Welcome to the North American Subaru Impreza Owners Club Monday August 10, 2020
Old 01-07-2016, 09:52 AM   #1551
Hummus
Member#: 385281
03 WRX
15 Grom
You don't, by chance, have as detailed a writeup on your 2012 STi trans swap into the bugeye as you do the 2011 STi trans swap into your 2011 wrx, do you?
Hummus is offline   Reply With Quote
Old 01-07-2016, 10:25 AM   #1552
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I never did a full write up. There are already a lot of threads on the GD 6 speed swaps so I didn't think I'd be adding much. Here's a quick summary of the setup when I initially installed it. I listed the model year of the parts I used but also tried to give a compatibility summary in parenthesis.
Drivetrain/Transmission
  • OEM 2012 STI 6MT (Same gearing as all 2007+ STI, all 08+ STI do not have speed sensor in trans)
  • OEM 2004 STI Driveshaft (Same as all 2004-2007)
  • OEM Stock WRX Axles (Same as all 2002-2007 Sedan)
  • OEM Stock R160 3.545 Rear Diff (Same as all 2002-2005)
  • OEM 2004 STI Front Axles (Late 04 Male Axles)
  • Anarchy Motive Shift Knob (Any STI 6MT Knob)
  • 04 STI Shift Linkages (Same as all 2004-2007 STI)
  • Kartboy Short Shifter (Any STI Shifter)
  • Kartboy Front Shifter Bushings (Any STI Shifter)
  • Karboy Rear Shifter Bushings (Any STI Shifter)
  • Torque Solutions Tranny Mount (Any Tranny Mount, WRX version needs shims)
  • ACT HD Pressure Plate (Any STI Clutch)
  • ACT 4 Puck Unsprung Disk (Any STI Clutch)
  • OEM Stock WRX Clutch Slave (Any Pull Type)
  • MapDCCD Center Diff Controller (Recommended over DCCDPro)
  • MapDCCD Wheel Speed Sensor (Needed if you use an 08+ STI 6MT)
Here's an updated list of how it is now. I've made a few changes to increase durability. The updated items are bold and highlighted.
  • OEM 2012 STI 6MT
  • DSS CF Driveshaft (GD STI version)
  • DSS 800HP Rear Axles (Hybrid R180 inner and WRX outer)
  • OEM STI R180 Rear Diff (3.545 final drive from any 06+ STI)
  • Aluminati Solid Billet Tranny Mount
Old 01-25-2016, 05:35 PM   #1553
BmoreSti
Member#: 230719
2005 Sti Andrewtech
& TurboXS FTW
Any pictures with the S&W installed? How was the fitment?
BmoreSti is offline   Reply With Quote
Old 01-26-2016, 02:57 AM   #1554
RoidRage
Member#: 272471
2010 WRX FlareObody
Red
Awesome, thanks for the write up!
RoidRage is offline   Reply With Quote
Old 01-26-2016, 08:13 AM   #1555
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
It's still at FOBIA's getting installed.
Old 01-26-2016, 02:11 PM   #1556
BmoreSti
Member#: 230719
2005 Sti Andrewtech
& TurboXS FTW
Oh ok, I'll check back than.
Old 02-01-2016, 02:43 PM   #1557
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Updated interior shot.
Old 02-01-2016, 03:24 PM   #1558
2011rex18
Member#: 321728
2011 WRX Limited
That looks awesome man love watching it come along
2011rex18 is offline   Reply With Quote
Old 02-01-2016, 11:59 PM   #1559
Jive Turkey
Member#: 219492
17' 5mt XV & 02 WRX
@comrad
gonna start towing it eventually?
Jive Turkey is offline   Reply With Quote
Old 02-02-2016, 08:53 AM   #1560
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks.
I've never really been opposed to it. Always other cars that need the trailer more than me though. As some point I'm sure I'll need to do it.
Old 02-07-2016, 02:16 PM   #1561
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I redid the Kirkey seat mounting without the square tube I had used to raise them up before. The first 4 pics are the passenger side. It is mounted in basically the "normal" spot for the brackets. Way low and far back for me to drive so the driver side I used a strip of aluminum to mount it a few inches further forward. Still way lower and a bit further back than before. It's pretty far back compared to what I normally would sit at but I think it will work out well.
