Welcome to the North American Subaru Impreza Owners Club Tuesday May 11, 2021
Old 03-27-2003, 06:52 PM   #1
SCOOBER
Member#: 223
1999 Impreza 2.5RS-T
Default Dirty Block & head gasket replacement
I am not sure if this is okay in this forum, but the reason I am at this point is my quest for FI....soooo.....I tried to clean my block off last night with engine cleaner and a stiff bristle brush...3 times...and it still has a dark, grungy appearence to it. Can anyone make a recommendation as to what I should use to clean the aluminum and make it silver again?
Head Gasket Question...what have you used to clean off the old material from the head and block in preparation for the new gaskets? Also, is there an advantage to using studs instead of the factory head bolts?
Doug
SCOOBER is offline   Reply With Quote
Hybrid setup build parts - EJ20 Block & Heads, EJ25 Block, 02 WRX Tranny parts... WRenXhaven Engine/Power/Exhaust 18 07-11-2009 10:46 AM
usdm sti short block with head gaskets sjs41379 Private 'For Sale' Classifieds 8 08-06-2005 10:20 PM
SCAM - WRX Block & Heads, COBB GC8 Intake, RC & WRX Injectors & more!! Free too!! blaznc Private 'For Sale' Classifieds 59 02-19-2005 01:58 AM
head gasket replacement suby53 Normally Aspirated with bolt-on Forced Induction Powertrain 8 12-10-2004 04:33 PM
2000 Legacy Head gasket replaced... 45K spburns74 Legacy Forum 17 01-25-2004 06:21 PM
