Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 12-15-2004, 04:37 PM   #1
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Default Is it possible for a wrx to be FWD?
Because under heavy boost my car acts like it is! I mean when the boost hits sometimes the front tires spin i can feel it, car feels all funked up. Broken center Diff. or something else? Transmission goes through all gears fine although at 70,000k it wouldnt suprise me if its broke.
PaulRex is offline   Reply With Quote
Old 12-15-2004, 04:41 PM   #2
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Your front tires will spin slightly under high load in most any AWD car that uses a viscous coupling center differential (such as the WRX)... it takes time for the differential to lock up, and it will behave as an open differential until it does, resulting in wheelspin on the wheels with the least grip (ie, the front ones, under acceleration, due to rearward weight transfer) until differential lockup can occur.
/Andrew
Kha0S is offline   Reply With Quote
Is it possible for 09 WRX to acheive STI HP/TQ numbers without any exhaust mods? REX265 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 81 12-27-2009 12:23 PM
Is It Possible for the Vendors to Have Their Signatures Removed... OriginalSin Off-Topic 42 07-24-2008 03:43 PM
is it possible for a lift to damage a downpipe? Wagon Joe Service & Maintenance 3 09-19-2005 04:30 PM
Is it Possible for uneven tires to mess up alignment? thetikler1 Tire & Wheel 4 01-11-2005 06:26 PM
