Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Old 08-22-2008, 10:03 AM   #1
Gso2k
Member#: 117378
2006 2.5i
Regal Blue Pearl
Default what adhesive did Subaru use for the rubber molding on sideskirts?
I removed the rubber molding from some wrx sideskrits to paint them. I didn't tape off the gunky glue part so now I need to buy an adhesive similar to what was used to make them stay.
Question: Does anyone know what was originally used? If not, could you recommend something that is similar that will still make the rubber sit as flush as it was stock and not apepar as though its raised or coming off? Something from 3M im guessing..
Thanks guys.
Gso2k is offline   Reply With Quote
Old 08-22-2008, 12:28 PM   #2
Brown's Mazda
Member#: 186428
05 Makin' cars
pretty
If you can remove the glue and have the molding sit flush, once you put the sideskirt back on, the pressure will hold it. Adhesive glue is very messing/stringy. Do you know which one came of which side? I've put many on without adding more glue and they will stay. Occasionally I've had some where they didn't quite stay on the ends.
-Lance
Brown's Mazda is offline   Reply With Quote
Old 08-22-2008, 12:39 PM   #3
ANIMAL_STI
Member#: 181686
06 STI
AWP
personally, i didnt run the rubber molding
blends in better with the body
ANIMAL_STI is offline   Reply With Quote
Old 08-22-2008, 05:40 PM   #4
SchmisterTyler
Member#: 185992
2003 WRX Impreza
World Rally Blue
Default haha
mine came off with weather, so i just superglued it back on, it works great cause super glue doesn't really take up any space as an adhesive, its like water. At first i was worried it might like melt the rubber from crazy chemical reaction but, its worked fine.
SchmisterTyler is offline   Reply With Quote
What sealant does subaru use for our headlights? jcbluescooby Interior & Exterior Modification 20 05-25-2012 02:04 PM
what ratio do you use for the amount of $$ to spend on a car? jhayzhon Off-Topic 21 08-03-2005 08:36 PM
What fix did you use for CEL P0420 ? WolfInSheepsCLothing General Community 19 08-25-2004 12:43 AM
What amp did you use for Type R's? fukamoto Car Audio, Video & Security 5 01-30-2003 08:43 PM
Which Westach probe did u use for the EGT? halogen Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-19-2001 07:01 PM
