Welcome to the North American Subaru Impreza Owners Club Thursday April 15, 2021
Old 11-08-2020, 09:39 AM   #1
IggyBcool
Member#: 402169
Default P0018 and P0019 2008 STI
Was getting ready to leave work this morning and started the car and noticed it wanting to idle rough, blipped the throttle and it cleared up. Thought it was weird but started my drive home and it felt off for about a mile and then it cleared up and felt normal again. Pulled in to the house, idled fine and let it sit there for a minute idling and the CEL popped on and I looked at the AccessPort and it said these two codes.
Going to try clearing out the codes in just a bit when I get ready to go to the store. If they come back, where do I start?
IggyBcool is offline   Reply With Quote
Old 11-08-2020, 10:17 AM   #2
heiche
Member#: 400179
2009 wrx
interesting that both left/right came up.
quick first check might be to look at the oil level. the cam position sensors are oil pressure operated. very low oil level could cause that.
while you're checking the oil, look for any glitter in the oil, just in case there was some failure that clogged up both screens going to the oil control valves (hope not!)
maybe then start taking off front covers to check that the timing belt hasn't slipped a tooth or two. is your timing belt overdue for replacement?
seems like a wide range of issues can cause these errors.
heiche is online now   Reply With Quote
Old 11-08-2020, 05:59 PM   #3
IggyBcool
Member#: 402169
Unfortunately the oil is still full. I did clear the code when going to the store and it came back on within like 20 seconds. Cleared it a second time when I got back home and let the car cool off. Started it back up, it idled rough for about 15 seconds, blipped the throttle, it cleared up and let it idle for about 5m with no CEL, so I took it for a spin, felt like it was normal, didn't break up or feel down on power - maybe just a bit but also maybe in my head knowing it had something going on and being a hypochondriac... got back home let it idle again for another 5m no rough idle and no CEL.
WTF?
Old 11-08-2020, 06:48 PM   #4
akritzer
Member#: 511749
2013 WRX Hatch
https://forums.nasioc.com/forums/sho...ighlight=p0018
Also +1 on checking your timing belt.
akritzer is offline   Reply With Quote
Old 11-17-2020, 02:18 PM   #5
IggyBcool
Member#: 402169
Finally getting around to tackling the problem. I was looking on rockauto for the cam position sensors, and in the description its saying Left lower, left upper same with the right side. Is there really 4 cps's?
Old 11-18-2020, 09:27 AM   #6
Max Capacity
Member#: 149347
05 LGT,09 SpecB
Black/silver
Yes, I seem to recall that that STI's have four where LegacyGT's have two.
Why don't you go to a local auto parts store to buy these. You can talk with the guy and he may be able to show you in the book.
I have found my local NAPA has the same guys working there after 10 years of going to them, where as the other chain stores always seem to have different people working there. I walk into my local NAPA and the guys know me..."priceless".
Max Capacity is offline   Reply With Quote
Old 11-18-2020, 09:32 AM   #7
Max Capacity
Member#: 149347
05 LGT,09 SpecB
Black/silver
Old 11-18-2020, 09:34 AM   #8
Max Capacity
Member#: 149347
05 LGT,09 SpecB
Black/silver
Here's the search for p0018, less STI
https://www.google.com/search?sxsrf=...UajAc4Q4dUDCA0
