#26 | |
Member#: 297799
South East
Vehicle:2003 WRX EJ207 version 8 |
![]() Quote:
My long-term plan is to get Ground Control Caster/Camber plates so I can dial in the suspension as much as possible, however, I need coilovers first. I am currently on STi struts with RCE yellows. I've been playing with the preload adjustment on the rack (what a pita to do on the car) and if I used the recommended torque settings (which is like 4 ft-lbs) the steering is way heavier and sticks even more. Too little preload and the rack knocks, but seems to return to center easier. I'll keep playing with the settings to see if I can get better results. Link to steering preload... https://bobistheoilguy.com/forums/th...ad-work.43677/
#27 |
Member#: 297799
South East
![]() So, I did the diode mod by buying a pretty expensive mini fuse from Australia to bump my voltage up to 14.6 (from 14.2). It seems to have worked. I haven't noticed any drops in power assist, at least not yet.
Link to the thread about the diode mod. https://forums.nasioc.com/forums/sho...1602651&page=7 Links to the fuse. https://www.hkbelect.com/product/235...mpatible-2012/ https://www.ebay.com/itm/322650712885 |
#28 |
Member#: 297799
South East
![]() Update.
I've been going in to work on Fridays and every time I go to reverse into my parking spot the assist drops off a cliff. It's weird because that's the only place it consistently drops off. So, I ordered a BRZ EPAS adjustable controller from the guy in Portugal. It arrived in like two days, which is pretty awesome. I just installed it and it definitely increased the level of assist. I can turn these 265 summers with one finger on the max setting. I am currently running it on the middle setting. On the test drive, I noticed that the steering will return to center now which is a welcome change. I think I need to beef up my motor mount bracket now that it producing a decent level of assist. I can see the motor flexing a bit when I turn the wheel. I think I might have some binding in the steering linkage going on too so I need to investigate that as well. |
#29 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
![]() Thanks for the follow up! This is definitely a project of interest to me.
#30 |
Member#: 297799
South East
![]() Update.
I was having serious issues with the EPAS dying on me and going into full manual mode. This was somewhat manageable with the 5MT, but with the 6MT (swapped at the end of 2021) the steering is ridiculously heavy in zero assist mode. Sometimes, restarting the car will fix it, but even that stopped working. I plan to wire in a switch to manually reset the controller at some point. After some investigation, I found a pinched control signal wire that was grounding out. I don't remember when, but I relocated the control module underneath the driver's seat. I extended the harness and bolted the module to a piece of plywood for proof of concept and kind of forgot about it as it worked well enough. I think some of the wiring harness was sticking out past the seat and got pinched by a 12-pack or something after a grocery store run. Whenever I hit a big bump, the signal wire would ground out and the module eventually shut down, I assume, to protect itself. I eventually found the wire and fixed it, but I also bought a newer control module just in case. FYI, some of the older ones have issues shutting down. I would look for modules from 2017 and up. The new module came with a mounting bracket that I modified to mount under the seat (pardon the self tappers). Part of me wonders if the control module has an internal ground that uses the bracket to ground out to the chassis. I haven't driven the car a ton since, but most of my inconsistency issues seem to be gone. I have immediate power steering on cold starts now. There was a delay before. I am a little bit surprised but so far, it is working better than ever. Anyhoo, here is my current setup under the driver's seat. I had some old ABS wiring laying around that I used to extend the smaller gauge wires. ![]() I am going to redo the harnesses. I am sourcing wiring and connectors now. I want to make this harness modular so I can pull the motor out without needing to pull the entire harness out as well. ![]() |
#31 | |
Member#: 170439
Vehicle:I <3 Lamp |
![]() Quote:
If anyone wants that controller to adjust steering feel on the fly its no longer on ebay (not with this link anyways). The Portugal guys website who makes this is... https://www.brunosteering.com/produc...ller-kit-epas/ He also has a GPS based kit. |
#32 | |
Member#: 297799
South East
![]() Another update.
I bought another EPS control module as I thought my earlier replacement was broken. It wouldn't shut off after turning the car off and I was afraid it would drain my battery. Or worse, it had a stuck relay and would potentially catch fire. However, the new module did the same thing. Eventually, I figured out that the newer modules will keep the P/S system running for a little while after key-off before killing power. My guess is this delay is a feature and not a bug. After about 5 mins, you can hear the relay click off. I decided to redo some of my wiring as it was more of a proof of concept setup. So far, I haven't had any cutout issues!! I also removed the Bruno controller and run the setup on minimum power assist. After driving this car without any power steering at all, the default assist feels like plenty. ![]() ![]() I am still working on building a new harnesses with brand new wires. I found the pins for the control signal connectors on Digikey. They aren't 100% the same as the OEM pins have a gold looking plating on the end but those aren't available. However, they fit and lock into the stock connector. https://www.digikey.com/en/products/...311-7/15902834 I will be using Deutsch connectors on the other side. Wiring is 22AWG if you are curious. I will probably relocate the control module in the trunk. Right now it is under driver's seat and I am worried that someone will kick the harness and I will lose power steering again. I rarely have passengers in the back, but it is bound to happen at some point. Quote:
#33 |
Member#: 540471
![]() Hello I am working on a prodject and am consider using an electric power steering.
and think about the corolla e120 unit that u are us in ur epas thred. the requerd relays what are these, and does the unit work in failsafe mode. there is a steering angel sensor on later units is it required? and last what pin should i feed power to make it work in safe mode. thank u for reading hope u can awnser my questions, have a good day |
#34 |
Member#: 297799
South East
![]() Almost a year update.
No issues whatsoever since my last update. I am honestly a little surprised I fixed it. lol. I am still running the system with the default power assist, although I wouldn't mind a little less assist. If I pick up a controller, I will probably get the AGT controller. I like that they have a screen readout now. https://www.agtengineering.com.au/pr...ering-emulator |
#35 |
Member#: 15822
Vehicle:1999 DIY 22b 74F |
![]() so it takes factory ABS signal and converts it to canbus the EPS module understands... pretty cool
