Welcome to the North American Subaru Impreza Owners Club Thursday May 13, 2021
Old 10-18-2019, 11:45 AM   #1
Martin4482.rm
Member#: 507519
Default Car wont build boost
Hey guys subie newbie here I bought an 04 blob eye with this issue and cant sort it out.
Ok so car runs completely fine pre boost as soon as it gets into boost the car falls on its face and spit out black smoke it will hit about 3psi then shutters bad if I stay in the gas it will build to abput 7psi tons of work done recently plugs ngk copper gapped at .30,coilpacks, fuel pressure regulator, new turbo inlet, used td04, new downstream 02, new fuel filter,
Mods list
Perrin uppipe
Cobb downpipe
AEM intake
Cobb ap v3
Cheap catback
Aftermarket radiator
Aftermarket turboinlet
Tein lowering springs
All new grimspeed couplers
Grimspeed y pipe <back of intercooler>
I'm really stumped on this any information is greatly appreciated thanks in advance
Martin4482.rm is offline   Reply With Quote
Old 10-18-2019, 01:14 PM   #2
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Check exhaust parts. Uppipe could be cracked. Turbo could be toast.
hybrid gti 2 is offline   Reply With Quote
Old 10-18-2019, 03:28 PM   #3
Martin4482.rm
Member#: 507519
Swaped a used turbo on same issues
Old 11-23-2019, 09:09 PM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
take the wastegate vaccum line off and see if it boosts. if it does, its your ebcs or something in that line, if it doesnt, than its mechanical and there is a leak somewhere. also did you change all the coil packs> did you use oem or aftermarket?
Old 11-24-2019, 08:45 PM   #5
Shik
Member#: 132
05 WRX, 15 WRX 6mt
'02 WRX- ShinjiTuned
That would be high on the "check this" list, especially as the weather begins to get colder.
Shik is offline   Reply With Quote
Old 10-18-2019, 03:44 PM   #6
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
But is the turbo spinning and have little work no play, when you installed it ?
Old 10-18-2019, 04:01 PM   #7
Martin4482.rm
Member#: 507519
Yes it was in good working condition zero shaftplay
Old 10-19-2019, 01:08 AM   #8
subaru_gc8
Member#: 29292
2004 WRX wagon
take the wastegate vacuum line off and see if it boosts okay, if it does, then you problemn is the ebcs.. make sure you dont over boost
Old 10-19-2019, 08:18 AM   #9
Martin4482.rm
Member#: 507519
I'll give that a shot and let you know thanks
Old 10-19-2019, 08:14 PM   #10
Martin4482.rm
Member#: 507519
Took vac line off wastegate gate same thing
Old 11-29-2019, 05:22 PM   #11
subaru_gc8
Member#: 29292
2004 WRX wagon
see if you have a exhaust leak somewhere. look for black soot on the pipe. also do a boost pressure test on your system.
Old 10-19-2019, 08:30 PM   #12
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Get a OEM replacement unless your going to do a tune with a 3 port. As the 3 post is not safe to boost on until they are tuned. I might have an OEM for an 02. Realize they are different for different years. The plug is different.
Old 11-23-2019, 05:55 PM   #13
00_imprezaoutback
Member#: 452713
02 Impreza WRX
Grey
Could be wastegate. When I got my 02 I couldn’t boost more then 5psi and it would fall on its face at 4500rpm put a new turbo on and the issue was gone
00_imprezaoutback is offline   Reply With Quote
Old 12-03-2019, 11:55 AM   #14
CarmMontana
Member#: 507853
having the same issue, patiently waiting for some more ideas! Good luck
CarmMontana is offline   Reply With Quote
