Welcome to the North American Subaru Impreza Owners Club Wednesday August 12, 2020
Old 06-17-2019, 08:59 PM   #1
Kreiser42
Member#: 503230
Default Idle surge, no engine light
Hey everyone,
Need some advice troubleshooting an idle surge. My car is a 2000 Impreza non turbo. Once warm the idle jumps up and down from about 1000rpm to 100rpm (almost stalls). Its quite sluggish until I get up to around 3000rpm then it takes off. It has no CEL and no codes stored. It had an intake manifold leak that I fixed but it did not fix the issue. Ive check for vaccum leaks, checked the coils and plugs, checked compression (130psi all around), changed the air filter, cleaned the MAP sensor, replaced the IACV and TPS. Where else can I look?? Im kinda at the end of my rope any help would be great
Kreiser42 is offline   Reply With Quote
Old 06-19-2019, 01:19 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Did you calibrate the TPS?
yarrgh is offline   Reply With Quote
Old 06-20-2019, 08:58 PM   #3
sub_sifu
Member#: 301690
2002 Wrx
how and why would he do that? Just researched it, doesn't sound like an easy thing to do, or is recommended unless certain that's the issue?
sub_sifu is offline   Reply With Quote
Old 06-21-2019, 02:27 AM   #4
Kreiser42
Member#: 503230
No I did not calibrate the tps, honestly didn’t realize that was part of the process. However switching the tps sensor made absolutely no difference in running condition. I’ve done some more poking around I found the downstream 02 sensor has been messed with, the wires are cut and reconnect multiple times and I believe it’s an aftermarket sensor. Could this be causing the surge??
Old 06-21-2019, 05:35 AM   #5
Aurielo24
Member#: 502816
Originally Posted by Kreiser42 View Post
No I did not calibrate the tps, honestly didnít realize that was part of the process. However switching the tps sensor made absolutely no difference in running condition. Iíve done some more poking around I found the downstream 02 sensor has been messed with, the wires are cut and reconnect multiple times and I believe itís an aftermarket sensor. Could this be causing the surge??
+1
Aurielo24 is offline   Reply With Quote
Old 06-21-2019, 12:53 PM   #6
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
The downstream O2 sensor only measures if the cat works on your vehicle. On 2005+, it does help with fuel trims.
It doesn't matter if that's the original issue, TPS was replaced, needs to be calibrated.
There are probably threads/videos on how to calibrate the throttle position sensor. When you installed it, did you notice it's slightly variable? That's on purpose. At 0% throttle, it should read 0.45V to 0.55V. At 100% throttle, it should read 4.5V to 5V.
I've found that sticking a needle through the insulation right at the TPS is the easiest way to get a reading.
Did you remove the intake manifold? Did you tighten the throttle cable a tad tight?
Old 06-21-2019, 02:39 PM   #7
Kreiser42
Member#: 503230
Nah throttle cable was tightened right up from the previous owner I’m guess in hopes to hide the issue but I’ve loosened that off. Yes I did notice the tps was variable, didn’t use a multimeter to set it just kinda set the idle by ear as best I could despite the surge. I’ll have a tinker with that. I have also noticed the catalytic has been cut out and welded back in, doesn’t seem to be leaking but any issue there related to the 02 sensors?
Another quick note, it will stall with regular fuel in the tank not so much with high octane.
Old 06-24-2019, 06:49 PM   #8
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
You say that once the engine is warmed up, these symptoms occur. If you have access to the coolant temp sensor, check it against intake temp sensor (and ambient) when the engine is cold, then again after warm-up.
Old 06-29-2019, 02:46 AM   #9
Kreiser42
Member#: 503230
Yea seems like the symptoms start once the car goes to closed loop. So check the output voltage of the sensors? What is the thought behind comparing the 2 of them?
Thanks for your advice itís greatly appreciated
