05-01-2012, 10:50 PM | #351 | |
Member#: 56219
Vehicle:2011 WRX STI Limited SPW |
05-02-2012, 12:29 AM | #352 |
Member#: 315291
Vehicle:2012 WRX PBP |
Its better that you stay away from T6. Leaves more for everybody else.
05-02-2012, 01:39 AM | #353 | |
Member#: 56219
05-02-2012, 01:58 AM | #354 | |
Member#: 314815
Vehicle:2007 Wrx White |
05-02-2012, 02:22 AM | #355 |
Member#: 56219
The loyalty over bulldozer oil is impressive. This is really good ****t after all. I admit it.
05-02-2012, 02:22 AM | #356 |
Member#: 56219
05-02-2012, 07:00 AM | #357 |
Member#: 284003
Vehicle:2010 Alpine 135i |
I really dont understand what you have against it based on "marketing"? Its been used. Its been proven time after time after time. What has also been proven is that there are more ****ty 5W30/5W40s on the market that people seem to think, based on price alone, that it will perform better and they are, more often than not, disappointed. Just because the peg wasnt designed for the specific hole doesnt mean it cant fit.
05-02-2012, 11:42 AM | #358 |
Member#: 136314
Vehicle:2014 Grand Cherokee |
Since we're talking oil...
I have 20 qts of Mobil 1 Extended Performace 5w30 down in my basement (leftover from my Xterra) that I will be using up in my new 2012 STI Limited...as to not waste money. Since I'll be changing oil at 3000 mile intervals, and I won't be racing...I'm not worried in the least. I WILL be switching over to the T6 once all my Mobil 1 is gone though. |
05-02-2012, 01:32 PM | #359 | |
Member#: 248581
Vehicle:2015 Impreza Sport Red |
05-02-2012, 03:12 PM | #360 |
Member#: 276300
Vehicle:2015 Ford Mustang GT Oxford White |
whats so magical about this T6 oil anyway. it doesnt even have any zddp in it. brad penn or amsoil pls
05-02-2012, 03:33 PM | #361 | |
Member#: 271383
Vehicle:2012 WRX Sedan WRB |
05-02-2012, 03:52 PM | #362 |
Member#: 276300
lol figures
05-02-2012, 04:04 PM | #363 |
Member#: 284003
Can you really argue with Blackstone labs? TBN still good after 8k miles? Check. Flash point and CST Viscosity after 8k miles still within spec? Check. Theres nothing magical about the oil. Its readily available at almost all WalMarts across the nation and very cost effective at ~$22/gal. Are there "better" oils out there? Probably, but the T6 is easy to find and proven to work well in these engines. We are only "fanboys" because we tried it and it has worked and worked well, and we are only advocating the oil because it works.
05-02-2012, 04:11 PM | #364 |
Member#: 289315
Vehicle:2006 STi "Frosty" |
My car didnt like rottela T6 but loves German castrol 5-30. 06 sti
05-02-2012, 04:31 PM | #365 | |
Member#: 280943
Vehicle:'11 WRX |
Back on topic, thanks for sharing your experience OP. I find it very interesting that the Subaru tech told you to switch to 5W-40 after break-in. There have been reports of some dealerships giving owners crap about using syn 5W-40 (blaming misfires, etc. on the heavier oil) just because the owner's manual states that syn 5W-30 is required . |
05-02-2012, 04:50 PM | #366 |
Member#: 136314
If the Mobil 1 was the regular 5w30 I wouldn't chance it, but it's the Extended Performance 5w30...a little better.
05-02-2012, 04:55 PM | #367 | |
Member#: 271383
05-02-2012, 05:06 PM | #368 |
Member#: 313311
If you want to know about oils, and which work well and which don't, go to www.bobistheoilguy.com. There you will get way better information than you will on this site about what works and what does not.
The problem with discussing oil on a specific car forum is you get "forum favorites" based more on what the frequent posters use, rather than what works. In turn, people who know nothing then convert to that oil because if so-and-so says it's good, then it must be ... then they in-turn post about how great it is .. and so on. On this forum, that oil seems to be the Rotella T6. Bottom line is if your using your car as a daily driver, and changing oil less than every 5k miles, there are many many oils that will work just fine for you. |
05-02-2012, 05:13 PM | #369 |
Member#: 280943
Vehicle:'11 WRX |
05-02-2012, 06:07 PM | #370 | |
Member#: 284003
I just dont understand why people are so adamant to reinvent the wheel here. X, Y, and Z oils are proven to work well and provide lasting protection in these cars, but so many people want to use Q, R, and S because....? I cant find any sort of logic to knowingly use a product that could significantly increase the chances of damaging an ENTIRE engine. Not just pistons/shortblock but turbo and heads... |
05-02-2012, 07:35 PM | #371 |
Member#: 7164
Vehicle:2000 Miata LS Evo Orange Mica (1/644) |
05-02-2012, 09:36 PM | #372 |
Member#: 98000
Vehicle:05 sti e85@420hp |
05-02-2012, 09:46 PM | #373 |
Member#: 289315
05-03-2012, 12:17 AM | #374 | |
Member#: 56219
05-03-2012, 12:23 AM | #375 | |
Member#: 56219
Similar Threads | ||||
2011 STi Sedan 305/368 EFI Tuned | krotondo | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 1 | 09-22-2011 01:46 AM |
***PhatBotti Tuned: E85'ed 2011 STi, 330whp!! Per Gear Data + Tuning Discussed*** | PhatBotti Tuning TKR | Proven Power Bragging | 54 | 06-24-2011 10:58 AM |
2011 STI OTS map vs Pro tune | Jose Gordils | Newbies & FAQs | 6 | 05-09-2011 11:08 AM |
2011 STi V-Limited LIPS IN STOCK! Yeah we got them! | RallySport Direct | Vendor 'General Sale' Forum | 1 | 11-08-2010 03:03 PM |
07 STI Blown Piston or Ring? | 07stilover | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 49 | 01-25-2008 01:24 AM |
