCIC
Fuel lines are complete Sent from my iPhone using Tapatalk |
12-21-2022, 07:36 AM | #20 |
Member#: 464859
Very nicely done!
03-19-2023, 04:08 PM | #21 |
Member#: 326377
SCIC
Sent from my iPhone using Tapatalk Last edited by newbie123; 03-19-2023 at 07:54 PM. |
07-06-2023, 12:13 AM | #22 |
Member#: 326377
SCIC
Making some progress on the intake manifold. Would anyone be interested if I started making these? Sent from my iPhone using Tapatalk |
07-14-2023, 05:38 AM | #23 |
Member#: 124809
Vehicle:04 FXT, 07 STI JBP, SWP |
Awesome progress!! Do you have an IG to follow?
07-14-2023, 10:11 AM | #24 |
Member#: 326377
SCIC
11-05-2023, 01:52 PM | #25 |
Member#: 536026
Alternator bracket/AC delete
Did you custom make that alternator bracket? Have you deleted the AC pump and pulley?
Can you not use the stock composite plastic intake? I like the front mounted turbo, I am currently pulling an ez30 and 6 speed MT to out in my JDM legacy twinscroll, and plan to do turbo setup like MCM boys in Australia, up pipe between the brake booster and steering rack location. Wish I had your welding skills! |
