Welcome to the North American Subaru Impreza Owners Club Sunday August 14, 2022
Go Back   NASIOC > NASIOC General > Warranty Issues & SOA Problems
Old 11-25-2021, 08:57 PM   #1
nick d
Member#: 102126
Default 2021 sti excessive oil consumption
hi all, my 2021 STI 15000km has been using about a quart evey 3000 km, and subaru has been doing a oil consumption monitoring. the first 3000 they agree the car used 1 quart, now waiting for the next 3. what will subaru do under warranty, and what should I be looking for? will they replace the engine?
nick d is offline   Reply With Quote
Old 11-25-2021, 09:33 PM   #2
ProjectN64
Member#: 454737
2005 STIpsm
2013BRZswp2017IMPREZAlrp
I think for it to warrant engine replacement it has to be a quart and a half +. I still think that the oil consumption you're dealing with is excessive and you should get a new engine. See what the dealer says, if it's something you don't like then reach out to subaru corporate to voice your displeasure with a new vehicle consuming so much oil. Good luck
ProjectN64 is offline   Reply With Quote
Old 11-26-2021, 07:46 PM   #3
elan26r
Member#: 527528
Impreza WRX STi
How has the engine been used? Lots of high revs? Has the used oil been analyzed for metal content (bearing debris)? STI's do use lots of oil - it's fairly normal. Doubt they will replace the engine without proof.
elan26r is offline   Reply With Quote
Old 11-27-2021, 09:43 AM   #4
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Subaru's definition of excessive oil consumption is 1 quart per 1,000 miles.
If you're concerned about the engine's health, have a compression and leak-down test performed. That should rule out a major engine problem.
Old 11-30-2021, 09:36 PM   #5
timpala11
Member#: 512891
2010 STi/21 Passport
RIP 19 WRX & 16 FXT
OP, my buddy has a 2019 STi with Cobb Stage 3 + EBCS and he doesn't consume any oil. He told me he drives like a granny but also said he's hit redline a few times.
Not to highjack the thread (PM me if you want) but KB, what do you think about 1 quart per 1k on a stock 2010 STi with 62k on it? This is a rough estimate as I haven't set the trip after filling, but I did the plugs and the compression test was good (140-145 psi on all cylinders). Didn't have access to leak down tester when I did the plugs or else I would have. I know I need your kit sooner than later! (bought the car with 60k, one owner and stock )
timpala11 is offline   Reply With Quote
Old 12-01-2021, 06:22 AM   #6
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Check again, making sure to go off the odometer, and make note of exactly how much you're putting in.
1 quart/1K miles is a LOT of oil to consume. At that rate, it has to be going somewhere and leaving a tell. Leak-down would have been nice, but until you get a tester, pull the intercooler and downpipe. It could be a burned up turbo or better yet, a bad PCV valve.
As a general rule of thumb, if you have excessive oil consumption, no AOS on the planet is going to stop it. It may mask the problem, but it will not resolve it.
Old 12-01-2021, 10:08 AM   #7
timpala11
Member#: 512891
RIP 19 WRX & 16 FXT
I'm about to change the oil so I will keep a real tab on it after that. Thanks for the input. Hoping to do the KB oil package soon!
Old 11-27-2021, 10:47 AM   #8
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
I'm surprised to see a quart in 1000 miles is the problem point. For the FB problem, 10 ounces in 1200 miles means short block replacement. I had that done, so it's burned into my head. That's 1/3 the quart in only 200 extra miles.
Old 11-30-2021, 08:59 PM   #9
nick d
Member#: 102126
so did it solve the problem after the short block replace?
Old 12-01-2021, 09:24 AM   #10
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
Yes. Short block at 94k miles. Car now has 150k miles with no oil consumption whatsoever.
Old 12-01-2021, 02:21 AM   #11
340Dustert00
Member#: 527731
If consumption hasn't decreased after the initial break in period, something internally is severely wrong. I have a built EJ20 with 75k miles that uses a quart in 3000 miles or so at 24psi, and a stock EJ20 that uses a quart in 2000 miles because it has 175k miles. Take that anecdotal response with a grain of salt.
340Dustert00 is offline   Reply With Quote
Old 12-06-2021, 02:47 AM   #12
Axshun
Member#: 478146
Subaru corporate was a pleasure to deal with when i encountered the same issue prior to logging 5k miles. If you’ve added aftermarket parts they’ll have you sign an agreement not to do so once they’ve replaced the engine. Definitely get it checked and resolved though.
Axshun is offline   Reply With Quote
Old 12-06-2021, 06:55 AM   #13
ProZach626
Member#: 186084
2018 STI
If you're unmodded call Subaru of America and just get the ball rolling with them if they don't acknowledge a problem. They always get something done.
If you're modded... you might be ****ed. The poster before me was extremely lucky in getting a new motor from one that had been modified.
ProZach626 is offline   Reply With Quote
Old 01-12-2022, 07:56 PM   #14
nick d
Member#: 102126
so after the oil consumtion test the car lost 2.3 lt after 6000 km, they proceeded to do a compression test and a leak down test and both came back normal. what should I be expecting from Subaru? I still think its excessive! no mods and car was driven not aggressively at all! plus I am an aircraft mechanic, and totally looked after the car well.
Old 01-16-2022, 10:24 AM   #15
Notch 8
Member#: 355254
2.43 quarts in 3728 miles.
What did Subaru claim to be an OK amount?
Notch 8 is offline   Reply With Quote
Old 01-18-2022, 08:52 PM   #16
nick d
Member#: 102126
no word back from subaru yest! dealer submitted the results last week
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
