05-26-2011, 10:00 PM | #10376 |
Member#: 180710
TXIC
Vehicle:2006 Sti WRB WFC# 229 |
05-26-2011, 10:31 PM | #10377 |
Member#: 159243
Vehicle:5/01 bugeye Hakt Ecu is back! |
i love the fog light covers! WANT!
05-26-2011, 10:34 PM | #10378 |
Member#: 180710
TXIC
Yeah i like them more and more every day. Getting the lip re-painted and changing wheels again soon.
05-26-2011, 10:38 PM | #10379 |
Member#: 227583
BAIC
Vehicle:2002 WRX PSM |
05-26-2011, 11:53 PM | #10380 |
Member#: 21339
HIIC
Vehicle:2002 LHD STI V7 6MT 12.9@103MPH EJ205 4EAT |
Who was having the over heating problem like me?
05-26-2011, 11:56 PM | #10381 |
Member#: 167244
TXIC
Vehicle:2k3 WRX MBP Clean & Simple |
air pockets in the radiator? burp it jon!
happened to me a few weeks ago. took forever to burp! i think i did 5 burp sessions 4-5 minutes on idle.. 30 minute intervals off |
05-27-2011, 12:01 AM | #10382 |
Member#: 21339
HIIC
actually it's not that. our coolant system is self burping over time. I've changed everything. I get overheating spikes in traffic while the AC is on. Fans working (now) and still getting the over heating.
It affects my cold starts because the ECU won't fuel the car correctly if this is bad |
05-27-2011, 12:02 AM | #10383 |
Member#: 91010
Vehicle:2002 Subaru WRX OG Blueberry |
05-27-2011, 12:14 AM | #10384 | |
Member#: 159243
headgasket? is teh coolant low? do you smell it burning? white smoke? only when the ac is on? |
05-27-2011, 12:47 AM | #10385 |
Member#: 21339
HIIC
not head gasket. coolant isn't low and i have enough in the over flow tank. no burning nor smoke. well i haven't experienced it with the ac off though but I presume it hasn't been cool enough for me to warrant traffic without ac hehehe.
it's the coolant temperature sensor behind your alternator. I'm going to try and change mine and hopefully this'll resolve my trouble of lean idle, hesitation on cold starts and this random over heating. The first time my over heating was from a failed crucial thermostat that got stuck open. Then fans not turning on... weird part is if I continue driving and air goes through my fmic, condenser, radiator then the temperatures drop to normal. |
05-27-2011, 12:48 AM | #10386 |
Member#: 192372
TXIC
Vehicle:2002 wrb+white=ftw!! ej257 hybrid 6 speedin |
that would be me! still havent figured it out yet but im waiting on a koyo radiator to come in to figure it out. it seems that after my car runnung up to the red and me turning the car off 3 time on the way to my mechanics put a small crack in it so now i have to fix that too, fml! i was thinking it would be the water pump on mine
05-27-2011, 12:52 AM | #10387 | |
Member#: 180710
TXIC
05-27-2011, 12:53 AM | #10388 |
Member#: 21339
HIIC
I have a ron davis / speedmonkee aluminum radiator and everything was replaced except for this small little thing. I gotta look at my fans too and chop and solder a new wire for the fan cause these wires seem to be damaged.
05-27-2011, 12:55 AM | #10389 |
Member#: 225389
RMIC
Vehicle:03 WRX MBPwidebody rotated 35R VOLTEX bugeye |
^because your car is too hawt!
05-27-2011, 01:02 AM | #10390 |
Member#: 192372
TXIC
i still kinda a noob, i have never herd of speedmonkee radiators before. are they good? and if so where can you get them at?
05-27-2011, 01:18 AM | #10391 |
Member#: 21339
HIIC
speedmonkee isn't around anymore. They're made by Ron Davis and you can still buy them through Ron Davis.
05-27-2011, 01:55 AM | #10392 |
Member#: 21339
HIIC
It's either my sensor or the harness to the sensor that's bad. Idled my car for about 20 minutes. The fans drivers side fan didn't turn on. The engine should've turned both fans on but didn't. When I turn the AC switch on the drivers side fan turned on. When off it turned off. Should've stayed on because the engine was very warm and car wasn't moving played with the switch with two screw drivers and the fans turned on. Took the connector off a little then engine adjusted timing and there was a big difference in idle. Put it back and didn't turn on. Messed with switch again and fans started moving again. I have multiple trouble but all causing a weird condition. I'm gonna change my sensor and replace radiator cap and thermostat to an OEM one again. Messaged my tuner about any temp adjustments away from stock. Waiting for reply.
05-27-2011, 02:01 AM | #10393 |
Member#: 30745
South East
Vehicle:SRP Greddy(R.I.P) Bugeye & '99 LandRover D2 |
I thought this was a good pic to post up...
Maybe these too... |
05-27-2011, 02:10 AM | #10394 |
Member#: 21339
HIIC
Nice shots
05-27-2011, 02:32 AM | #10395 |
Member#: 159243
you seem to be on the right track infek. if you try hard enough, you will figure it out. its only bolts and wires right?
our cars are funny with grounding as i'm sure most of you are aware...being 9 years old stuff is gonna start to fail. my problems are usually based around the last thing i messed with lol... |
05-27-2011, 02:38 AM | #10396 |
Member#: 21339
HIIC
Thanks, it's because it's 9 years old and understand that if I don't resolve the issues that she won't be around for 9 more years you know? Bugeye for life!
05-27-2011, 02:41 AM | #10397 |
Member#: 159243
nothin to it but to do it! don't be skerred! take your time and if you have doubts...STOP!
05-27-2011, 02:58 AM | #10398 | |
Member#: 21339
HIIC
Sensor Thermostat Radiator Cap Clogged Radiator |
05-27-2011, 03:42 AM | #10399 |
Member#: 233105
NWIC
Vehicle:2006 WRX CGM |
Taken and edited with Android HTC Inspire |
05-27-2011, 08:57 AM | #10400 |
Member#: 171495
Vehicle:2001 WRC S7 Replica Wrong Fitment Crew #019 |
Wanted to post my bugeye here also, cant remember if i allready did
the Bugeye thread | 5spdfrk | Member's Car Gallery | 18633 | 05-20-2010 12:18 PM |
Where's the bugeye lip thread?! | yankdanger | Interior & Exterior Modification | 0 | 04-06-2009 09:43 PM |
