Welcome to the North American Subaru Impreza Owners Club Wednesday April 25, 2018
Old 03-17-2018, 12:47 PM   #1
Bakerboy15
Member#: 483145
2011 STi Hatch
Red
Default Up Pipe Install Disaster
Yesterday i took my car to a shop to have the Grimspeed up pipe replaced because it rusted through the flex and had a huge exhaust leak.. I bought the exact same pipe ( 2 bolt with 38mm external waste gate) The shop i took it to worked on it for 7-8 hours. They said that it was not matching up well with my current set up which is an Invidia down pipe and Tial wastegate. They say the car had a few seized bolts and had to be replaced. The O2Sensor would not screw back in tight so i assume it is barely in there. Honestly i'm not sure what to think about the install it seems to be ok, but just needed to put this out there in hopes to receive some positive feedback or things i should watch for now that its over.
Bakerboy15 is offline   Reply With Quote
Old 03-17-2018, 01:37 PM   #2
MrWRX17
Member#: 458676
2017 WRX
It sounds like they got the pipe itself installed. I would check all hardware is installed and tight. Check and make sure the o2 sensor is fully seated against the washer. If the 02 sensors are stripped or too corroded they may not tighten and will need to be replaced. Be careful, if they stripped the sensor it may have stripped your uppipe.
Give it a check and fix it needed, hopefully they didnt strip it.
MrWRX17 is offline   Reply With Quote
Old 03-17-2018, 01:49 PM   #3
its byron
Member#: 345847
08 WRX STI
Install yourself ftw
its byron is offline   Reply With Quote
Old 03-19-2018, 11:24 AM   #4
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
Hard to tell exactly what went wrong. A little anti-seize always works well when installing an O2 sensor. While the fit might be a little off, it does eventually bolt back up no problem. If you had the same DP and EWG prior to the swap, then the only hiccup could be from the seized bolts probably. But the Uppipe bolts to the Exhaust Manifold and the Turbo, not sure how the DP came into question.
Do you know if they used new gaskets? If it has been awhile, it is always best to replace the exhaust gaskets for each connection broken up.
kenliu84 is offline   Reply With Quote
Old 03-19-2018, 12:15 PM   #5
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
I never want to see a thread title with our name and "install disaster." However, it looks as if there wasn't a problem with the pipe itself, but rather the installation. An external wastegate uppipe install on a car with non-seized hardware takes me around an hour to two hours from start to finish. I could see that time increasing when they start having problems with studs or bolts, especially ones at the turbo. Breaking a stud at the turbo means the turbo is coming out, which sometimes happens and will add a lot of time to an install.
As far as the uppipe not matching up well with the downpipe and wastegate, this is a harder pill to swallow. The 5 bolt flange of the uppipe bolts to the inlet of the turbine, which has a location that is dictated by the two mounts bolted to the engine. If these mounts don't move, then the turbo doesn't move. If the turbo doesn't move, the installation of the downpipe is completely unaffected. The wastegate fitment is the least constrained and shouldnt be affected by anything on the install as the is clearance between the downpipe and wastegate.
It kind of just sounds like they were having a hard time as opposed to there being a disaster with our uppipe. If this is not the case please let me know and I can help you out.
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
Old 03-19-2018, 01:02 PM   #6
Bakerboy15
Member#: 483145
2011 STi Hatch
Red
Chase
Engineering
I agree this wasn't on Grimmspeed. I didn't mean for it to look like i was calling out Grimmspeed for my mess of a install. The Grimmspeed pipe is a quality product. I ran the car this weekend and it seems like its put back together well. I still need to stick my head under the car to check all bolts.
I was just a little concerned after the install because 8 hours just seems insane... seized bolts or not.
Old 03-23-2018, 04:38 PM   #7
subaru_gc8
Member#: 29292
2004 WRX wagon
ALso u would make sure that there is no added stress on the flex pipe or that will become the breaking point due to stress.
subaru_gc8 is offline   Reply With Quote
