Go Back   NASIOC > NASIOC Archives > NASIOC Archives > General Forum Archive
Old 07-30-2000, 05:19 PM   #1
Don Grubbs
Member#: 1373
Post Solo II Sway Bar?
I remember seeing awhile back a website with a sway bar for use in Solo II. I can't find it now. Was this misinformation? Does anyone know what website it was? I don't remember any specifics about it.
Don Grubbs is offline
Old 07-30-2000, 08:30 PM   #2
Eric
Member#: 48
1999 Impretza 2.5
Post
Call rallispec or email them off their website www.rallispec.com
They have the full selection of Whiteline adjustable swaybars. And Im sure they can get you a front sway bar if you wanted to stay in stock class. Rear swaybars are not legal in stock class, only front ones. Of course you could get a rear and run STS. Maybe a 2K Solo2 rule book from www.scca.org would be a good investment too.
Eric
Silver 99 RS
Eric is offline
Old 07-31-2000, 08:25 PM   #3
gronemeyer
Member#: 645
1995 Glacier White
Impreza L Sport Wagon AWD
Post
Rear swaybars are legal in stock class, but only the factory original stock swaybar and only if it was available on that particular model, that particular model year. No updating/backdating allowed.
gronemeyer is offline
Old 07-31-2000, 08:44 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I thought updating/backdating was allowed for all classes.... or is it just allowed for STS? Not that I've ever run (or ever will) a stock class. Those people are way too fast.
8Complex is offline
Old 08-01-2000, 06:27 AM   #5
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
No update/backdate in stock class. Get a rulebook! Or read 'em online.
ColinL is offline
Old 08-01-2000, 10:25 AM   #6
nativo
Member#: 157
1998 JDM STIv8 6sp
Rally Blue Pearl
Post
For all of you who demand a GREAT rear sway bar, SPO Motorsports just released their new adjustable rear sway bar. It is made out of a much stronger material than the previous one. We have tested and we must say that it is a must buy, at the same time USE WITH CAUTION as this bar when set in it's strongest position it will break the rear end lose in a hurry if you are not an experience driver.
You will find your self going through turns much faster than you were used to. And finally those understeering problems are gone!!!!
It is our feeling that this is the bar to get since it allows you to learn your way from unexperienced to a much experienced driver. Why buy just a bar and then the links so you'll have to get the brackets later anyway.
This bar is an assembly and has been redesigned so it fits perfect. Ther is no clearing issues and it fits like a glove.
This is what Miguel Alcrudo from Auto Plaza Racing Team in a letter to SPO Motorsports had to say:
"This swaybar fitted perfectly even better than the previous 21mm swaybar that we bought from you, it has a perfect clearence all over the bar".
"In terms of performance we tried it on the STRONGEST POINT. The car improved dramaticly on performance, you could easely notice the difference on sharpness and how does it turn quickly on any kind of
turns."
"My point of view is that i liked it pretty much, no matter that your running at a point with no margin for errors."
"I really have to thank you for all your help and for the next race we will be much better".
They are available now through SPO Motorsports.
Thanks,
Efrain N. Alers
Nativo Performance
nativo is offline
Old 08-01-2000, 10:43 AM   #7
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
What is the thickness of this new adjustable bar? 21mm?
ColinL is offline
Old 08-01-2000, 07:57 PM   #8
Andre Vandenberg
Member#: 501
1998 2.? RS Turbo ;)
RBP
Post
I hate to post a negative post here but flame suit is on.
You CAN get all the oversteer you want from the stock bar with AGX's ONLY aa well as toe and camber settings. I too did not believe it, until I spent a day in Chris F's car at the Autox. His car throttle steer a LOT easier than mine did with a 20mm bar in the rear. The only diferance between our cars as far as suspention goes is the 20 mm bar in the back and the toe and camber settings....
just my2c...
Andre
Andre Vandenberg is offline
Old 08-02-2000, 04:55 AM   #9
Jimmer
Member#: 313
98 Impreza OBS
Green
Post
I did change my original rear sway bar for a 18 mm one. I just add Whiteline links to the rear sway and front. That gives you a faster control with the direction... Suggest you to do that mods.. before changing your suspension.. You will see a big difference with that. But you will have to change to STS Class..
The new Moffa aluminium links could be also a good choice. Check in the Ads bulletin board.
Jim
Jimmer is offline
Old 08-03-2000, 12:16 AM   #10
gronemeyer
Member#: 645
1995 Glacier White
Cool
8Complex, I caught your comment about stock class drivers being too fast. Are you serious or just talking "smack?"
HTML code is On
FS : 04 STi OEM Coilovers and Sway Bars suby300 VIC Private Classifieds 5 07-18-2010 10:15 PM
FS: Whiteline 22mm Adjust. Rear Sway Bar *CHEAP* SubaruCrazy Suspension/Brakes/Handling 11 06-11-2010 12:58 PM
FS: adj. rear sway bar, strut tower bars, cusco lower arm bar II, kartboy endlinks SilverSubaab Suspension/Brakes/Handling 22 03-01-2007 06:43 PM
F/S: Brand new Cusco Sturt bar, Sway bar, Lower Bar Type II for 02-up Impreza WRX STi JunGdb Private 'For Sale' Classifieds 79 06-28-2006 12:24 AM
Carolina Motorsports Solo I & Solo II Tim K. South East Region Forum 19 08-17-2001 12:47 PM
