Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Old 12-13-2008, 04:07 PM   #1
Super_HKS
Member#: 154434
2009 WRX Hatch <@[email protected]>
Default Coolant help needed
So my Resovoire tank on my WRX is getting for coolant. I purchased an antifreeze/coolant combo at the store to fill my car and my fiancees Legacy GT. The coolant that is currently in our cars looks green. The coolant I purchased today is a redish color. To insure I dont do something stupid, will this be fine or shall I take some other steps around this.
Thanks for your help and knowledge
Sincerely
-Daniel
Super_HKS is offline   Reply With Quote
Old 12-13-2008, 04:09 PM   #2
Super_HKS
Member#: 154434
PS I read this but still was a little unclear
http://forums.nasioc.com/forums/showthread.php?t=504002
Old 12-13-2008, 04:38 PM   #3
Jim2752
Member#: 147610
2007 Stage 2 STi
I think your only supposed to use the green stuff. The Subaru coolant would probably be the best.(make sure you don't get the new blue stuff they have for 08/09)
I'm about to change my coolant because I put some prestone in there and I would rather have subaru coolant.
Jim2752 is offline   Reply With Quote
Old 12-13-2008, 10:33 PM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
If the stuff you bought says "dexcool" on it, do not use it - bring it back!
DrD is offline   Reply With Quote
Old 12-13-2008, 11:50 PM   #5
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
You stink at reading. Color has ZERO to do with coolant, quit discussing color. If you don't know, drain it all out and replace so you DO KNOW. #2 option is to use a "any make/any model/any fluid coolant" like Peak Global as a band aid fix to top it off for now.
Old 12-15-2008, 09:34 AM   #6
Super_HKS
Member#: 154434
WHy is this?
Old 12-15-2008, 10:00 AM   #7
rkramer
Member#: 118209
2015 WRX Limitec
Originally Posted by Super_HKS View Post
WHy is this?
Dexcool + regular coolant has a possibility of sludging up. Haven't seen it personally but there are enough reports of it. The big problem is that if you have a leak already, and use dexcool to top it off, you run the risk of really bad things happening if the dexcool hits hot engine parts.
(go down to the organic acid section for dex cool)
http://en.wikipedia.org/wiki/Antifreeze
rkramer is offline   Reply With Quote
Old 12-15-2008, 03:42 PM   #8
Super_HKS
Member#: 154434
I dont have a coolant leak or anything just my coolant resovoire tank is getting a bit low and I wanted to top it off. Should I just take my car to subaru and say hey can you just top off the coolant for me? Crap I just spent like 17 dollars on that god damn coolant.
Old 12-15-2008, 07:01 PM   #9
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
if it's just a little bit, around 1 cup or so, just use distilled water. if you find yourself having to add some more often, you have a leak somewhere and should replace with 50/50 mix. well, find the leak first, THEN replace with 50/50. If you're willing to go to the dealer and get screwed on labor charges, just buy subaru coolant and don't worry about it.
yarrgh is offline   Reply With Quote
Old 12-19-2008, 11:21 AM   #10
Super_HKS
Member#: 154434
I dont havea leak.........I just want to top off my resovoir tank
coolant diminishes....... need help jdmjunkie562 Newbies & FAQs 19 02-13-2009 12:40 AM
Bad coolant leak, need help quick! sorrowfulkiller Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-22-2009 01:31 PM
coolant issues. need help! ImprezivEJ20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-22-2008 05:38 PM
mysterious coolant leak need help zero-d Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-05-2007 08:35 PM
Coolant leak...need help KitchenerWRX Newbies & FAQs 2 08-25-2005 03:15 AM
