Welcome to the North American Subaru Impreza Owners Club Monday May 10, 2021
Old 11-20-2006, 06:07 PM   #126
XWRATED
Member#: 111454
2003 WRX Sedan
WRB, 86' Buick GN 500 HP
I wonder, for the first two fittings that go into the inlet hose (they are both small diameter hoses, I believe one is the map sensor, and the other I am not sure. I wonder if I can tee these two together???
XWRATED is offline   Reply With Quote
Old 11-20-2006, 06:39 PM   #127
XWRATED
Member#: 111454
2003 WRX Sedan
Check the picture here, I want to "T" hoses 3 and 5.. Would that be ok?
Scott
Old 11-21-2006, 02:35 AM   #128
byroll01
Member#: 611
14 E63s AMG
09 ML63 AMG
5 is the return air from your factory boost control solenoid. I don't remember 3 it's been so long. I'm no help anyway for which are the est to T, I'm waiting for an answer as well.
byroll01 is offline   Reply With Quote
Old 11-21-2006, 05:11 PM   #129
XWRATED
Member#: 111454
2003 WRX Sedan
Someone's gotta have the answer to this. The number three hose goes to some round plastic looking "widget" that has another fitting from it to the intake manifold right on the front there.
Scott
Old 11-21-2006, 05:26 PM   #130
XWRATED
Member#: 111454
2003 WRX Sedan
Ok, I just found out that hose 3 is going to the purge control solenoid. Now for the simple question! Can I "T" hose 5 (boost control solenoid) to hose 3 (purge control solenoid) so I have an extra entry point to the inlet hose.
Scott
Old 11-23-2006, 11:17 AM   #131
XWRATED
Member#: 111454
2003 WRX Sedan
I have the perrin inlet as well and I was waiting for the same answer.
If it doesn't come then check valve will be my solution.
where would you mount the check valve?
Old 11-23-2006, 03:09 PM   #132
byroll01
Member#: 611
14 E63s AMG
09 ML63 AMG
here is that check valve kit I was looking at:
http://www.et-performance.com/turbo.html
and another thread discussing these similar questions:
http://forums.nasioc.com/forums/show...ve+check+valve
Old 11-30-2006, 06:30 PM   #133
XWRATED
Member#: 111454
2003 WRX Sedan
Well I used the catch can for the pvc to inlet hose. metal line off the intercooler I just ran to a breather that I picked up from autozone that fit perfect and looks like it belongs underneath the hood. I ran a hose like it would normally run in those plastic clamps and then down around the purge control solenoid I installed the breather. I expect it to do the job for the missing fitting. I read a few people talke about the air from the turbo sucking the pressure from that line, but I figured if any pressure got in there, it would be forced out from the breather. Thats how it is on my turbo buick, and thats how I expect it to be here. We will see how it goes. I'll post a pic when I get a chance. I have extreme confidence that this will work fine.
Old 11-30-2006, 08:56 PM   #134
freddie32001
Member#: 116103
2006 OBP WRX STI
Blouch 2.5 XTR
Here's the kit that I am running. You have probably seen the original version a few pages back. This is the new updated version made of larger ID tubing and 100% high temp silicon. If anyone has any questions, let me know.
freddie32001 is offline   Reply With Quote
Old 12-07-2006, 03:47 PM   #135
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
do you guys think it'd be okay to use 1 line from the intake for both catch cans?
scobaru is offline   Reply With Quote
Old 12-18-2006, 09:44 AM   #136
rt4me
Member#: 82786
2004 WRX
I'm wondering about two things.
First, I've read the inside diameter of the system (hoses and fittings) should be as uniform as possible. A cheapo catch can I have has fittings that are close but the actual size of the hole going into and out of the can gets pretty small. I'm wondering what the downside of this is?
Second is about the medium put inside cans to help condense the various vapors. Any thoughts on using thick fishing line? I've got a lot of it, it won't rust or corrode, I think it would take 1000 years to break down and I'd think a tangled mess of it would work okay for condensation material.
rt4me is offline   Reply With Quote
Old 12-23-2006, 09:58 PM   #137
WRXRgr
Member#: 54942
2004 WRX
Is there any reason you can't use something like aluminum window screen?
WRXRgr is offline   Reply With Quote
Old 01-18-2007, 11:26 AM   #138
exekious
Member#: 73951
2006 M5
I would like to add something about installing a catch can. I just removed my greddy catch can installed by the prior owner and replaced it with a Crawford Air/Oil Separator. I noticed the can was installed completely wrong.
