Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2020
Old 09-25-2018, 05:19 PM   #1
ProjectBugeyeMY02
Member#: 483797
2002 Impreza
Silver/Black
Default How to build 300whp reliable 09-14 wrx
I'm sure this has been discussed before, so if it has, can comone be kind enough to comment the link?
Anyways, picked up a 09 Wrx a couple weeks ago, already deleted the mufflers, purchesd a better pitch stop, an AEM cai, running Cobbs ots stage 1+aem 93 map. Going to heat wrap the stock ic to prevent heat soak. When I purchase a downpipe, I'll run stage 2. I'll get bored with it and want more. My overall goal with this motor is 300whp, I would like it to be as reliable as possible, I mention what my plan is for supporting mods, obviously with a protune to go with it. If anyone else has any tips/reccomendations it would be appreciated!
My plan
Aem cai (I know not necessarily but I like the noise)
Better Full recerc Bpv (not sure which yet)
Invidia Cattless DP ( 3in dual n1 cb)
Catch can set up
Mishi tb hose
Turbo Heat shield
Cobb ebc
Debating fuel pump/injectors ( not sure if necessary?)
Also wastegate maybe? (also not sure if necessary, if so better internal or not to bother and get a ewg with a new up pipe?)
Will I need to run a better ic? I've looked at both Avo/grimmspeed tmic.
Thanks guys
ProjectBugeyeMY02 is offline   Reply With Quote
Old 10-22-2018, 12:52 AM   #2
Vooduru
Member#: 485649
If it's 265 stock and with the mods you've done to it, aren't you close to 300?
Vooduru is offline   Reply With Quote
Old 10-22-2018, 02:47 AM   #3
leche43
Member#: 474819
Pump and injectors aren't necessary, for your goal. Do your research on catch cans, not necessary at this level imo money would be better spent on a top mount upgrade, or even radiator and hoses. Top mount upgrade goes a long way for driveability and reliablity if you drive hard. Stock top mount heat soaks in no time, I don't think reflective tape will help the poor little thing. Up pipe will surely help, but wouldn't do it until you upgrade top mount because the added heat to the engine bay
leche43 is offline   Reply With Quote
Old 10-22-2018, 09:46 AM   #4
snow_bound26
Member#: 395793
2005 92x Aero
Blue(retired�ȸ
My plan
Catch can set up
Mishi tb hose
Turbo Heat shield
Cobb ebc
Thanks guys
You are over thinking some of this. The OE BPV is perfectly fine for your goals. Save that money. Same thing with the WG. Unless you want to run EWG leave the OE one alone and you'll be fine. Don't bother with the TB hose either. Catch cans are going to add maintenance and need to be checked routinely so they don't cause issues like running low on oil or having them spill in the engine bay. AOS in my opinion is better and safer. It if you're not getting much blow by then they might not be worth it at this point.
Take the money you would've spent on those things and do a TMIC; GrimmSpeed, Turbo XS, Process West are all good. PW comes with everything you need. The other 2 don't come with a splitter. I personally would do the fuel pump. The injectors will be close to or completely maxed out. The pump will be maxed out. Walbro 255 is cheap and gives you room for the future. Cobb EBCS is a good choice. A turbo blanket/wrap is more effective then a heat shield (though the stock TMIC will still heat soak a bit). I have a VF34 with a coated hot side and blanket and can put my hand on the intercooler after a hard run. When I had a Cobb heat shield and not the others I couldn't do that. Your up pipe is fine since it's catless. You won't see much, if any increase in performance with an up pipe at this point.
snow_bound26 is offline   Reply With Quote
Old 10-29-2018, 11:35 PM   #5
tiny360
Member#: 493336
1997 Legacy Outback
Default You should go big, because you are already home
tiny360 is offline   Reply With Quote
Old 03-09-2019, 12:18 AM   #6
sgilmore
Member#: 498813
2012 WRX
Dark Metallic Grey
Default kinda old, but I'm kinda new
My 12 has tbe, cobb sf, and tp 93 oct tune. Stock vf52 @ 19psi. Makes 304awhp/311tq on a mustang dyno. headed for 3 port, fuel pump, pw tmic, and id1000s in the upcoming months. then maybe flex fuel, targeting 350awhp
sgilmore is offline   Reply With Quote
Old 04-11-2019, 10:10 AM   #7
westlord
Member#: 495520
He's looking for wheel horsepower. Because of drivetrain losses (~20%), 300whp would require 375hp (not at the wheels... which is the number manufacturers use). 375hp * (100% - 20%) = 300 whp. The -20% is for the drivetrain loss.
westlord is offline   Reply With Quote
