Welcome to the North American Subaru Impreza Owners Club Monday July 16, 2018
Old 03-05-2006, 07:38 PM   #1
WRXINTX
Member#: 96712
Default How to remove center differential assembly/transfer case??
Can this be done with the tranny left in the car????
Thanks!
RYNO
WRXINTX is offline   Reply With Quote
Old 03-05-2006, 07:45 PM   #2
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Yes you can do this without dropping the trans. Just remove the tail case cover.
Crazykev is offline   Reply With Quote
Old 03-05-2006, 07:56 PM   #3
WRXINTX
Member#: 96712
sweet, I thought so too, but the subie manual says first off, remove from vehicle....
the manual seems to be translated from japanese because it doesn't make good sense anywhere...
it has got Engrish translation...
any pics of all that I need to remove to get to the center diff???
or do you know of any links??
Thanks for the tip so far!!!
RYNO
Old 03-05-2006, 08:21 PM   #4
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
You have to remove:
Drive shaft
Crossmember
Shift linkage
Remove the spring pins that hold the shift bracket to the selector rod
I don't have any pics, but it is pretty simple. The only tough part (not even hard) is removing the spring pins.
Old 03-05-2006, 09:18 PM   #5
WRXINTX
Member#: 96712
Originally Posted by Crazykev
You have to remove:
Drive shaft
Crossmember
Shift linkage
awesome, you both have been lots of help!!!!
Thanks and I will keep it posted as to what was broke when I get into it tomorrow night!!!
THANKS AGAIN!
RYNO
Old 03-06-2006, 10:56 PM   #6
WRXINTX
Member#: 96712
everything went smoothly.... It was the output shaft, broken, stuck in the driveshaft....BUT WAIT!!!
there's MORE!!!
the center diff had popped itself apart after wearing the cross pin that the spiders ride on... I am going to post pics on the other thread when I get to a computer that has something faster than the dial up that I am on at home.... :-/
Thanks so much to those who offered hints and tips... seems like my first assumption was correct on the center diff.... better than a slipping clutch and better than broken gears or shift forks...
Sincerely,
RYNO
Old 03-07-2006, 07:07 AM   #7
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Sweet! I was pretty sure your stepper or output shaft was schmeckled.
Old 03-07-2006, 07:42 AM   #8
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Actually, driving the car with the snapped output shaft is what probably ruined the center diff. It was probably trying it's little heart out to keep ya' going
Old 03-08-2006, 11:46 AM   #9
WRXINTX
Member#: 96712
pics here ....
http://forums.nasioc.com/forums/show...6#post12963466
Thanks again for all the help!!!!
This was my first time to dig into one, and they are really cool.... done other trannys before, but not a subie...
RYNO
How to remove rear differential sensor? ASAP DJS1 Transmission (AT/MT) & Driveline 1 05-01-2010 05:31 PM
How to remove center panel of STI rey_vibora Newbies & FAQs 8 04-18-2004 10:34 AM
how to remove rear differential protector? exhondaguy Transmission (AT/MT) & Driveline 1 07-30-2003 11:37 AM
How to remove center console? BeavisNuke Interior & Exterior Modification 4 05-26-2002 06:01 PM
How to remove center panel??? Br0kWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-19-2002 09:08 PM
