Welcome to the North American Subaru Impreza Owners Club Friday May 14, 2021
Old 04-12-2021, 11:51 AM   #15301
trevoroni
Member#: 155188
Our base model Samsung fridge with the freezer on the bottom is about 5 years old and it's still going without any repairs.
The compressor has been getting noisier and turns off with a clunk so I'm not holding my breath on it lasting too much longer though.
I think the consensus on fridges these days is they all suck.
trevoroni is offline   Reply With Quote
Old 04-12-2021, 12:01 PM   #15302
Badler
Member#: 133597
Friend has gone through 2 LG fridges in the last 3 years or so. He's had to replace some part multiple times already FWIW.
Badler is offline   Reply With Quote
Old 04-12-2021, 12:09 PM   #15303
orndog
Member#: 34670
2016 slowmobile
Originally Posted by f4phantomii View Post
Wood frame around the door? Handyman or carpenter.
If it's just the bottom 12 inch or so of the wooden frame, that can usually be cut out and new wood spliced in fairly seamlessly.
Oh, and for god sakes install some rain gutters!
The last time I spliced in a spot, I used PVC "lumber". That way, no more rot from rain splashback.
The last 2 exterior doors I've replaced I got as much of the frame in PVC as I could get. The exterior brickmould trim is also PVC.
edit: I don't know what I'm doing.
orndog is offline   Reply With Quote
Old 04-12-2021, 01:03 PM   #15304
WRX Shenanigans
Member#: 101378
Originally Posted by Grap View Post
You're replacing the entire motor/fan assembly, right?
You're not trying to mix/match parts, are you?
You can buy an entire new assembly for like $30.
Yup, entire motor/fan assembly, but not the housing. I was trying to avoid replacing the whole housing. The custom job is because I couldn't find a motor/fan with the exact same specs as my current to fit in the same housing. Not really that big a deal; I just had to use the bracket from the previous motor to fit in the old housing. That part fit perfectly.
WRX Shenanigans is offline   Reply With Quote
Old 04-12-2021, 01:05 PM   #15305
WRX Shenanigans
Member#: 101378
Originally Posted by TMSmith View Post
Fridge suggestions? Hoping for 1500 or less but 2000 or less if we need to. Think the one that came with the house is going out.
All these suggestions are really anecdotal anyway, but I have all Maytag appliances and they have been good. Needed minor stuff but nothing major and I've had them for a little over 7 years.
Do you want a side by side? Or a French door fridge with a bottom freezer (which is what mine is and I highly suggest it over a side by side) like this:
https://www.maytag.com/kitchen/refri...ft2772hez.html
Old 04-12-2021, 01:14 PM   #15306
Badler
Member#: 133597
Originally Posted by vapore0n View Post
Who do you call when you want to get the frame to a storm door replaced?
Door and window install guy? Handyman? Ghost Busters?
Whoever installed that storm door at my house used wood scraps and did it with their feet! Wood rotting, cracked, needs to be replaced.
Should I do it? I need a saw to cut to measure. I should buy one. I need to replace frame wood on the garage too. The bottom area is all chewed up.
Have then use Windsor One if possible.
Old 04-12-2021, 01:53 PM   #15307
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
Just as a PSA, we bought a Unitech exhaust fan with humidity sensor. It's been awesome so far. It's got 3 speeds, plus a manual override. Not only have we not had to think about turning it on, but the mirror in the bathroom hasn't even fogged a bit since it's been in. The overall dampness feel in the main bathroom has completely disappeared.
mhoward1 is offline   Reply With Quote
Old 04-12-2021, 02:03 PM   #15308
vapore0n
Member#: 21356
2017 Subaru Corolla
STI Limited SE-R Type (R)
This is what Im dealing with.
I see that there is a baby gutter, and it drains right on top of that rotted wood
Some of those plastic pieces are broken due to the sun making them brittle. Ill have to do those too.
Ill look at those WindsorOne pieces. I like having 30 yr warranty.
vapore0n is offline   Reply With Quote
Old 04-12-2021, 04:14 PM   #15309
Grap
Dicky Nipperist
Member#: 6590
That plastic 'gutter' is called 'J' channel and it's on every house with siding like that. The piece between the wood trim and the j-channel is called 'Z' channel, and it should go up behind the siding and direct water down the face of the trim, rather than letting it behind it and rotting your structure.
The wood brickmold failed due to ****ty paint prep and care....it's also wood. Replace that **** with PVC brickmold and never look back.
