08-19-2005, 02:13 PM | #1 |
Member#: 1800
NESIC
Where to buy body kit gasket/rubber/seal?
I bought a rear lip for my WRX that unfortunately came with a torn up rubber gasket that helps fill the gap between the lip and the bumper cover. My bodyshop guy had no ideas on where to buy some new gasket, anyone got any ideas?
Thanks, Paul
08-19-2005, 03:52 PM | #2 |
Member#: 75129
Vehicle:09 WRX stg 2+ Lost the boxer rumble |
You mean a place other then Subaru parts dept ?
08-19-2005, 07:07 PM | #3 |
Member#: 9355
NESIC
Vehicle:2013 STI Hatchback 2015 BMW X6 |
You can't even get these through Subaru. I bought an EDM rear lip for my wagon and had to get it repainted. The bums at the paint shop took the gasket off. I searched high and low but could not find a part number. I spoke to some guy at a dealership in Canada, who does offer a rear lip for the wagon, and he did not have a part number for the rubber seal. He did, however, get all the part numbers for the hardware I needed for the install. He even faxed me over the installation directions. I decided to install the rear lip without the rubber seal, and it worked out fine. It doesn't rub the rear bumper, nor does it stick out much. If you looked at it, you wouldn't know that you needed that rubber seal. Good luck!
Mike |
08-19-2005, 07:20 PM | #4 | |
Member#: 1800
NESIC
Mike: Yeah, that's pretty much what all my searching turned up. Mine definitely needs a gasket, it won't be tight in a couple spots. Thanks. |
08-19-2005, 07:23 PM | #5 |
Member#: 38607
TXIC
Vehicle:04 FXT Black |
homedepot?
JC Whiteny (Spelling) has alot of weatherstriping. I use to own a ford Last edited by ShortBus; 08-19-2005 at 07:33 PM. |
Where to buy 3" Doughnut Gasket??? | REX8 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 19 | 06-02-2006 08:43 PM |
Where to buy Up/downpipe gaskets? | maxpower_454 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 14 | 05-17-2006 08:15 PM |
Where to buy 3" exhaust gasket in Dallas? | stevenh | Texas Impreza Club Forum -- TXIC | 10 | 05-02-2006 11:25 PM |
where to buy GTspec header gaskets? | litlechina | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 02-12-2006 01:28 PM |
Where to buy 3" exhaust gasket for full length DP to stock indermediate pipe? | InfamousDX | Newbies & FAQs | 4 | 11-11-2004 09:24 PM |
