Welcome to the North American Subaru Impreza Owners Club Monday February 19, 2018
Old 05-26-2002, 02:04 PM   #1
BeavisNuke
Member#: 14981
2002 WRX Sedan WRB
TurboXS Stage 2.5
Default Best way to remove center console?
I'm installing a short shifter today and need to pry this thing off somehow.
BeavisNuke is offline   Reply With Quote
Old 05-26-2002, 04:40 PM   #2
6Pack
Member#: 13901
2002 WRX Sedan
It's a combination of prying and unscrewing. If you don't feel like doing a search here, there's some good instruction on scoobymods.com for some other mods that require its removal. It's pretty simple and you can tell what needs to be done as you're doing it, just take your time.
6Pack is offline   Reply With Quote
Old 05-26-2002, 04:46 PM   #3
edkwon
Member#: 453
2017 Kia Niro
2016 Porsche Cayman GTS
6Pack is right, scoobymods.com will probably have the answer. The removal of the center console for the GC8 and GDA chassis cars are pretty similar. You have to unscrew and dismantle the console starting from the arm rest section and remove each piece sequentially moving up towards the stereo in order to expose the shifter plate and swap out your shifter.
Ed
edkwon is online now   Reply With Quote
Old 05-26-2002, 05:14 PM   #4
nqwan
Member#: 2916
02 duburu arr exu
trying to take off the armrest section only left me with a gouge that is luckily out of sight. i simply started from the shiftboot area, just reach in and pull up on the piece until the clips pop off. then work your way back. thats the easiest way i've found to do it. some people pull out the ebrake portion first
hope that helps,
nqwan
nqwan is offline   Reply With Quote
Old 05-26-2002, 07:01 PM   #5
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Search the scoobymods.com site. The WRX and RS are different. No screws for the WRX just tugging.
Peaty
www.Scoobymods.com
Peaty is offline   Reply With Quote
trying to remove center console on 06 THE_DON Interior & Exterior Modification 0 05-03-2010 11:17 PM
How to remove center console for 06 WRX? Daemos Interior & Exterior Modification 5 05-16-2007 11:44 PM
How to remove center differential assembly/transfer case?? WRXINTX Transmission (AT/MT) & Driveline 8 03-08-2006 12:46 PM
How to remove center panel of STI rey_vibora Newbies & FAQs 8 04-18-2004 11:34 AM
How to remove center panel??? Br0kWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-19-2002 10:08 PM
