Welcome to the North American Subaru Impreza Owners Club Saturday July 20, 2019
Old 05-24-2019, 08:04 PM   #1
Jmann462
Member#: 466915
2003 Impreza Wrx STI
Default Cam sensors at rear of Heads Leaking oil
Recently purchased 03 STI with JDM 205 w/avcs delete 81k miles. I purchased knowing that there was a minor oil leak issue at the rear camshaft sensors at the back of the heads, it pools up a bit and burns, smoking and making me and my car look terrible haha. I have now become completely stumped on how to resolve the issue. I purchased the IAG camsensor delete plugs and removed the sensors and installed the plugs, still have the issue(not as bad). I was told by IAG that they were made for the USDM not the JDM and the diameter of the hole is slightly larger than that of the USDM. Anyways. the oil spits out, its not pouring by any means. I am just sick of it and I have googled hours to no avail. I was hoping someone else has ran into this issue and could offer some feedback or a resolution. I would love this fixed so i can finally tune it and have some real fun. Thanks in advance.
Jmann462 is offline   Reply With Quote
Old 06-01-2019, 12:55 PM   #2
Jmann462
Member#: 466915
Default Help!!
Does anyone have insight on this issue? Any and all help is much appreciated. TIA
Old 06-01-2019, 09:48 PM   #3
supermarkus
Member#: 6971
2008 WRX STi
SSM
You can check McMaster Carr and see if you can upsize the o-ring and rtv the bejeezus out of the plug. Make sure all sealing surfaces are free of oil before applying your silicone.
supermarkus is offline   Reply With Quote
Old 06-19-2019, 08:20 PM   #4
Jmann462
Member#: 466915
Thanks for the response, sorry for the delayed one haha, life has been hectic. What you just said was exactly what i was going to do i was just hoping someone else had experienced this before and had a less barbaric means of fixing the silly issue. Thanks yo!
Old 06-20-2019, 08:54 AM   #5
Bansheeboy11
Member#: 182415
1999 RS
Dont put RTV on the plug, find an oring that properly seals it and it wont leak. Make sure you buy something that can handle hot oil, and lightly coat it with grease when you put it on the plug and back in the head.
Bansheeboy11 is offline   Reply With Quote
Old 06-28-2019, 03:19 PM   #6
Jmann462
Member#: 466915
Man that is what i have already attempted doing. The i need the same diameter with a thicker wall. I have had 0 luck in finding that because diameter goes up with the wall then the o-ring it too big to fit into its slot on the plug. I need to get a custom O-ring. Ill figure something out. I was just hoping i wasn't the only person experiencing this ridiculous issue.
Old 06-28-2019, 03:54 PM   #7
ascendr
Member#: 462136
02 Bugeye
You could bring the delete plugs to a machine shop and have a groove turned in to accept the o-ring of your choice?
ascendr is offline   Reply With Quote
Old 06-28-2019, 07:05 PM   #8
ascendr
Member#: 462136
02 Bugeye
I happen to have a set of JDM single AVCS heads and the rear crank sensors on my bench so I took a few measurements hopefully it's helpful.
The o-ring on the cam sensor looks to be 18.35mm while the hole in the block looks to 18.27mm