Old 02-07-2016, 02:19 PM   #1562
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here are some pictures of the cage in the daylight. This is with the seats in the new positions. Still need to install the harness and fabricate the mounts for the seat backs to the cage.
Old 02-07-2016, 02:22 PM   #1563
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Compilation of the quickest and fastest Subaru 1/4 mile drag racing passes from 2015. All of the cars are in the 8's and 9's! Includes the White Bullet STI, CJ's V8Bait STI, P&L's Drag STI, JrTuned's 2015 STI, and more!
08.48 @ 168, Roly Resto, 2005 STI
https://youtu.be/p9xTC2zi0Ws
08.69 @ 164, CJ Synak, 2006 STI
https://youtu.be/T1-hPHy0EVA
08.76 @ 169, Tyler Ivy, 2007 STI
https://youtu.be/x3XyQMAoCkY
09.12 @ 152, Clive Fulcher, 1998 GC8
https://youtu.be/8BSMeT_pVas
09.13 @ 152, Jr Barrios, 2015 STI
https://youtu.be/WsLKWZqFAwE
09.30 @ 149, Jeff Chang, 2005 STI
https://youtu.be/bF1ogfhqOPw
09.45 @ 141, Brian Leazenby, 2003 WRX
https://youtu.be/CXchDB4wT4I
09.51 @ 150, Ben Johnson, 2002 WRX
https://youtu.be/uZjxn-QXU6I
09.91 @ 121, Kyle Padilla, 2002 WRX
https://youtu.be/eYd6p-8tztY
*These are the best passes that I could find videos for, there could be others that didn't have video available or were not known at the time that this video was made. All passes were from 2015.
Old 02-19-2016, 12:26 PM   #1564
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
RJS Window Net and Mounting Kit
Advanced Chassis LLC Seat Back Brackets
Old 02-19-2016, 12:56 PM   #1565
96accord
Member#: 145105
2015 Honda Accord
So with that trap speed you should have a better time? 09.15 - 09.20 range?
96accord is offline   Reply With Quote
Old 02-19-2016, 01:03 PM   #1566
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I think I could knock a few tenths off with a slicks and a good 60'. Brian and Jeff were both 1.2-1.3 I believe. Not sure about all the others. Could have let off or been breaking up on the top end since it won't effect ET much (but can make trap way lower). I know some of these cars 1/8th mile way faster than me and that helps ET a lot.
Old 03-02-2016, 09:55 AM   #1567
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Picked up some new wheels for this summer. Silver Enkei RPF1 17x9" +45 with hubcentric rings and Honda centercaps.
Old 03-16-2016, 11:17 AM   #1568
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
17x9" RPF1 with 245/45R17 M&H Drag Radials
Old 03-16-2016, 11:39 AM   #1569
ocdpvw
Member#: 282232
2012 TP Stage 3
Bagged SWP & Bagged DGM
Love the cage. This car is nuts!
ocdpvw is offline   Reply With Quote
Old 03-16-2016, 11:49 AM   #1570
WreaKLoosE
Member#: 165300
2006 WRX
Steel Gray Met.
WreaKLoosE is offline   Reply With Quote
Old 03-17-2016, 11:06 AM   #1571
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Old 03-19-2016, 10:56 PM   #1572
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
2016 Setup | 750WHP | 17x9" +45 RPF1 | 245/45R17 M&H Drag Radials | Kirkey Seats | 8.50 NHRA Certified 10 Point Roll Cage
Old 03-20-2016, 10:15 AM   #1573
Smurftastic
Member#: 243697
17.4 PSI ECUtuned 02
BLOD Cofounder|TopScoob31
Love the last picture - how was fitment for the cage in the driver's side dash? Looks like you had to navigate behind the fuse box?
Smurftastic is offline   Reply With Quote
Old 03-20-2016, 04:00 PM   #1574
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
My forward bars go right in front (closer to the driver) of the OEM beam that runs along behind the dash. Which means it goes right where the fuse box is. So that part has to have some cutting and the fuse box is mounted slightly off to the side so the bar can go through.
Old 03-20-2016, 08:52 PM   #1575
mtnmarc
Member#: 385446
2004 WRX
JBP
Why not remove the back seats since there is no room now with the cage.
mtnmarc is offline   Reply With Quote
