Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 10-08-2018, 03:26 PM   #1
SubaruImpreza25i
Member#: 492468
Default Compatible motors for 08 Impreza 2 5i?
I have a quick question for anyone that might know. I have a 08 Impreza 2.5i (base) that needs a motor. All I know is it has the n/a EJ25. Does anyone know any makes/model years of other Subarus that the motors can drop in my 08?
If I have to swap intakes, ecus, etc. I'm fine with it I just don't know what would actually fit if possible. Thanks!
SubaruImpreza25i is offline   Reply With Quote
Old 10-09-2018, 12:01 PM   #2
Loyale93
Newbie Moderator
Member#: 91347
2004 Tacoma Crew Cab
2012 Triumph 1050
https://en.wikipedia.org/wiki/Subaru_EJ_engine
Here you go.
Please also fill in your profile.
Loyale93 is offline   Reply With Quote
Old 10-15-2018, 11:08 PM   #3
NicMonte
Member#: 479655
2009 Impreza 2.5i
Light Blue
Buy a wrx, I did lol I also have a 2.5i 09 Impreza. I picked up an 02 wrx for cheap and started that as my build. Best of luck, I came to nasioc with the very same question you have. And now I own a wrx no need to swap....just start to build.
NicMonte is offline   Reply With Quote
Old 10-16-2018, 02:21 AM   #4
ManSteven
Member#: 492620
"Buy a wrx, I did lol I also have a 2.5i 09 Impreza. I picked up an 02 wrx for cheap and started that as my build. Best of luck, I came to nasioc with the very same question you have. And now I own a wrx no need to swap....just start to build."
Thanks for the tip! Glad I came across this thread.
ManSteven is offline   Reply With Quote
Old 10-16-2018, 01:35 PM   #5
Loyale93
Newbie Moderator
Member#: 91347
2012 Triumph 1050
He's not talking about a WRX swap.
OP, just buy the motor that's for your car for the least headache. You don't want to get into swapping electronics.
With the correct motor, you should be able to unbolt and unplug everything. Pull the old motor, put the new one in, and bolt/plug it back together. Easy peasy. No headaches.
Old 10-16-2018, 05:14 PM   #6
NicMonte
Member#: 479655
2009 Impreza 2.5i
Light Blue
Loyale93 I understand, however, he is talking about a "swap". Which I had the same question When I came here, and was told it'd be a wiring issue. Not that it couldn't be done, but it'd be a mess. I just said buy a wrx. Which is exactly what I was told, and read many of times lol.
