Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2020
Old 12-13-2006, 01:16 PM   #1
STL WRX
Member#: 88304
05 VF34 Aspen WRX
Default Can I modify my high pressure washer to have high pres soap?
My pressure washer has this gay ass low pressure (soaking) solvent nozzle that allows soap to be applied to any surface in a VERY low pressure spray (this is stupid). When you switch nozzles to the different high pressure nozzles you lose solvent spray and or soap. I want to spray high pressure soap plain and simple. How do I do this... anyone know?
STL WRX is offline   Reply With Quote
Old 12-13-2006, 01:19 PM   #2
Asinine
Sufficient for Sharky
Member#: 55173
with paddles.
Yes, you'll need a large pot (4 quarts), two pounds of... wait... nevermind. I thought you wanted your pressure washer to have high pea soup.
Asinine is offline   Reply With Quote
Old 12-13-2006, 01:20 PM   #3
Cjchaps
Member#: 3181
07 Rav4
I had split pea soup for lunch.
Cjchaps is offline   Reply With Quote
Old 12-13-2006, 01:21 PM   #4
STL WRX
Member#: 88304
05 VF34 Aspen WRX
ahahaha anyway....
Old 12-13-2006, 06:16 PM   #5
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
It would be easier to mix prepump, but I don't think it would be too great for the pump...
GLwagon is offline   Reply With Quote
I just modified my string trimmer..do I have a problem? vision.dynamix Off-Topic 9 06-04-2009 04:52 PM
Where can I modify my injectors 06WRXMIKE Southern California Impreza Club Forum -- SCIC 11 11-07-2007 08:02 PM
Off topic but need your help. High pressure washer. BIG GUN Off-Topic 1 04-27-2005 02:11 PM
High Pressure water to clean wheels? WarHawk187 Interior & Exterior Modification 4 06-05-2004 03:07 PM
i need 4wd impreza with disc brake E-brake Cables. can i modify my cable? supermoose Brakes, Steering & Suspension 0 09-30-2001 09:43 PM
