Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
Old 03-13-2018, 08:57 AM   #1
Subydude81
Member#: 118266
2007 Lexus IS250 RWD
6MT
Default What gasket needed for Q300 exhaust
I recently traded in my 16 wrx for an 18 sti and will be using my q300 but I was in such a rush to remove the exhaust I don't know what kind of gasket goes between the stock downpipe and q300 midpipe. Any help me out.
Subydude81 is offline   Reply With Quote
Old 03-13-2018, 10:48 AM   #2
shadowsports
Member#: 446364
'17 STI LMT '08 LGT
DGM / QSM
I have a '17.. but if the DP is stock, the kit comes with everything you will need. Remove the donut gasket from the stock DP.
shadowsports is offline   Reply With Quote
Old 03-13-2018, 11:07 AM   #3
Subydude81
Member#: 118266
6MT
Yea but I'm reusing the exhaust and the gasket crumbled to pieces.
Old 03-17-2018, 12:54 PM   #4
shadowsports
Member#: 446364
'17 STI LMT '08 LGT
DGM / QSM
The gasket is standard. Use a pencil and piece of paper to trace the flange diameter and holes. Go to any auto parts store. It will cost you $3-5 dollars. Or you can spend a little more and get a metal exhaust gasket. Either will work. You might need new bolts and nuts if this is second hand. Buy high quality grade8+ steel bolts so they won't snap.
