Welcome to the North American Subaru Impreza Owners Club Thursday May 13, 2021
Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 01-06-2010, 02:19 PM   #1
cbeaum14
Member#: 211526
2004 STI
JBP
Exclamation HELP!! leaking tein strut
so i went in for my alignmet check and they showed me that my driver front tein bacis coilover is leaking oil. i thought that they might have been mis guided for whatever reason but they wernt. so now i need to fix this some how....buy a new damper? rebuild the damper?? who can rebuild in DFW??? o yea did i mention i have to get this done by friday?!?!? HELP!!!!!
info from the damper lable:
Tein Damper Basic
DLS60-UZ746-L
impreza 02+ 04STI
82027
cbeaum14 is offline   Reply With Quote
Old 01-06-2010, 02:21 PM   #2
Big_Hitter
Member#: 10831
1995 Firehawk #456
2009 FXT VF52/E85
so your strut is leaking oil? what's the big deal?
are you Adam James or something?
(j/k)
Big_Hitter is offline   Reply With Quote
Old 01-06-2010, 02:26 PM   #3
ohxietviet
Member#: 143164
06 AW WRX
Send back to Tein for rebuild.
ohxietviet is offline   Reply With Quote
Old 01-06-2010, 02:30 PM   #4
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
Good luck with that....
Squidz is offline   Reply With Quote
Old 01-06-2010, 02:42 PM   #5
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
^^^ +1 my friend sent his back to tein and some how tein lost it lol so screw that.
ownnij is offline   Reply With Quote
Old 01-06-2010, 02:43 PM   #6
cbeaum14
Member#: 211526
2004 STI
JBP
yea i called em and they said it would take like a month!! wtf??!! a month?? really it should b free in that case.
Old 01-06-2010, 02:51 PM   #7
cbeaum14
Member#: 211526
2004 STI
JBP
update:
ANYONE KNOW SOMEONE IN DFW THAT CAN REBUILD MY DAMPER?!?!?!?!?!?!?!?!?
SO these are pretty much my options....
1. my shop/tuner wasts $500 for swap all 4 corners with the old suspension.
2. overnight a new strut from tein in CA ($400) and have it installed ($300). id do it myself but its cold outside ppl....
3. screw it and drive 500miles back to school (jackson, MS) and figure something between now and May.
Old 01-06-2010, 05:44 PM   #8
ohxietviet
Member#: 143164
06 AW WRX
I'm sorry but to remain hella jdm fresh you must ship them to Tein.
Old 01-06-2010, 06:18 PM   #9
aschen
Member#: 30733
2007 tiny car
striped
The answer is pretty easy
1: don't overnight strut, ship regular cheap method
1b: drive on blown damper for the time being, no big deal
2: wait for a warm afternoon
3: install in like 8.5 min
Keep in mind you dont need the whole strut, you should be able to buy the damper for a couple hundred somewhere....
aschen is offline   Reply With Quote
Old 01-06-2010, 10:38 PM   #10
cbeaum14
Member#: 211526
2004 STI
JBP
exactly what im doing. ill have to wait till may when i get back from school to fix everything but i dont drive that much at school anyways. and ur right all i need is a damper but tein still want $440 for a new damper only...wtf. o well.
Old 01-06-2010, 11:09 PM   #11
warlocksbugeye
Member#: 204869
03' WRX - Black
Your doing better than me since HKS has had mine for over three months!
warlocksbugeye is offline   Reply With Quote
Old 01-06-2010, 11:22 PM   #12
StaplesFreak
Member#: 224233
2007 STi "Sally"
Blk
If you havent had them for too long I would at least contact Tein
StaplesFreak is offline   Reply With Quote
Old 01-07-2010, 12:25 AM   #13
Br0wnb0y
Member#: 109147
2005 LGT Not
BSM
So you're not supposed to ride around on blown struts for months?
...I guess I didn't it wrong
Br0wnb0y is offline   Reply With Quote
Old 01-07-2010, 05:10 PM   #14
cbeaum14
Member#: 211526
2004 STI
JBP
yea i called them its only year warrenty from the date of purchase not even the install date. HKS is F'n up! im afarid tein will do the same thing although they garenteed 3-4 weeks repair not indluding shippin.
Old 01-09-2010, 12:58 PM   #15
couldnthinkaone
Member#: 2944
2012 E550 BiTurbo
11.3 @122mph
can you get parts to rebuild them?
couldnthinkaone is offline   Reply With Quote
Old 01-10-2010, 02:32 PM   #16
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
There is a huge difference between a leaking strut and a blown strut. Most struts will leak slightly in various places, no matter how old/new they are. I no longer use Koni struts because they leaked severely in the 6 cars I used them on. BUT according to Koni the leak did not affect operation of the strut, and unless you are a chassis dynamics engineer or a great driver, you may not be able to really "tell" that a strut is blown. The only way to know is to remove it and put it on a shock dyno....costs $25-$50 each. Most major cities have a race shop that can perform this duty, you just need to search around.
Tein does their rebuilds in California (a friend of mine works there), they used to do it in Japan only. Unless the strut is clunking severely (after you have removed it from the car AND retightened all of the hardware), is dumping oil out of the shaft seal or a cannister puncture, or the rebound adjuster does not have any apparent change in performance (but you may not be able to see that unless it's on a shock dyno), then don't worry about a little leak. You do want a little bit of oil on the shaft for normal operation, you just don't want it dumping out the shaft seal or cap crimps.
PS-- I know what I'm talking about. hahaha
JamesWilson2 is offline   Reply With Quote
Old 01-10-2010, 10:28 PM   #17
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
^^this.
scby rex is offline   Reply With Quote
Old 02-10-2021, 01:34 AM   #18
sebastian323
Member#: 510671
2006 WRX
Gray
good information. what is the approximate cost of rebuilding a damper if I send it in?
sebastian323 is offline   Reply With Quote
Old 02-10-2021, 08:59 PM   #19
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
U know u bumped a 11yr old thread right?
No matter I will play
https://www.tein.com/service/price_list.html
Old 02-11-2021, 10:48 AM   #20
Silver571
Member#: 88361
2013 Zentorno
at least he searched, eh?
Silver571 is offline   Reply With Quote
Old 02-17-2021, 03:58 PM   #21
sebastian323
Member#: 510671
2006 WRX
Gray
thanks dude!
haha , yes, I searched!
FS: 04 sti struts, 06 wrx suspension, tein strut bar Poekin MAIC Private Classifieds 10 09-20-2007 09:18 PM
NorCal: 02 WRX Sedan Stock Struts with Tein Struts - $150 t3ch9 Private 'For Sale' Classifieds 2 05-24-2006 09:09 PM
leaking front struts mengy2 Brakes, Steering & Suspension 0 04-12-2004 11:42 PM
help with Tein strut tops and camber bolts WRXIN Brakes, Steering & Suspension 5 12-05-2002 07:42 PM
