06-05-2005, 12:49 PM | #1 |
Member#: 14868
Vehicle:2002 wrx |
mounting my sub and amp in my trunk
hey guys, i need to mount both my amp and sub in my trunk and was wondering if these would be ok spots to use.
for the amp: the back wall of my trunk (back of the rear seats). if i just drilled a few small screws to just hold the amp in place. the sub box: if i just drilled some small screws through the board on the bottom of the trunk into the box, the one on top of the spare. would this be possible? thanks
06-05-2005, 01:42 PM | #2 |
Member#: 88024
Vehicle:1997 OBS red/gun metal two tone |
the amp is a good i dea, just make sure you know what your drilling into first, find solid mounting points or it's going to fall off in hard driving.
for the sub box... go to wal*mart, buy some industrial strength velcro in the fabrics section, i think it's like $7, but the side wit the hooks on the bottom of your box and then stick it down to your carpet, the hooks will catch with the carpet and you'll be fine. I have 2 10s in a box with the amp on the back of the box stuck down with that stuff and i can go run through dirt roads at high speeds and slide around turns without the box budging one bit. it's also much easier than screwing stuff down |
06-05-2005, 02:39 PM | #3 |
Member#: 14868
Vehicle:2002 wrx |
thanks!
i actually have a bunch of velcro strips. they are general use for smooth surfaces and not really for clothed surfaces, but im pretty sure if i use enough it wont really matter, its only a single 12 in a medium sized box. almost 19 all around. thanks again! |
06-05-2005, 07:10 PM | #4 |
Member#: 59015
Vehicle:2004 WRX Blue |
I mounted a crossboard behind the seat to mound my amps (two of them). I tried the velcro route for my sub-box and it worked well until I took my first brisk corner (another words, velcro sucks!). The cheapest way that I found to hold my box in place was to use a truck bed pole (adjustable pole) and mount it in front of my box (box is nearest the bumper). It's light and doesn't cause me any problems at all.. plus its easy to remove.
I have seen people remove the spare and prep the hole for a single speaker... looks nice and works well if you don't want a spare. |
06-05-2005, 07:35 PM | #5 |
Member#: 77483
NWIC
Vehicle:2009 Audi A3 2.0T q Lava Grey |
06-05-2005, 07:49 PM | #6 |
Member#: 70395
Since i got rims and tires the spare doesn't match the new wheels diameter so i ditched it and put my amp in there.I don't like the idea of on the back seats because the heat is just radiating back onto the amp.Maybe if it was 100% verticle and you mounted it with the fins verticle but on a hot day those amps will shut down if your pushing them.Especially with the crappy 13.8 volts from the alt.GM alts rule with the 14.5V
06-05-2005, 11:58 PM | #7 | |
Member#: 88024
06-06-2005, 12:02 AM | #8 |
Member#: 88024
if you want a clean install you can do what we did with my friends civic, like dumdum said you can put the sub in the spare tire well. check out his page, we just put fiberglass in the bottom of the car, cut off the excess, built a frame to hold the mdf for the sub mount, fiberglassed it air tight and then mounted his sub inside. granted he does have a massive PG titanium 15 so we had to mount it a little above the floor level, but with a smaller sub it should fit flush.
here's his cardomain page if you want to see what we did. http://www.cardomain.com/ride/692845/3 |
06-06-2005, 03:25 AM | #9 |
Member#: 59015
Yea, I don't agree with mounting the amps to the back of the seats either. Thats Why i mounted them on a mounting board about 2"s off the back seat. You space them out and drill you a hole between them in the board... thats where you run the cables through. Keeps it real clean.
06-07-2005, 03:30 PM | #10 |
Member#: 14868
Vehicle:2002 wrx |
thanks for the advice guys, i went ahead and used velcro liberally on the bottom of the box and then mounted my amp on top of the box via the same method. needless to say it looks super clean, and best of all - no holes!
heres a quick pic of it. thanks again! |
06-08-2005, 01:10 AM | #11 |
Member#: 59015
Go take a quick corner... let me know if either 1. the carpet moves and speaker slides around or 2. the velcro doesn't hold. Thats what happened to me... got tired of dealing with it.
06-08-2005, 01:13 AM | #12 |
Member#: 82259
BAIC
Vehicle:1999 impreza 2.2L Brilliant Red <4EAT Club> |
once again heres teh svek lazy ass way to do it
06-08-2005, 05:00 PM | #13 | |
Member#: 14868
Vehicle:2002 wrx |
already velcro'd the carpet. everything has been holding, its great. 1000watts in the trunk and headache free. |
Sub Box, 2x10" Subs and 400W Amp - Designed to fit GC trunk. (prefer TX local) | Skidd | TXIC Private Classifieds | 8 | 02-11-2012 03:27 PM |
FS ID: Custom STi sub and amp install in trunk | deluxsti | Interior/Dressup/Audio & Security | 7 | 12-19-2006 02:57 PM |
CO: FS Sub and Amp in box | 02rusWRX | Private 'For Sale' Classifieds | 0 | 10-28-2005 12:04 AM |
sub and amp or speakers and amp | dan avoN7 | Car Audio, Video & Security | 2 | 12-05-2004 10:52 AM |
two 8 inch subs and amp in custom box for sale | Thug | New England Impreza Club Forum -- NESIC | 1 | 05-23-2000 10:02 PM |
