02-20-2008, 01:03 AM | #26 |
Member#: 122315
South East
Vehicle:2003 WRX OBP |
Did you drive the car with the BCS unplugged? What kind of boost did you see?
02-20-2008, 10:52 AM | #27 |
Member#: 99375
Vehicle:2002 Subaru WRX World Rally Blue |
drove with the BCS unplugged and threw a code and boost was mechanical boost only 7lbs....drove it with the vacuum line disconnected and over boosted...
02-20-2008, 12:51 PM | #28 |
Member#: 166919
Vehicle:03 WRX WRB stage 2 goodness :) |
It very well could have been the battery. Most newer cars will run but not well if battery voltage is less than like 11.4 ish. As for the taking the vac line off that goes from the T to the bcs i would be very cautious in doing so, cuz i was having some boost issues as well. Even being careful with my eyes glued to the boost gauge I rolled into it on the highway in 4th and it spiked to 25 psi and i heard a crazy boom followed by the check engine light and oil pressure light with smoke coming from under the hood and shards of the blocks laying under the intake manifold...... This happened in december and i'm still trying to save up for a short block. So lets just say i will never ever ever ever be yanking that line off again without some type of controller In the mix.
01-19-2016, 09:21 AM | #29 |
Member#: 425096
NESIC
Vehicle:2002 Impreza Wrx Silver |
Help!
Hey so this is a super old post but was the problem ever solved?
01-20-2016, 06:07 AM | #30 |
Member#: 112612
Vehicle:2010 Legacy 2.5 CBS 2002 Impreza WRX WRB |
If you want to test your boost control solenoid or any other 12 volt solenoid, get yourself a power probe. They're pretty awesome. You can also put the car if test mode too.
06-17-2016, 02:26 AM | #31 | |
Member#: 449071
South East
Vehicle:2002 Subaru wrx Silver |
09-26-2016, 07:22 PM | #32 |
Member#: 441253
Vehicle:98 EJ20T Forester Black |
I too am having some low boost issue. I've cleaned the solenoid and it clicks just fine if I connect to the battery, but when I have the car in test mode it is silent. I'm seeing about 11.9 V at the harness plug when the key is on. Should this solenoid be engaging during test mode or not?
01-19-2019, 04:03 PM | #33 |
Member#: 493194
So my 04 wrx was tuned on Tuesday but before it was tuned the previous owner said he had just turned the boost down to 7psi with a boost controller well since then I replaced the intake with a Perrin short ram intake and put a Perrin recirculating bov on and replace the t at the turbo and wastegate that runs to the solenoid well after the tune my car only hold a steady 6psi at 1st then about 9psi if I am getting on it through the rest of the gears my tuner told me my waste gate was opening to soon releasing all of my boost and the. I tested the connector to my bcs with a noid light and it doesn’t see to get power I am currently getting ready to check it with a multimeter and clean the bcs but if it doesn’t work I’m not sure what other options I have.
01-19-2019, 04:10 PM | #34 |
Member#: 453872
Vehicle:2005 wrx wagon 48w |
have you tried connecting the solenoid to 12v and see if it clicks open? if it does nothing when power is applied you need a new solenoid. get a MAC 3 port valve.
01-19-2019, 04:12 PM | #35 |
Member#: 493194
how to install boost controll??? | YeloWRX | North West Impreza Club Forum -- NWIC | 2 | 09-12-2007 05:42 AM |
anyone know how to test if the factory boost control solenoid is working | sonicwrxpa | Electrical & Lighting | 1 | 05-12-2007 09:50 PM |
How to test factory boost solenoid | sonicwrxpa | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 05-11-2007 07:09 PM |
How to bypass factory boost control solenoid? | Z1 Performance | Legacy Forum | 1 | 10-01-2002 12:50 PM |
how to clean boost control solenoid?? | okamikatekore | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 04-03-2002 06:06 AM |
