Welcome to the North American Subaru Impreza Owners Club Tuesday November 20, 2018
Old 07-19-2008, 01:24 AM   #1
OMG_WTF
Member#: 154470
2007 WRX STi
Default Logger will not connect to ECU....?
when i open the logger, there is a small error message on the bottom stating something to the effect of "cannot init with ECU, make sure ignition on..."
i successfully connected and retrieved the ROM already with ECU flash...
anyone have any ideas? should i try and reinstall ROMRaider?
thanks very much in advance for any/all help
OMG_WTF is offline   Reply With Quote
Old 07-19-2008, 10:09 PM   #2
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
If you have a choice of COM3 and COM4, for example, and are using COM3, change to the other COM.
Jerry Xu is offline   Reply With Quote
Old 07-20-2008, 03:36 AM   #3
OMG_WTF
Member#: 154470
2007 WRX STi
hello.. i was able to get it to work after deleting and reinstalling ROMRaider.. thanks for the help
Access port not connecting to ecu on boost 2.5ReallySexy AccessPort 39 02-17-2018 11:59 AM
Can not connect to ECU....have check engine light Paul Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 05-27-2010 11:00 AM
ECUFlash Will Not Connect to Car STI 2 NV Open Source Reflashes 11 01-03-2010 02:30 PM
problems connecting to ecu with green connectors and jumper connected claudefrog Open Source Reflashes 3 05-15-2008 12:58 PM
obd-2 scan tool will not connect MTREX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-04-2001 01:05 AM
