Welcome to the North American Subaru Impreza Owners Club Saturday August 8, 2020
Old 11-02-2013, 11:09 AM   #351
Ultimateone
Member#: 48025
2020 Supra
AZW
Nice, should be a fun journey
Ultimateone is offline   Reply With Quote
Old 11-02-2013, 12:10 PM   #352
JuanWins
Member#: 328915
2005 STi
Originally Posted by xluben View Post
It has arrived:
This turbo is capable of 600hp?
JuanWins is offline   Reply With Quote
Old 11-02-2013, 12:11 PM   #353
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
No. Not at all. 600WHP will not be this setup. Maybe next year.
xluben is offline   Reply With Quote
Old 11-02-2013, 12:21 PM   #354
blurple203
Member#: 360576
2013 Base WRX
Plasma Blue Pearl
what are you expecting out of this setup?
blurple203 is offline   Reply With Quote
Old 11-02-2013, 12:27 PM   #355
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I hope for >100WHP.
Old 11-02-2013, 03:17 PM   #356
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
Tree Fiddy? ( Serious lol ). Or 400?
Navendra94 is offline   Reply With Quote
Old 11-02-2013, 04:07 PM   #357
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
On E85 I think it should do at least that.
Old 11-04-2013, 10:32 AM   #358
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here are more photos of the turbo. It is a TD06SL2-5371 (similar to GTX3071R compressor).
Old 11-04-2013, 10:38 AM   #359
snake32
Member#: 167338
11 Wrx hatch
Dgm
is the flapper welded for ewg?
at least that's how it looks in this picture, is not clear enough tho.
http://www.benjohnsonphotography.com...-BvPxLz5-L.jpg
snake32 is offline   Reply With Quote
Old 11-04-2013, 10:39 AM   #360
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
My brother and I did a little more work last Friday. The turbo is on the motor. That's about it. Here are some photos.
TD06SL2-5371 vs. VF39
^That one's a bit misleading due to perspective. Haha. Here's a more accurate one:
Turbo includes nice, multi layer gaskets and a small compressor to wastegate vacuum line.
Bolted on. Stock oil line fits great. Used the included banjo bolt and crush washers.
Oil drain lines up well.
Front.
Rear.
Side.
Ghetto BandAid because my brother cut his finger when trimming bump stops for his Bugeye.
Old 11-04-2013, 10:40 AM   #361
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Also, put this on the wall in my laundry room. The door on the right goes to the garage. Nice to be able to contain messy hands.
Old 11-04-2013, 10:42 AM   #362
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
No, it is not welded. I'll be running it internally gated. The sealing surface for the flapper is machined to create a flat surface for the flapper to seal against. I think this is what you're seeing that looks like it's welded.
Old 11-04-2013, 10:49 AM   #363
Ultimateone
Member#: 48025
2020 Supra
AZW
Hmm, any reason you're not running it external?
Old 11-04-2013, 10:51 AM   #364
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Because the uppipe I have now is internal and I don't want to buy a new one.
Old 11-04-2013, 10:30 PM   #365
pattylicous
Member#: 117487
Selling the vf39?
pattylicous is offline   Reply With Quote
Old 11-04-2013, 10:32 PM   #366
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yep. Sure am.
Old 11-07-2013, 11:27 AM   #367
sexyyrex
Member#: 128022
2015 Mustang GT
That turbo looks strikingly similar to the AMR CXR550 I had, all the way down to the billet actuator, except its got the "goblin" upgrade wheel, AKA the GTX wheel. I wonder how similar they are, if they are indeed similar that car should make some nice power on e85. I think mine did a little over 400whp.
sexyyrex is offline   Reply With Quote
Old 11-07-2013, 11:33 AM   #368
besthaticouldo
Member#: 279660
It has arrived:
besthaticouldo is offline   Reply With Quote
Old 11-07-2013, 12:28 PM   #369
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
[IMG]http://distilleryimage2.ak.instagram.com/9896c8d088f211e2b59022000aa80136_7.jpg[IMG]
It does look pretty similar! CXR550 is rated at 52lb/min vs. 56lb/min for the GTX3071 compressor. I didn't see any wheel dimensions listed for the CXR turbo's, so I'm not too sure how the dimensions compare. I think this turbo could do 400WHP on pump. Hopefully a bit more on E85.
Originally Posted by besthaticouldo View Post
[IMG]http://farm3.staticflickr.com/2830/10727481965_3383a3561b_o.gif[IMG]
This is so perfect.
Old 11-07-2013, 12:41 PM   #370
Jive Turkey
Member#: 219492
17' 5mt XV & 02 WRX
@comrad
omg derrick.
much funny
such creative.
wow.
Jive Turkey is offline   Reply With Quote
Old 11-08-2013, 11:38 AM   #371
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
More work last night:
Installed AMR hard inlet.
Installed better condition OEM fuel rails with evap removed.
Installed MAW/TIC plastic TGV's.
Installed ID2k Injectors.
Started cleaning up evap/breather lines.
My brother did more wiring (MapDCCD, VSSPro, Boost, AFR, Oil Pressure). Nearly complete.
Mock up of intake manifold on the motor. Not quite ready to go on yet.
Here is an interior photo. It came out a little blurry. Oops.
Old 11-08-2013, 11:40 AM   #372
Overland04
Member#: 293311
2013 FXT 6-Speed
Obsidian Black Pearl
Water in replacement of Grain Belt? You must be really trying to focus. We'll maybe not on that last picture.
Overland04 is offline   Reply With Quote
Old 11-08-2013, 11:44 AM   #373
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I didn't drink any fluids during the time working last night. That may explain that last photo...
Old 11-08-2013, 11:50 AM   #374
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Poor Man's Panamera
That usually happens when I drink too many "fluids." Everyone is different, y'know?
bicycle_wreck is offline   Reply With Quote
Old 11-08-2013, 11:52 AM   #375
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
True. Haha. That does seem a bit backwards...
