Welcome to the North American Subaru Impreza Owners Club Wednesday September 19, 2018
Old 10-26-2006, 08:50 AM   #1
kwan_1104
Member#: 127781
Default Help! Headers and cams questions
So, my next mods are going to be headers and cams, so I thought I might wanna get some advices from you guys. Planning to get a EL header, I have seen a lot of header out there, but most ppl are using mostly rallitek, cobb or borla. Why are ppl using these headers? Are they the best headers in the market? What about fujisubo or zerosports, they are expensive and is very famous, aren't they suppose to have excellent headers?.......As in cams, delta cams seems to be relatively cheap comparing to cobb's cams, does that mean cobb is better than delta or is it just the price difference?? I drive an 06 2.5i if that helps. I dun mind paying more for extra performance, but really need to get this clear in my head so that I dun hv to pay a whole lot more for something that have the same or similar performance value. Thanks you
kwan_1104 is offline   Reply With Quote
Old 10-26-2006, 09:27 AM   #2
problemcat13
Member#: 73398
04 11 VW GTI
APR Stage 1 (300ft/lbs)
In case you haven't seen it, the NA Power White Paper thread is linked below. However, you do sound somewhat knowledgeable on the subject, so:
Anyone have experiene / advice for this guy? FWIW I can tell you from what I've read the Delta cam is a regrind (weld on material and grind down) whereas I don't believe the Cobb is, it's a new cam altogether. Some people don't think regrinds will hold up as well, but Delta has gotten good reviews on here.
http://forums.nasioc.com/forums/show....php?t=1022154
problemcat13 is offline   Reply With Quote
Old 10-26-2006, 11:01 AM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Incorrect. The Cobb cams are also a regrind. They are working on new billet cams for the WRX and STi, but us RS guys still get the regrind. And the Cobb Cams= Web Cams. It's the exact same cam, but about $50 cheaper if you buy it from Cobb. And there's nothing wrong with a reground cam...
Old 10-26-2006, 02:50 PM   #4
Skidd
Member#: 1853
GC6 Supercharged
STM
Just an FYI, the Delta doesn't actually weld on more metal to your cams, only grind metal off. There is enough material on the SOHC to change the profile by removing metal only. I know this for a fact, because I asked the Delta guy before purchasing and installing these cams in my car. I had to adjust the valve lash to compensate. And yes, it affects both duration and lift.
As for the headers, I chose the OBX EL header because they are the same as the rallitek/cobb header, and about 1/2 the price. For the cost difference, even if they are only a couple of HP off of the high priced headers, it was worth it to me. Are cobb better? Perhaps? Are they +$250 better? Not to me.
In the end, Delta cams and OBX EL Header pluss full exhaust back and CAI have turned my car into a totaly different beast. Worth every penny!
P.S. I do get a CEL, but it the "as I expected" miss fire CEL. The delta cam idles pretty rough, and throws a misfire cell about once every 2 months. Plug in my scan tool, check the code, and clear them out. Doesn't bug me at all.
Skidd is offline   Reply With Quote
Old 10-26-2006, 08:52 PM   #5
problemcat13
Member#: 73398
04 11 VW GTI
I stand corrected for sure. Matt knows his stuff, and apparently Skidd does too.
Old 10-26-2006, 09:11 PM   #6
kwan_1104
Member#: 127781
so appraently... cobb and delta is basically the same.... how about headers?? are brands lik zerosports or fujuisubu better or the same?? btw wt the optima diameter of the header??
Old 10-27-2006, 09:55 AM   #7
ghostme76
Member#: 127773
im rolling with the web cams and damn there spicy stuff i love them and the torque is there up to the red line! but its a huge job installing them!Pitch in some new gasket while your there!!
ghostme76 is offline   Reply With Quote
Old 10-27-2006, 11:13 AM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
Yeah,
I know guys do it with the engine in the car, but I personally wouldn't. These engines come out so quickly and easily, there's no reason not to do this job on a stand. And I agree that any car over 60k mi deserves new head gaskets and timing belt with the cam install.
Cobb and Delta are both regrinds, but how they do it is slightly differently. There are proponents of both methods. There's an old "Cobb vs TWE" where some of us really got into the nitty gritty of it.
As for Zerosports and other JDM exhaust makers? The quality is about the same, and you are just paying for a really cool JDM brand. Regarding size? Don't exceed 2.25" 2.5" tends to really kill off the low end port velocity, and since these engines don't rev to 8000rpms, you never really make up for it...
Old 10-27-2006, 11:43 AM   #9
SubaDuba420
Member#: 102793
2016 WRX
Ugly Sedan
Has anyone done cams on a 2006 2.5i, which is what the OP drives, with the new semi variable timing? Does that affect the grind? Would you need to use different specs than used on older models?
SubaDuba420 is offline   Reply With Quote
Old 10-31-2006, 04:20 PM   #10
remstarasianboy
Member#: 130594
2005 Saabaru 9-2x
Desert Metallic Silver
Originally Posted by kwan_1104 View Post
So, my next mods are going to be headers and cams.....
Might as well do the forged pistons while you have your engine apart
remstarasianboy is offline   Reply With Quote
header and uppipe question RenoSTi Newbies & FAQs 7 12-19-2008 11:19 AM
EL vs UEL headers and exhuast questions 06-07 2.5i Sir-Knight Normally Aspirated Powertrain 9 11-24-2006 08:11 PM
Need some help..injector and tuning question 03WRX83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-11-2005 05:08 AM
please help!! downpipe and uppipe questions. JOELSWRX Newbies & FAQs 4 01-02-2005 09:05 PM
help header and up pipe ? 387hardcore Mid Atlantic Impreza Club -- MAIC 4 05-01-2004 02:54 AM
