Welcome to the North American Subaru Impreza Owners Club Thursday May 24, 2018
Old 04-05-2010, 09:05 PM   #1
02wrxroger
Member#: 217413
Unhappy 565cc blue injectors and Walbro 255 fuel pump for my 02 WRX
Will i need to get a tune if i replace my stock injectors and fuel pump with the 565 injectors and 255 walbro pump? (before i change the turbo and uppipe) I ask because i have a VF 39 in route and i'll be switching this out soon. I also have a new uppipe that will be going in with the turbo. Will my stock TMIC be able to handle this until i get a STI TMIC?
All i have now is a full catless turbo-back and a CAI. I have had an open source tune (17lb bst) for the parts i have now.
Thanks for any help.
02wrxroger is offline   Reply With Quote
Old 04-05-2010, 09:14 PM   #2
dgriff992002
Member#: 158090
2004 Impreza WRX WRB
Hta68 ewg 382 awhp on e85
should be I've seen a few guyz run the stock wrx ic with that set-up I do have an Sti TIMIC for sale
dgriff992002 is offline   Reply With Quote
Old 04-05-2010, 09:20 PM   #3
prometheum
Member#: 92003
04 bicycle!
if you're swapping out your injectors you don't need a retune per se, but you definitely need to rescale your injectors. fuel pump doesn't require a retune. yes your stock tmic will be fine, but keep in mind it is holding you back. but if you swap out anything else besides the injectors it is a good idea to get retuned
prometheum is offline   Reply With Quote
Old 04-06-2010, 05:43 AM   #4
bugeyerex02
Member#: 195967
2002 VF39'd WRX
WR Blue
huh?
yes. you need a retune. your car will think you are running 440cc injectors. so at any given point, the ECU knows it needs X amount of fuel for Y amount of air. now, add another 125cc's of fuel each time. you will run super, super, bad rich. risking cylinder wash rich.
get a local with a tactrix cable to load you a base map or, just wait till you get your turbo in and do it all at once.
bugeyerex02 is offline   Reply With Quote
Old 04-06-2010, 06:12 PM   #5
lotarg
Member#: 90940
Do your injectors while the turbo is still out, it will make things a little easier. Also, if you are going to at any point use the Cobb VF39 map, the scaling for the blue injectors will have to be changed because they are not identical to the pinks.
lotarg is offline   Reply With Quote
Old 04-06-2010, 06:21 PM   #6
AMS
Member#: 27854
STI, WRX, GTR, EVO,
BMW, Porsche, + More!
This is correct. You don't need to fully tune the car, but you DO need to have a base map/injector scaling done. This will allow you to drive the car around until you are ready to fully tune it. I would suggest driving the car as lightly as possible until you can tune it!
AMS is offline   Reply With Quote
Old 04-08-2010, 11:10 PM   #7
subielvr5
Member#: 239083
2002 VF39 WRX
I did the VF39 upgrade w/the deutchworks 565's and I was actually able to run the turbo, CSS TMIC, Megan Bell-mouth downpipe, HKS exhaust and injectors w/o my Cobb tune at the time. I was stupid and was eager to drive it before the tune. It did boost stock though obviously, but ran fine.
subielvr5 is offline   Reply With Quote
Old 04-09-2010, 07:12 AM   #8
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
You need to sit on your wallet and sit at the keyboard and start researching. Read the sticky threads at the top of this forum as it's obvious you haven't. We have both a TMIC FAQ here and an Injector FAQ as well as 9000 other posts that will answer your questions. If you are super lazy or want hand-holding, please post in the newbies and FAQ forum.
Old 04-09-2010, 03:57 PM   #9
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
kaboom..cha-ching
Old 04-09-2010, 05:33 PM   #10
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
I see what you are trying to say and its half true. To simply drive the car and have it run yeah you need to scale them, but ACTUALLY drive the car and really get into it the car NEEDS to be tuned.
Originally Posted by bugeyerex02 View Post
huh?
Yes, car will run but not to its full potential
YES. But to answer the OP's post you WILL need a tune to properly drive the car
This is the correct answer, only not so harsh
Will
GrimmSpeed is offline   Reply With Quote
WTB: any used sti turbo or 18g/16g, sti pink injectors, and walbro 255 fuel pump cibon7 MWSOC Private Classifieds 8 02-23-2010 08:48 AM
WTB: any used sti turbo or 18g/16g, sti pink injectors, and walbro 255 fuel pump cibon7 MWSOC Private Classifieds 1 02-22-2010 10:03 PM
WTB: Used STI Pink Injectors and Walbro 255 Fuel Pump nastiaz04 SWIC Private Classifieds 5 12-31-2009 01:48 AM
WTB: STi Pink Injectors and Walbro 255 Fuel Pump InNOutBandit Private 'Wanted' Classifieds 0 09-11-2007 07:24 PM
FS: STI pink injectors and Walbro 255 fuel pump nimaxpro Private 'For Sale' Classifieds 9 10-19-2005 11:05 PM
