10-05-2010, 06:59 PM | #1 |
Member#: 116512
Vehicle:1999 impreza sport silver |
dash swap info
i know there is a bunch of threads on this subject, but i still cant find exactly what im looking for!
i was wondering if there is a step by step dash swap thread with pics? 02-03 dash swapped into 93-01 gf/gc. i know what needs to be done to swap the dashes, just would like to see a step by step write up! |
10-05-2010, 07:01 PM | #2 |
Member#: 157348
Vehicle:I Thlammed My Penith in the Car Door |
your best bet is to swap dash beams, too.
10-05-2010, 07:28 PM | #3 |
Member#: 116512
ya.....i basicly know what all i need to do. i just really want to see a good write up on this!
i dont know if i should go with cutting the firewall and welding in the right holes for the ac and heater hoses. basicly cut the wrx firewall and paste onto my gf? |
10-05-2010, 07:59 PM | #4 |
Member#: 1305
AKIC
Vehicle:2000 Impreza |
I haven't seen any step by step directions.
I took 2 pictures of the only hard parts of the swap. Use the lower mounting hole towards the rear of the car on both sides of the dash beam as your reference point. Rotate the beam around that hole so that the center support bars going to the tunnel meet up with the GC mounts on the tunnel. You'll need to drill new holes for the other 3 bolts obviously, and the arms that attach to the tunnel need to be trimmed a bit because they're to long. This is the left side: The other hard part was adding HVAC. You'll need to remove some sound deadening from the tunnel and maybe pound on it a little bit in one spot to make room. Mounting needs some modification but is pretty straight forward, I only used the upper mounts, I was going to do something with the lower mount but it was a tight enough fit in there without it. The tricky part is getting the right holes through the firewall. I've seen it welded before, which I guess is probably the best answer. I think my method will be plenty strong though, and I could do it myself in my garage which was a plus. I cut out the sections of the firewall from the wrecked GD that I needed. Only needed to do some minor reshaping to the A/C and heat pieces with a hammer to make them an exact fit. Then cut holes into the GC firewall in the right places. I used panel adhesive and some bolts for added reinforcement. Sorry, I didn't take any more pictures but those are the 2 tricky parts IMO. There are more modifications needed to parts in other portions of the install but they're all pretty straight forward. If you can handle these two things then you shouldn't have a problem with the rest of it. Also, finished product if you use the 2 holes I mentioned as your reference to rotate the beam on. You'll end up with a gap like this on both sides and the forward portion of the dash sitting flush against the windshield all the way across. Last edited by AKGC8; 10-05-2010 at 08:06 PM. |
10-06-2010, 05:37 PM | #5 |
Member#: 116512
those are some good pics.....now i just need to find a wrecked wrx for cheap and swap everything
Similar Threads | ||||
COMPLETE 05 sti dash swap, EVERYTHING hvac,radio,dash,centerconsol+++ | Ctracer911 | Interior/Dressup/Audio & Security | 15 | 10-22-2009 07:22 AM |
(OH) 02 WRX Partout (5spd Swap parts, Transmission, Dash Swap etc) | STinkyPinky | Complete Car Part-Out | 34 | 10-03-2009 02:53 PM |
dash swap and motor swap questions | aka_tur | Subaru Conversions | 6 | 02-27-2007 05:21 PM |
99-01 RS dash swap into 97L | Billy | Subaru Conversions | 8 | 11-20-2003 07:09 PM |
Center dash pod info needed... | 8Complex | General Forum Archive | 13 | 02-27-2001 08:47 PM |
