Welcome to the North American Subaru Impreza Owners Club Friday December 14, 2018
Old 05-05-2002, 05:16 AM   #1
sumo
Member#: 2458
1999 impreza L
Default E-Brake light stays on...?
Hello. My cars e-brake light will not turn off. At first, it would turn on every now and then. I made sure the brake handle was all the way down, and messed with the switch and it won't turn off at all. Do I need a new switch, or is there anything I can do to repair it?
Thanks
sumo is offline   Reply With Quote
Old 05-05-2002, 07:14 AM   #2
syntrix
Member#: 9211
2002 wrx wrb
swankmonkey.com
I'd guess that one of the wires that go to the switch at the base of the handle is grounded out.
Don't remember if the brake / ebrake light is the same, but if it is, then it's a possible failure somewhere?
The brakes work fine when stopping, right?
syntrix is offline   Reply With Quote
Old 05-05-2002, 01:00 PM   #3
sumo
Member#: 2458
1999 impreza L
Yes, the brakes work fine.
Old 05-05-2002, 04:01 PM   #4
I drive a WRX wagon
Member#: 9219
02 IS300 5sp
check your brake fluid. That light also comes on when fluid is low
I drive a WRX wagon is offline   Reply With Quote
Old 05-05-2002, 09:39 PM   #5
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
when the fluid got low in my car once, the red ebrake light was constantly on. I do not, however, drive a wrx.
rex n effect is offline   Reply With Quote
Old 05-05-2002, 10:51 PM   #6
sumo
Member#: 2458
1999 impreza L
WRXwagon. You were right on. Right after I read your reply I looked at my fluid and it was low. I put some in and the light turned off...Thanks alot for the responces...
Thanks
Parking brake light stays on TyranosaurusWRX Service & Maintenance 23 05-04-2018 09:49 AM
installed new mc, bled brakes brake light stays on???? vien Brakes, Steering & Suspension 6 04-27-2010 03:18 AM
Brake light stays on when cold? strohk Brakes, Steering & Suspension 4 12-15-2004 06:21 PM
E-Brake light staying on? Bobalouy Brakes, Steering & Suspension 5 09-07-2004 04:00 PM
Parking Brake light staying on??? NYWRXTASY Brakes, Steering & Suspension 8 04-09-2003 09:57 PM
