Welcome to the North American Subaru Impreza Owners Club Sunday February 28, 2021
Old 03-31-2020, 01:55 PM   #601
super_subie
Member#: 344431
2020 STI
CWP
are the 2020 STI wheels the same as previous models? I only saw the previous model but noted as size 19x8.5...i thought they were 19x9.5?
super_subie is offline   Reply With Quote
Old 03-31-2020, 02:15 PM   #602
nightVzn
Member#: 291558
2020 WRX Limited
To all appearances (correct me if I'm wrong if anybody knows otherwise), the 2020 STI wheels are the same as the 2018-2019 ones with the exception of a machined finish on some spokes. Looks like they even just mildly photoshopped last year's photos for the 2020 gallery.
Specs seem the same otherwise. Although maybe that machining shaves off a negligible amount of weight
S209 gets wider wheels. But only 9" according to page 1 of this thread and the Subaru website, not 9.5.
nightVzn is offline   Reply With Quote
Old 04-01-2020, 10:34 PM   #603
Leonardo
Cowabunga!
Super Moderator
Member#: 185
1999 Impreza wagon
Dark Gray Metalic
Yes, cosmetic differences are what stands the separates the 2020 from the previous years.
Leonardo is offline   Reply With Quote
Old 04-04-2020, 11:56 PM   #604
tirving
Member#: 513183
2012 OB 3.6R Limited
Graphite Metallic Grey
Default I need help figuring out how much my OEM 17" wheels weigh for my 2012 OB 3.6R
OK, I have definitely scoured this thread and, unless I missed it, I can't for the life of me, find weight info for these rims, they're 17", came stock on my 2012 Outback 3.6R. The reason is, I am looking at a set of BRZ rims that will fit and want to know if there's an unsprung weight savings. Am I just missing the stats for this wheel in this thread? I'd like to shave off some weight if possible, from the wheels because I am getting some beefier AT tires.
tirving is offline   Reply With Quote
Old 04-05-2020, 12:05 AM   #605
chanomatik
Member#: 159474
2017 Impreza Sport
Lithium Red - OLDKID
BRZ wheels are definitely lighter.
chanomatik is online now   Reply With Quote
Old 05-14-2020, 10:01 PM   #606
gellomero
Member#: 427158
2008 WRX STI
Check all over this thread and canít find anything about it but this are OEM Enkei Wheels out of a 2019 WRX with Brembo option, I test them on a 2012 STI and have a bit more then 1/8 of and inch so about 3.5MM of clearance. Tight fitment but no rubbing at all, also the rear Brembo brakes have so much free room that didnít bother to take pictures
Please Moderator feel free to delete post if not allowed.
gellomero is offline   Reply With Quote
Old 05-15-2020, 09:57 AM   #607
Detslider
Member#: 170244
'16 Outback
Dan, awesome thread! Thanks for doing the research and putting it all in one place. I came here looking for stock specs for a 2006 WRX Wagon and noticed the specs listed here are different than what is on the fastwrx.com site.
I checked the door plate on my car and it says the stock tire size is 215/45R17. Can you confirm if the backspacing is +55 or +53?
Thanks! When the storefront opens again I'll be sure to swing by and do some impulse shopping.
Originally Posted by Mach V Dan View Post
2006-07 WRX
Offset: +55
Bolt pattern: 5x100
Wheel Weight: 21.0 lbs (Mach V shipping scale)
OEM-equipped tire size: 215/45R17
https://www.fastwrx.com/pages/subaru...el-information
2006-2008 WRX wheels:
Bolt pattern: 5x100
Centerbore: 56.1mm
Wheel size: 17 x 7.0"
Offset: 53mm
Stock tire: 205/50R17
Detslider is offline   Reply With Quote
Old 05-15-2020, 12:09 PM   #608
Mach V Dan
Member#: 12029
Originally Posted by gellomero View Post
Check all over this thread and can't find anything about it but this are OEM Enkei Wheels out of a 2019 WRX with Brembo option, I test them on a 2012 STI and have a bit more then 1/8 of and inch so about 3.5MM of clearance. Tight fitment but no rubbing at all, also the rear Brembo brakes have so much free room that didn't bother to take pictures
This is interesting because it appears Subaru made a running change on this wheel design. When this style first came out in 2018, it did NOT clear four-piston Brembos. Now (2019 model year and later), it DOES.
...Can you confirm if the backspacing is +55 or +53?
+55.
Dan
Mach V
FastWRX.com
Old 07-14-2020, 04:47 AM   #609
Franz At
Member#: 504118
Seems like the newer models of Subaru are using wider wheels. Nonetheless I would still replace them with an aftermarket wheels like Method race MR501 VT-Spec. A pal of mine bought a set from 4WheelOnline and looked and fitted sharp on his blue wrx.
Franz At is offline   Reply With Quote
Old 08-08-2020, 04:36 PM   #610
npav78
Member#: 510370
I'm out of space in my initial posts, but here are some more:
2018 BBS Subaru WRX STI Type RA/Series.White/S209
Size: 19x8.5" (19x9.0" for S209)
Offset: +55 (+54 for S209?)
Bolt pattern: 5x114
Wheel Weight: 24.15 (est.)
OEM-equipped tire size: 245/35R19 (265/35R19 for S209)
Notes: Available in gold (Type RA and S209), bronze (Series.White), and gunmetal (S209). Clears 6-pot Brembos. Not sure about 4-pot.
