03-22-2021, 09:17 PM | #1 |
Member Sales Rating: (2)
Member#: 123677
Vehicle:2006 Legacy spec.B Titanium |
MD Baltimore, MD: 2006 Subaru Legacy GT Spec.B, 219,908mi - SOLD
2006 Subaru Legacy GT Spec.B # 375 of 500 - Pending Contract
Location: Baltimore, MD Asking Price: $5,000 OBO Mileage: 219,908 Transmission: 5 speed manual Color: Titanium Silver Title: Clear Title on hand Lien: No Liens VIN: (4S3BL676066207202) Original Owner: [email protected] All service records physically in hand and/or tracked online at mysubuaru.com The chassis has 219,908 miles. Engine has 80,000 miles. It was completely rebuilt at 130,000 (October 2011), starting with a replacement STI block and new everything. More notes below car description. Engine - Rebuilt at 130,000 in October 2011 by IAG Performance NOTE: After routine maintenance in March 2021, IAG Performance (the engine builder) has informed me there is irregular compression in Cylinders 1 & 3. Car can be daily driven but is not advisable for hard pulls until the engine is addressed. DeatschWerks Side Feed 740cc Injectors Walbro 255lp ACL Race Rod Bearing Set, Main Bearing Set ARP Head Stud Kit FHI 2.5L Crankshaft, FHI Intake manifold to cylinder head 08+ WRX" Oil Cooler (STI 08-10) Oil Pan, Oil Pump (11mm), Engine Gasket Kit, Oil Feed Line fitting with Filter Raised Head, 3 Piece PCV Valve Kit L-shaped Crank Case Breather hose, Case Half Set with Case Bolts 07 STI, Killer B Killer B Motorsport Ultimate Oil Pickup Manley 99.5 Platinum Series STI Pistons and Connecting Rods Subaru Timing Belt roller/Tensioner kit WRX/STI ACT clutch kit heavy duty modified street WRX Crawford Performance AOS v2 Koyo Radiator - Hyper V-Series NGK Iridium IX 2309 1-step Colder spark plugs Induction and Exhaust - 368 whp, 350 wTorque Blouch TD06H-20G-XT Prodrive 3-port boost control solenoid Prosport Turbo heat shield blanket IAG BigMAF intake Perrin FMIC Perrin Turbo inlet pipe Invidia Q300 Quad Tip Catback Exhaust Invidia Legacy GT Catted Downpipe Tial44mm External Wastegate, Prosport GTSpec GEN II style unequal headers wrapped with Silicon spray, TGV Deletes EBCS 3-Port BCS Boost control Brakes: StopTech 332 mm (13.2"), 2-Piece Rotor Big Brake Kit, ST-40 4-pot Front Brake Calipers Rear: DBA 4000 Rear Rotors Perrin Master Cylinder Brace Drivetrain Upgrades: STi L/R engine Mounts STi Pitch Mount STi Transmission Mount Suspension: RaceComp Engineering Tarmac 1 Coilovers and Camber Tophats Cusco Front Strut Tower Cusco 23mm Front Sway Bar Cusco 21mm Rear Sway Whiteline Front Roll-Center Perrin PSRS (Positive Steering Response) Caster Kit Perrin Lower Control Arms Interior: Cobb Accessport v3 All original Spec.B Brick Red Interior Phone radio connection Defi 52mm Red Racer Boost Gauge (White Needle) Defi 52mm Red Racer 140 PSI Pressure Gauge (White Needle) 3-point, 2.5" Driver Harness restraint Airbag recall completed Tinted Windows Wheels Enkei Raijin Gun Metal 18 x 8 Goodyear Eagle GT 225x40 Miscellaneous: Tinted Rear Lights Apexcone Slimline Premium Race HID Kit (6000K, 55 watts) Twin Supertone Horns H3 Yellow Headlight Replacement Bulb The exterior is not perfect, but you will be hard pressed to see a better maintained 2006 model year anything. It's professionally full detailed twice a year since I purchased it (at Pro Wash in Columbia since 2011). There are edge and bumper rock chips and scratches but nothing significant. Extras coming with the car for Race Day - not selling separately: Brakes Race Pads: only 2 Track days on each: ***8226; Carbotech XP10 (Fr/Rr) ***8226; Pagid RS19 Yellow (Rr) ***8226; StopTech Centric Posi Quiet Ceramic pads - Currently on car for Street ***8226; Dual and Quad Brake piston compression tool - Similar spec on Amazon ***8226; Pittsburgh 1.5 Ton Aluminum floor race jack ***8226; Big Red Jack stands ***8226; Tomioka racingCar Ramps - similar spec on Amazon: Toolbox containing: ***8226; Tire Gauge, Fender blanket ***8226; Heat Sleeve ***8226; Goodyear Rechargeable Impact Wrench 1/2'' Sq. Drive, 20-150ft. lbs. with multiple sockets ***8226; Torque Wrench w/Storage Case I am the original owner, purchasing it new in November 2005. I am reluctantly selling it. It has not been daily driven for last 5 years. I had to get another car for the family, though I drive whenever I go out by myself. I'm selling because I am no longer be able to track the car. That is the reason to include the additional race day items. I've maintained the car meticulously with oil changes every 3k miles with all paperwork since I purchased the car new in November 2005. IAG Performance built the engine in 2011 and have exclusively servicing the car since 2010. Only performance fluids like Motul Excess 5w-40 have served the car since. Original Interior: Extras coming with the car for Race Day - not selling separately: ]
03-31-2021, 05:42 PM | #3 |
Member#: 123677
Per request, these are the numbers provided me from IAG Performance:
Comp test: Cold/Slow cranking 1: 130 psi 2: 121 psi 3: 136 psi 4: 125 psi 11% variance Leak down 1: 12% TDC and bottom past piston/cylinder wall into crankcase 2 : 13% TDC and bottom past piston/cylinder wall into crankcase 3: 11% TDC and bottom past piston/cylinder wall into crankcase 4: 14% TDC 10% bottom past piston/cylinder wall into crankcase |
