Tire & Wheel Forum sponsored by The Tire Rack |
05-02-2010, 10:27 PM | #1 |
Member#: 185492
RMIC
Vehicle:2005 STi OBP FR 3071 twinscroll |
fitment issues 2009 STi bbs on 2005 STi?
Im thinking about picking up a set of the 2009 BBS 18x8-8.5? +55 offset? correct me if im wrong please, wheels that are on the new STi. Tryed to find the answers im lookin for but havnt been able too. What all is needed to fit these wheels on a GD body STi? Fenders? Spacers? ....also im on k&w coilovers..if that helps.
05-02-2010, 11:14 PM | #2 |
Member#: 177401
Vehicle:2015 STi White |
they fit fine, no work needed. The offset is high if you want to run wide tires but they're great with 225/40R18 or 235/40R18
05-03-2010, 02:43 AM | #3 |
Member#: 31062
Vehicle:2012 Prius |
still will not fit...need 10 mm spacers in the back to clear the struts.
Either that or throw on 25mm bolt on spacers all around for a safe and reasonably better way to make them fit. 25mm spacers don't require stud removal or trimming of the stock studs. FYI...I have a full set of 25mm spacers for sale...=) kics 25mm bolt on spacers used for 3 days...haha. |
05-03-2010, 03:35 PM | #4 | |
Member#: 56400
SCIC
Vehicle:2004 Subaru STi-SOLD custom roofrack brackets! |
05-03-2010, 04:23 PM | #5 | |
Member#: 31062
Yes that will work
05-03-2010, 04:32 PM | #6 | |
Member#: 177401
This is bad information. They fit without spacers. 18x8.5" +55 clears the strut.
05-03-2010, 04:37 PM | #7 | |
Member#: 31062
They do not fit KW coilovers as the OP stated he has. They do fit with stock struts, but the 2nd person asked for a 5x100…so you need to get the hub conversion spacers. Read before responding please…. Kics makes a 15mm hub conversion spacer...and Ichiban makes a 25mm conversion spacer. |
05-03-2010, 04:42 PM | #8 |
Member#: 56400
SCIC
Yea there are a number of different manufacturers for the wheel spacer/hub adapters out there. I believe 15mm is the smallest they make. I'd love to do this one day, but it is a lot of money to drop at one time to find out they dont work. Good info in this thread nonetheless.
05-03-2010, 04:44 PM | #9 |
Member#: 177401
15mm hub conversion spacers involve cutting the stock bolts.
Sorry if K&W coilovers are so much wider than stock struts. |
05-03-2010, 04:45 PM | #10 |
Member#: 56400
SCIC
05-03-2010, 05:56 PM | #11 |
Member#: 31062
05-10-2010, 03:53 PM | #12 |
Member#: 183992
Vehicle:16 Mini Cooper S |
OP,
I just picked up a set of the 08 STI BBS in the size you mentioned and stuck them on the wife's 07 STI. They fit and DO NOT touch on stock suspension. At full lock over uneven road, they slightly rub, but other than when I was doing a u-turn after putting them on to see if they rubbed, she's had no rubbing issuses since. THis is with the 245/40 Sport Cups that they came with. They look really really nice as well. |
05-10-2010, 04:02 PM | #13 | |
Member#: 56400
SCIC
05-10-2010, 04:23 PM | #14 | ||
Member#: 207826
Vehicle:85k 2002 WRX Correct Fitment Crew #034 |
05-11-2010, 04:46 PM | #15 |
Member#: 183992
08 STI BBS on 07 STI.
It's the wife's car, so I got no say on tires or anything. We found these fairly cheap, and she didn't want different tires or anything. She's a cheapass.
They look really good though, and fit well. Enjoy! Even the wife was pleased with how the pictures came out. I had to DRAG her kicking and screaming to go out and take these, but she was pleased when she got there! |
05-11-2010, 04:49 PM | #16 |
Member#: 56400
SCIC
^wow that does look sweet!
05-11-2010, 08:41 PM | #17 | |
Member#: 240161
Vehicle:2002 wrx wagon R.I.P 87 bmw e30, 2013 BRZ |
05-10-2010, 04:21 PM | #18 |
Member#: 177401
I would argue they only rub at all because the tire is too tall. if you got a reasonable tire height instead of using the stock 08 STi tires, you'd have zero issues.
And the k&w coils must be pretty wide to have clearance issues with 8.5" of width at +55. That's only 8mm closer than the stock wheel even ignoring the tire. 235/45R17 is a common tire choice for the factory STi wheels which is 5mm wider and a little taller. I am surprised somebody makes a set that thick. |
05-12-2010, 08:17 PM | #19 |
Member#: 238875
Vehicle:05 sti aspen |
+1 nice pix
05-13-2010, 01:50 AM | #20 |
Member#: 31062
stock STI shocks along with WRX shocks for that matter will allow the 08-10 STI BBS wheels to fit. It just doesn't fit with the KW coilovers.
05-14-2010, 04:30 PM | #21 |
Member#: 183992
Yeah, I love New Cut Road. And a few out near BWI.
Thanks for the feedback. It was a cost-effective way for the wife to "spruce up" the looks of her car. I really like how it turned out. |
Similar Threads | ||||
White STi BBs on UGM STi....... | gregbenoit | Member's Car Gallery | 26 | 07-11-2008 01:56 AM |
2005 sti bbs on 2004 wrx? | Bogus83 | Tire & Wheel | 2 | 10-23-2006 11:11 AM |
any fitment issues with 35mm offset on 05's? | VTSubieRS | Tire & Wheel | 1 | 05-17-2006 10:21 AM |
5 bbs rims-2005 sti-4 sale | tvblue22 | Private 'For Sale' Classifieds | 3 | 02-27-2006 11:55 PM |
