Welcome to the North American Subaru Impreza Owners Club Thursday December 13, 2018
Old 02-15-2018, 11:49 AM   #1
19transam81
Member#: 405335
2011 STi
Plasma Blue
Default Car not bosting last 15 psi, chugs...
Woke up this morning to leave for work and when my car build boost up to 14 pounds it seems normal. However any more boost and it chugs and bounces around 15 psi. Prior to this I was heading 20 PSI and is very slow to accelerate. At the point of chugging air to fuel is around 12.1. Car is a 2005 Saab 92X, catless down pipe, Manual boost controller, stock bypass valve stock intercooler stock airbox, 140,000 miles.
19transam81 is offline   Reply With Quote
Old 02-15-2018, 01:45 PM   #2
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
Did you inspect the MBC?
mrsaturn7085 is offline   Reply With Quote
Old 02-15-2018, 03:28 PM   #3
subaru_gc8
Member#: 29292
2004 WRX wagon
thats what my car did when my coils started to go
Old 02-15-2018, 03:38 PM   #4
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
This. Car is misfiring which leads to the chug and leaner afr because you're not burning the air in the chamber.
Check plug gap first, but if you're over 120k or so, get some NEW oem coil packs.
06rexwagon is offline   Reply With Quote
Old 02-15-2018, 03:38 PM   #5
19transam81
Member#: 405335
2011 STi
Plasma Blue
Can you elaborate on the manual boost controller inspection? i mean it looks fine, its not flopping around. i can data log with rom raider but im not sure what parameters to log, there is so many to pick from and i am very very new to rom raider.
Old 02-15-2018, 04:09 PM   #6
19transam81
Member#: 405335
2011 STi
Plasma Blue
also throwing an evap code p0457 if that means anyhting
Old 02-15-2018, 04:11 PM   #7
06rexwagon
Member#: 114730
[email protected]
it's the coils
Old 02-15-2018, 04:41 PM   #8
19transam81
Member#: 405335
2011 STi
Plasma Blue
might as well do plugs too. what plugs should i go with being stage 2? should i do all the coils or is there a way to find the coil that is ****ed? is this a common issue?
Old 02-15-2018, 04:58 PM   #9
19transam81
Member#: 405335
2011 STi
Plasma Blue
also, wouldnt this throw a code? is it odd that i am only getting the evap code?
Old 02-15-2018, 05:35 PM   #10
subaru_gc8
Member#: 29292
2004 WRX wagon
you know you would think so but from the time it started it took like a year for it to throw a code. I think sometimes unless the count for to misfires hit a certain level it wont throw a code. basically I threw all sorts of parts at it for that year and just got tired of it so i waited, and ended up getting a misfire code in 2 cylinders but it did take a while for the to come up
Old 02-15-2018, 09:02 PM   #11
mrsaturn7085
Member#: 375462
WR Blue
Coils will often throw a misfire code after a while.
Inspect the MBC by removing it and taking it apart maybe? Most of them screw open pretty easily. See if you've got a broken spring or something internally.
Old 02-18-2018, 09:50 AM   #12
19transam81
Member#: 405335
2011 STi
Plasma Blue
Did some data logging and a third gear pull, sent the log from rom raider to my tuner. The misfire codes are turned off on my car because I guess these cars throw ghost misfire codes? Anyway, it’s the cool packs, thanks everyone who helped me get this solved.
Old 02-18-2018, 09:51 AM   #13
19transam81
Member#: 405335
2011 STi
Plasma Blue
Coil packs, not cool packs
Old 02-19-2018, 02:50 AM   #14
CarnacanWRX
Member#: 480035
2003 Impreza WRX
I drive an 03 WRX. When this was happening to you, did it feel like once it hit 14lbs of boost or WOT that you basically let off the gas? Say your WOT and you let off, then WOT again. But you're actually still WOT. is that how yours felt? I feel I have the same issue.
CarnacanWRX is offline   Reply With Quote
Old 02-19-2018, 06:27 PM   #15
subaru_gc8
Member#: 29292
2004 WRX wagon
when mine would happen it felt like really bad misfiring. mine happened at 8lbs BTW and it wouldnt rev past a certain point
Old 02-19-2018, 06:34 PM   #16
CarnacanWRX
Member#: 480035
2003 Impreza WRX
Mine will hit 14lbs in 3rd and 4th like it's supposed too, but once I go WOT it chugs in and out of boost
Old 02-21-2018, 01:39 PM   #17
06rexwagon
Member#: 114730
[email protected]
Did some data logging and a third gear pull, sent the log from rom raider to my tuner. The misfire codes are turned off on my car because I guess these cars throw ghost misfire codes? Anyway, itís the cool packs, thanks everyone who helped me get this solved.
Told ya . Glad you got it worked out.
Old 02-24-2018, 01:47 AM   #18
subaru_gc8
Member#: 29292
2004 WRX wagon
That's kinda scarry if they turned off the misfire codes