Grap is offline   Reply With Quote
Old 04-13-2021, 09:29 AM   #15310
vapore0n
Member#: 21356
2017 Subaru Corolla
Thanks for posting the actual names of parts.
That way I can tell the handyman or whoever does the work, rather than point to things.
Old 04-13-2021, 09:29 AM   #15311
vapore0n
Member#: 21356
2017 Subaru Corolla
double post tuesday!
Old 04-13-2021, 07:39 PM   #15312
f4phantomii
Member#: 58504
2004 STi
Aspen White / Silver
Wow! Actual Z channel under the J channel!
No builders here do that like they should. All I ever see is the J channel right on the brickmould and a bead of caulk between the two.
f4phantomii is offline   Reply With Quote
Old 04-13-2021, 08:51 PM   #15313
Grap
Dicky Nipperist
Member#: 6590
I know, right??
Old 04-14-2021, 08:38 AM   #15314
mla163
Member#: 104922
2016 WRX
Apparently playground mulch is at a severe shortage this season. I have a playground all set up and want to fill it with about 3 cy of playground wood chips. The stuff I'm looking at is "certified" playground mulch, so it's softer and degrades slower.
I called 10 places and no one has any. They are months out. What are my options?
I don't want rubber mulch because that stuff is forever. I don't want regular wood chips because these kids run around barefoot.
Is there some kind of friendly mulch type thing that I can use. Good for barefeet and soft?
mla163 is offline   Reply With Quote
Old 04-14-2021, 08:57 AM   #15315
shiplemw
Member#: 203905
Dirt.
shiplemw is offline   Reply With Quote
Old 04-14-2021, 08:58 AM   #15316
shiplemw
Member#: 203905
Did you take a picture of the back door at my place? I have the same issue / color siding and also have the same deck color but different front door.
Old 04-14-2021, 09:20 AM   #15317
Grap
Dicky Nipperist
Member#: 6590
What's wrong with asphalt and the random broken bottle like when we were kids?
Old 04-14-2021, 09:49 AM   #15318
vapore0n
Member#: 21356
2017 Subaru Corolla
What a small world.
Apparently we both had the same person do the same ****ty job
Old 04-14-2021, 10:14 AM   #15319
TMSmith
Member#: 216496
Due to covid/the last year or so, I honestly donít know what industry or good hasnít been affected at this point. Cars, gym equipment, mfg. supplies, steel, home material, appliances, windows, etc. itís crazy.
TMSmith is offline   Reply With Quote
Old 04-14-2021, 12:34 PM   #15320
shiplemw
Member#: 203905
About 2 years ago our daycare needed new mulch in the playground area. I offered to help with the cost and moving it around. The daycare said no, they had it covered. They found someone that had a wood chipper and he dropped a bunch of "wood chips" off. They were 6" pieces of chewed up wood, splinter ready nightmares. After about a week the daycare asked for help to remove the knarled stuff, and they bought actual mulch from a local landscaping company.
Old 04-14-2021, 12:56 PM   #15321
Badler
Member#: 133597
Welp, front of the ole' ****box is finally done.
Before and after.
Old 04-14-2021, 01:00 PM   #15322
shiplemw
Member#: 203905
Badler - I'm not a huge fan of the black (personal preference) but I think it ties together nicely. Great job.
Are you going to do some small landscaping in front of the concrete walls to help break that up?
Old 04-14-2021, 01:08 PM   #15323
Badler
Member#: 133597
It's actually a dark brown/grey. The plan is to put a tree and more landscaping in the front. I have some blue fescue in there that the rabbits keep eating so they're not big yet. Minimalist. I basically mow the lawn and that's it.
Old 04-14-2021, 01:48 PM   #15324
Salvation27
Member#: 292403
2012 Legacy
Graphite
What about rubber mulch?
Salvation27 is offline   Reply With Quote
Old 04-14-2021, 02:03 PM   #15325
legacy_etu
Member#: 35985
So I started talking to contractors about replacing my windows. First place I spoke with wants to rip out the windows and install new construction windows form the outside. Then replace the outside trim because they'll possibly/probably destroy the old stuff removing it. They were very pricey ( I feel). Their total price was more than twice the cost of the windows. Anyway, to me it seems like this method (new construction) makes things easier for them but more costly for me. Someone set me straight here, why are they not quoting replacement style windows. I asked them but he gave some some salesman BS answer that didn't make sense.
^^ Badler, nice job. Looks nice and clean....and low maintenance.
legacy_etu is offline   Reply With Quote