How can I order the Gunmetal one ?
npav78 is offline   Reply With Quote
Old 08-30-2020, 10:54 PM   #611
Mach V Dan
Member#: 12029
You can't. It's S209-spec, and Subaru guards those, so if you want to order it you have to pony up your VIN and proof of ownership. Plus they are probably like $2500 each, although I haven't priced them out yet.
Dan
Mach V
FastWRX.com
Old 09-16-2020, 03:55 PM   #612
LonelyDriver38
Member#: 518627
Hello,
I was curious to know if you knew if the 4piston fronts and 2 piston rear Brembos off the 2015 would fit in the 2018 WRX 17inch wheels? If I would need spacers or if it would even fit in the barrel of the wheel?
I would personally like to keep the wheels at 17inch if I can and the calipers will clear.
Thank you!
LonelyDriver38 is offline   Reply With Quote
Old 09-22-2020, 12:28 PM   #613
Mach V Dan
Member#: 12029
Originally Posted by LonelyDriver38 View Post
Hello,
They will not fit.
Dan
Mach V
FastWRX.com
Old 10-02-2020, 12:07 PM   #614
bnkrpt
Member#: 422266
Default 50th anniversary wheels
Can someone help me find the part number for the 50th anniversary WRX wheels from 2018? I like the silver and think they'd look great on my white WRX.
bnkrpt is offline   Reply With Quote
Old 10-05-2020, 04:08 PM   #615
Mach V Dan
Member#: 12029
We sell those, HERE.
Dan
Mach V
FastWRX.com
Old 10-31-2020, 12:02 PM   #616
sharky512345
Member#: 54314
1999 Legacy GT
I'm curious if anyone knows the specs for the 2021 Crosstrek Sport 17" wheels.
sharky512345 is offline   Reply With Quote
Old 11-01-2020, 03:55 AM   #617
Tedde22
Member#: 184981
2020 WRX STI
Ceramic White
Question
Dan
Mach V
FastWRX.com
Any idea if these clear the 2016 STI 4 pots ?
I haven't been able to find a clear yes/no. It appears they put these wheels on the WRX Series.White which has 4 pots ?
Tedde22 is offline   Reply With Quote
Old 11-02-2020, 08:17 AM   #618
McFarland15
Member#: 463181
2016 WRX STi
Dark Grey metallic
I picked up 19STi 19inch wheels for my 16 STi not knowing that they don't clear the front calipers. My question is if I put a spacer on the fronts what size do I need ,and is it ok to run spacers on the fronts without needing them on the rear ? Or do you need to run spacers on all four Wheels ? Thanks
McFarland15 is offline   Reply With Quote
Old 11-02-2020, 05:52 PM   #619
Mach V Dan
Member#: 12029
Probably not.
For 2020 -- the first year the WRX was available with Brembos -- the standard WRX wheel got a revision that allowed it to clear 4-pot Brembos. The Series.White wheels also clear. Older WRX wheels do NOT clear, so we're guessing the 50th Anniversary silver ones don't clear, either.
5mm spacer required in most cases, but double-check before moving the car!
Dan
Mach V
FastWRX.com
Old 11-02-2020, 09:11 PM   #620
Tedde22
Member#: 184981
2020 WRX STI
Ceramic White
Thanks Dan, the info and help is much appreciated.
Old 12-12-2020, 02:01 PM   #621
ILSMKU2
Member#: 77908
2020 911 S/ 2017 M3
RIP 11, 09, 06, 03 STI's
Im on the fence about buying new wheels for my 2020 STI or buying spacers. Ive had spacers on other cars and they all seem to vibrate at 80mph. So I am leaning towards wheels with a lower offerset to space the wheels out.
What are some 19" wheel options you all are using these days?
ILSMKU2 is offline   Reply With Quote
Old 12-14-2020, 10:42 AM   #622
Mach V Dan
Member#: 12029
Please keep this thread focused on the specifications of OEM wheels. Your question might be a good subject for a new thread.
Dan
Mach V
FastWRX.com
Old 12-14-2020, 02:48 PM   #623
BlueSTI4Me
Member#: 34361
04.7 STI
WRB IG @got2boostit2
Subscribed for reference.
BlueSTI4Me is offline   Reply With Quote
Old 01-19-2021, 01:15 AM   #624
ml3941
Member#: 490098
Is this wheel from a 2019 WRX or 2020 WRX? Brembo option is only offered on MY 2020 and as a 2019 owner I wonder if my wheels would clear 4pot brembos.
ml3941 is offline   Reply With Quote
Old 01-21-2021, 12:43 PM   #625
Mach V Dan
Member#: 12029
Originally Posted by ml3941 View Post
Is this wheel from a 2019 WRX or 2020 WRX? Brembo option is only offered on MY 2020...
As far as I can tell, that wheel above must be from a MY2020 US car. (Could be earlier model year in other markets.)
They will not without at least a 3mm spacer.
Dan
Mach V
FastWRX.com
WTB : Alloy WHEELS or nicer oem subaru wheels to replace my ugly steel wheels MR2fanatic Tri-State Area Private Classifieds 7 04-03-2011 10:24 PM
WTT: OEM subaru wheels/tires for Gold 17" wheels veselik3 NWIC Private Classifieds 2 05-16-2006 04:24 PM
gauging interest: rs 16x7 gold wheels 5 spoke oem subaru wheels anthonyrb98 Private 'For Sale' Classifieds 53 04-27-2006 01:43 PM
Anyone have a set of OEM WRX wheels they want to get rid of? Skibum4444 North West Impreza Club Forum -- NWIC 2 01-31-2003 01:48 AM
Subaru Wheel Specs Snowrider Brakes, Steering & Suspension 3 10-07-2001 10:20 PM
