Welcome to the North American Subaru Impreza Owners Club Saturday May 8, 2021
Old 12-01-2004, 03:28 PM   #1
suby53
Member#: 59648
97' Legacy Outback
Question head gasket replacement
I have a t04e on my ej18 in my impreza and i think the head gaskets have finally given out. My engine has all the symptoms of a blown head gasket (low coolant, milkshake substance coming out of valve cover breathers, etc.). I'm assuming its from the turbo and that the stock head gasket can't handle the high compression. So I am wondering if anybody knows of some high performance aftermarket head gaskets that will hold better than stock?
suby53 is offline   Reply With Quote
Old 12-01-2004, 07:10 PM   #2
sideways slut
Member#: 21085
2.5 rs-t
copper or cometic
sideways slut is offline   Reply With Quote
Old 12-01-2004, 08:01 PM   #3
suby53
Member#: 59648
97' Legacy Outback
Which is better between the two? And do you know of any venders that sell these?
Old 12-01-2004, 11:06 PM   #4
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
you can get the Cometic directly from them, www.cometic.com
Wedge is offline   Reply With Quote
Old 12-09-2004, 10:41 AM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
Contact Kevyn Kistner at Cometic (440)354-0777. Let him know that Jay from Sourcemotorsports sent you. I can't promise any discounts, but it is possible.
Jay Storm
www.sourcemotorsports.com
Old 12-09-2004, 11:20 AM   #6
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Another thing you can do is get some 2.2L heads. They should be pretty cheap and will also lower your CR to about 8:1 (is that right? anyone). Then you can turn up the boost. Oh and those 2.2 heads as long as they are the 2 port will bolt up to your stock intake and exhaust.
Chad
93 2.2T (with 1.8L intake manifold and
subachad is offline   Reply With Quote
Old 12-09-2004, 01:35 PM   #7
darioc
Member#: 35695
02 RST
98 Outback 92 Wrangler
i notice a tiny bit of a milkshake substance just on my pcv valve. should i be worried? its not on the other two breathers though! theres nothing in my intake, not even oil. i dont see any external leaks from the headgaskets. the coolant does not seem to be low.
darioc is offline   Reply With Quote
Old 12-09-2004, 04:44 PM   #8
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
I wouldn't recommend getting 2.2L heads. It doesn't matter how much boost you run, you can run 30psi, and not make power due to the restriction of airflow from the heads.
Old 12-10-2004, 04:33 PM   #9
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
Custom copper gaskets have been said to not seal as well, and I'm not sure if cometic makes a gasket for 1.8L heads, but people have had good luck with them so I'd go cometic if it's possible. People have also had good luck with boost and the newer generation metal layer subaru gaskets (again, not sure if they have these for 1.8L heads).
j
ilmaestro is offline   Reply With Quote
Results of 1st Time engine pull / head gasket replacement Mike1967 Normally Aspirated Powertrain 12 09-12-2005 09:20 PM
Question for the local mechanically inclined about head gasket replacement crxtls2 New England Impreza Club Forum -- NESIC 11 04-05-2005 08:20 AM
what to get when leaky head gasket replaced at dealer? bigpaulo Service & Maintenance 1 03-08-2005 08:39 AM
2000 Legacy Head gasket replaced... 45K spburns74 Legacy Forum 17 01-25-2004 06:21 PM
Dirty Block & head gasket replacement SCOOBER Normally Aspirated with bolt-on Forced Induction Powertrain 0 03-27-2003 06:52 PM