On the STI There are 2 valve cover vents.
Make sure you used the one closer to the AVCS controller (closer to front of the car)! Mine was backwards and caused my catch can to fill up frequently.
exekious is offline   Reply With Quote
Old 01-18-2007, 01:34 PM   #139
rt4me
Member#: 82786
2004 WRX
I don't want to sound like an idiot, but wouldn't you want your catch can to fill up? It's catching things.
Old 01-22-2007, 01:21 AM   #140
Boost4U
Member#: 16459
1998 2.5RS
Would having a catch can like the AVO with 3 ports on it be a better solution than 2 cans? That way you have the line from the PCV and from the Valve cover coming in to the can and a single return to the turbo inlet pipe?
Boost4U is offline   Reply With Quote
Old 01-22-2007, 05:57 PM   #141
Phat04WRX
Member#: 59097
04 WRX
Java Black
after doing a lot of reading. I am still confused as the whether the WRX needs one or two catch cans. I think one, but I'm not sure. Why the heck does the STI need two and a WRX need only one?
Phat04WRX is offline   Reply With Quote
Old 01-22-2007, 09:04 PM   #142
byroll01
Member#: 611
14 E63s AMG
09 ML63 AMG
from what i have gathered, from this thread and others on this subject, ideally any wrx (sti or otherwise) would benefit from 2 cans because the crankcase vents and the PCV are two different systems and ultimately should stay that way. One catch can can be used if you A. use checkvalves in the appropriate lines or B. don't care and figure with one can you are still doing more good than bad.
Old 01-23-2007, 03:23 PM   #143
Phat04WRX
Member#: 59097
04 WRX
Java Black
yeah. that's what i figured. but i thought i saw Uncle Scotty chime in here or maybe some other catch can thread (can't remember, reading toooo much) and he said STI needs two. WRX needs one. Scotty knows what he's talking about when he's being serious. That's where the confusion came from.
EDIT: found it. here it is.
Originally Posted by Uncle Scotty View Post
....ej25x = 2 catch cans
....ej205 = 1 can
Any chance you can clarify doo000ood??
Old 01-23-2007, 07:15 PM   #144
Boost4U
Member#: 16459
1998 2.5RS
Rather than returning a line from the catch can to the inlet pipe....could we not just have a vent to relieve the can and prevent improper airflow direction to the valve covers?? That way we could have the 2 sources entering the can and only need 1 can to do the job?
Old 01-23-2007, 08:29 PM   #145
yoa
Guest
Member#:
Nice info.
Old 01-25-2007, 08:02 AM   #146
mybluesubi
Member#: 53526
1997 Impreza
black
I have an N/A 2.2 and I'm not running a PCV at all. I have the two valve cover breathers and block breather T'd together going through an oil catch can. I've had it this way for about 15k miles and haven't seen any signs of anything bad.
mybluesubi is offline   Reply With Quote
Old 01-25-2007, 12:38 PM   #147
Phat04WRX
Member#: 59097
04 WRX
Java Black
Come on Uncle Scotty clear this up. It'll only take a minute. i'm sure it'll be painless
Old 01-28-2007, 06:45 PM   #148
SIBzzz
Member#: 129888
Liquid Copper
does anyone know where the forum is for the make it your self oil catch can under like 30 bucks. I searched and didnt find it. thanks
SIBzzz is offline   Reply With Quote
Old 03-28-2007, 10:44 PM   #149
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
bump this up for search purposes
BREWPUBEAVER is offline   Reply With Quote
Old 06-02-2007, 11:53 AM   #150
alphakry
Member#: 48239
2006 STI
here's a question that hasn't been covered:
Do Catchcans void your warranty? Esp. if you cut into the stock lines?
alphakry is offline   Reply With Quote
Catch can maybe reduce oil use? leighton1245 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 06-05-2010 06:38 PM
Oil catch can...or catch canS?? BoXinWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-28-2009 05:01 PM
Installed OBX catch can... (another catch can thread) txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-10-2008 01:00 AM
WTT(HR): Greddy Oil Catch Can with Perrin Oil Catch Can scooby_wooby MAIC Private Classifieds 1 03-24-2008 09:01 PM
WTT: Cusco catch can for a perrin catch can sti charles Engine/Power/Exhaust 10 11-29-2007 01:04 AM
