Welcome to the North American Subaru Impreza Owners Club Friday May 7, 2021
Old 08-23-2002, 09:54 AM   #1
Osgood30
Member#: 20437
1999 Impreza RS
STI Ver7
Have a Nice Day? oil vapor catch can or ... I am confused
ok,
I have purchased RalliSpec intake system from RalliSpec. They have discontinued making them, so I told him I'll buy what you got and then make the rest myself. The picture below is what I got, just a tube and a K&N cone filter. The tube goes directly onto the throttle body.
I asked him: "what do I need to do to finish it?"
he said: "well, you would need brakets to hold the tube, and a heat shield".
I said: "ok, can't be that hard".
I then asked him: "but other than that it is ready to go, I can just put it on."
He said: " yep"
So when I was taking off the original air box, I noticed 3 hoses that come from the engine block, to the air box. If I would installed RalliSpec system it would leave those 3 hoses unconnected.
Then I called RalliSpec back. And he told me, "oh yeah, you will need a catch can for those 3 hoses"
I think I have fugured out that the catch can is, but my question is , where can I get it, and if I can feed those 3 hoses into the RalliSpec tube instead.
please help, bacause right now I just bought stuff that has no freakin use for me.
Thanks
Alex
Osgood30 is offline   Reply With Quote
Old 08-23-2002, 11:48 AM   #2
Fred Zaplitny
Gone... But not forgotten
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
The origional RalliSpec can was custom made IIRC. If I had to use a catch can, I would probably go with a JAZ breather tank. The 1 pint size unit. It only has 2 inlets, but you can use a T fitting to attach the 3rd hose.
Fred
Edit: check this link
Fred Zaplitny is offline   Reply With Quote
Old 08-23-2002, 12:53 PM   #3
SUBACHI
Member#: 20457
2002 SUBARU IMPREZA
Blue Ridge Pearl
I got a jaz products oil catch can(breather) for my 02 rs. last year. Its amazing how much oil collects in that can. The thought of that much oil going into my intake scares me. I also got a good deal on my catch can. Here is the link to where I got mine.
http://www.goodvibesracing.com/Breather%20Tanks.htm
sorry no pics on car but it really looks cool under the hood.
SUBACHI is offline   Reply With Quote
Old 08-23-2002, 02:45 PM   #4
GooseMan
Member#: 2462
2012 Audi A4 Avant
S-Line Titanium
I have the Rallispec system. The intake comes with a little catch can that mounts to one of the aribox brackets, and all three hoses connect to it.
It also comes with a plexiglas heat sheild and some spacers for the hood vent to let cool air in.
Actually, you didnt happen to get these did you? Cause I need new ones!
GooseMan is offline   Reply With Quote
Old 08-23-2002, 09:30 PM   #5
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
For the heat sheild a guy named steathbmber or something similar was making them for like 30 bucks a pop. Havent seen him on the board in a while i think he switched jobs and lost internet access but maybe someone may still be in touch with him.
Poppa smurf is offline   Reply With Quote
Old 08-24-2002, 04:13 PM   #6
GooseMan
Member#: 2462
2012 Audi A4 Avant
S-Line Titanium
Yup! stealthbmbmr2 (he had to change his screen name) makes EXCELLENT heat sheilds. I actually have one myself. Very nice!
Old 08-24-2002, 09:42 PM   #7
Osgood30
Member#: 20437
1999 Impreza RS
STI Ver7
Thanks for responces guys. I can make the heat shield myself. But I am going to go with this breather/catch can (picture below). It only has 2 nipples.
My question is: do all 3 tubes that go into air box, on origional Subaru set up "inlets", or is it 2 side tubes are inlets and middle outlet? Because I will need to connect 2 tubes in 1 before going in breather tank. Whould it matter which to tubes to connect, or would it be better to connect 2 side tubes and leave middle one alone?
Thanks again
Alex
Old 08-25-2002, 06:07 PM   #8
Osgood30
Member#: 20437
1999 Impreza RS
STI Ver7
bump
Old 08-25-2002, 08:53 PM   #9
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
From the looks of the valve on the middle one, I'd say that's a drain.
Comes standard with molded-in inserts and a swivel petcock for easy draining.
Yup, middle one is for draining. I'd connect 2 lines to one side and the third to the other side. Just get a Y coupler and you should be fine.
AJ
AJ711 is offline   Reply With Quote
oil catch can or air oil seperator??? jaytech Newbies & FAQs 11 09-21-2009 12:03 AM
Oil catch can...or catch canS?? BoXinWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-28-2009 05:01 PM
NJ:RED Perrin Oil/coolant catch can dancemf6 Engine/Power/Exhaust 0 12-05-2006 06:05 PM
Oil in catch can, odd consistency?? BigJ04STi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 02-20-2006 04:47 PM
NE1 out there with a Rallispec intake with aluminum crank-vapor catch can w/ filter? MrP0nch0 Technical Forum Archive 16 07-25-2000 12:05 AM
