Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 10-20-2018, 08:49 PM   #1
bwWRX123
Member#: 485297
Default EGR Delete - Electrical Problems
Gents,
I have a 2018 WRX base model with the 6 speed transmission.
I had the car apart for a few weeks doing the following things:
1. TGV delete
2. EGR delete
3. Grimmspeed top mounted intercooler
4. Grimmspeed chargepipe
I finished up yesterday and drove her around a bit. Here's what I saw:
check engine light
ABS light
Vehicle dynamics control light
cruise control doesn't work!
heater doesn't work!
The check engine light was expected, but the others worry me, especially the last two.
Any thoughts? I plan to get an e-tune this week. Maybe that will fix everything . . .
Thanks,
bwWRX123
bwWRX123 is offline   Reply With Quote
Old 10-20-2018, 10:06 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Some CEL's will disable things to force you to get it fixed.
Get the codes and post them here.
Old 10-20-2018, 10:50 PM   #3
bwWRX123
Member#: 485297
There are five codes. Three refer to the EGR Solenoids, and two refer to TGV Position.
Old 10-21-2018, 11:45 PM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Please post the codes, not a basic description. Specific codes can have specific resolutions, or, they can be related to other codes.
Old 10-22-2018, 09:57 PM   #5
bwWRX123
Member#: 485297
Okay, these are the codes:
1492 EGR Solenoid Valve Signal 1 Circuit Low Input
1494 EGR Solenoid Valve Signal 2 Circuit Low Input
1498 EGR Solenoid Valve Signal 4 Circuit Low Input
2016 TGV Position Sensor 1 (RH) Circuit Low
2021 TGV Position Sensor 2 (LH) Circuit Low
Old 10-23-2018, 10:43 AM   #6
bcterp
Member#: 409569
2018 WRX
So did I read your first post correctly? You’re not tuned for the mods yet?
bcterp is offline   Reply With Quote
Old 10-23-2018, 12:36 PM   #7
bwWRX123
Member#: 485297
That's right. No tune yet for the TGV/EGR mods.
Hopefully all those codes will go away with the first map from the tuner.
I think I need to bleed the coolant system to get the heater working, so I'm not to worried about that anymore.
You and someone else told me that perhaps the ABS light, cruise control problem, etc., are tied to the TGV/EGR codes. So, hopefully those problems will go away with the first map from the tuner.
Old 10-23-2018, 12:45 PM   #8
anarekist
Member#: 468117
2017 WRX
DMG
brrrrruh, you gota have a base map to flash when you do these mods so the error codes dont show up and put you in limp mode.. talk to your etuner ask for a base map.
anarekist is offline   Reply With Quote
Old 10-23-2018, 07:43 PM   #9
bwWRX123
Member#: 485297
Okay, all problems solved.
When I put the base map on, all the warning lights and the cruise control problem went away.
Thanks for your help everybody.
