Welcome to the North American Subaru Impreza Owners Club Friday July 20, 2018
Old 03-03-2007, 06:59 PM   #1
dukeduster
Member#: 95789
2002 WRX PTE
6262, hydra, 1100 FIC
Default Boost surging on hyrbid motor
dont know where else to put this at so ill start here. Mods feel free to move.
I have a aem tru-boost with a 46mm external gate and I cant run over 8 psi without the boost surging up and down. I can run 8 psi Just fine but when i turn it up to like 14psi it wont even turn up. I then adjust the wastegate crack pressure to 11 and it will achieve 11psi but then surge back and forth from 8 to 11psi. anyone have any ideas? I also have a smaller line going to the top of the wastegate could this cause that?
dukeduster is offline   Reply With Quote
Old 03-03-2007, 09:26 PM   #2
dukeduster
Member#: 95789
2002 WRX PTE
nevermind i am an idot lol. I fogot i am setting duty cycle on the boost controller not psi.
boost surge... low boost... jmodica Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-06-2009 04:16 PM
Boost Controlling On Stock Motor? iSuby86 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 78 01-15-2009 02:25 PM
High Boost/Low RPM Surging on Highway Obsessive Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-23-2008 10:06 AM
Acceptable Boost Levels on STi Motor artdoesart Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-30-2004 09:09 AM
Boost Problems on stock motor - help! Kickz107 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-21-2003 09:47 PM
