10-12-2018, 04:46 PM | #1 |
Member#: 482024
Vehicle:2002 WRX Silver |
Is Head work worth it on a DD? EJ205
I was just wondering to what extent I should build my 02 WRX 205 heads. Im planning a 300-350 wheel DD with a 20g and meth injection. Just curios to hear your guys thoughts. Thanks in advance!
10-12-2018, 05:04 PM | #2 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
Isn't needed for those power goals.
Depending on what your definition of head work is, it'll allow you to make that power with less boost and little trade off. Or you make the same power with more margin of safety. What size turbine housing; 7cm or 8cm? |
10-12-2018, 05:08 PM | #3 |
Member#: 298403
W. Canada
Vehicle:2008 WRX Premium Spark Silver |
As mentioned, what kind of head work are you thinking?
I'll second that, you can easily achieve those power goals without touching the heads. The factory heads are good for around 450hp. |
10-12-2018, 05:46 PM | #4 |
Member#: 461268
10-12-2018, 06:56 PM | #5 |
Member#: 395793
Vehicle:2005 92x Aero Beige |
10-12-2018, 07:44 PM | #6 |
Member#: 461268
Talking having them ported. Obviously better using their dual avcs feature
10-12-2018, 08:14 PM | #7 |
Member#: 461268
I was saying more so on matching the flow characteristics of ej20x heads which are supposedly Jdm better flowing heads
10-12-2018, 08:53 PM | #8 |
Member#: 267339
BAIC
Vehicle:2002 0[[XXXXoXXXX]]0 MBP LongRoof |
Spend the money on proper EL headers & good TMIC instead...and do TGV delete/porting.
10-12-2018, 09:52 PM | #9 |
Member#: 298403
W. Canada
10-13-2018, 09:22 AM | #10 | |
Member#: 33782
Example, I have two sets of EJ20Y/X (manual vs auto) heads in my garage and they're not big port but are DAVCS. Last edited by Homemade WRX; 10-17-2018 at 12:09 PM. |
10-13-2018, 07:53 PM | #11 |
Member#: 461268
10-14-2018, 04:11 PM | #12 |
Member#: 384017
Vehicle:2009 WRX WRB |
Don't waste your money on head work at that power level. Stock heads are plenty capable at that power level.
10-15-2018, 09:30 AM | #13 |
Member#: 33782
10-15-2018, 10:27 AM | #14 |
Member#: 492721
Hello everyone!
10-15-2018, 10:32 AM | #15 |
Member#: 461268
10-15-2018, 11:52 AM | #16 |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
head work does make the engine breath better up top, but it doesnt necessarily mean that it will work well with the turbo you have. to make power, you need to match components to what you are trying to achieve and where you want your power band to be. Ie if you have a 16g turbo that doesnt make power above 6500 why try to make power above that. Now if you have a 3076 then yes it makes sense cause it can make power above that point.
Also if you get head work, you will loose velocity on the bottom end so it will lag a little more. |
10-16-2018, 05:06 PM | #17 | |
Member#: 33782
On my personal 2.1 stroker build, I'm using stock EJ255/7 exhaust cam and ported heads. I didn't want a big lope in my daily driver. I also wanted to keep low end spool for the .64 6758 setup and have flow for the .83 7163 (interchangeable EFRs). I did go ahead and toss some left over sodium filled STi valves in there and some old BC springs and retainers, as I'll be spinning over 8k on the 7163. |
10-16-2018, 11:09 PM | #18 | |
Member#: 166005
Vehicle:2005 Saab 92x Beaten Silver |
Are you keeping the 205 intake cam?! |
10-16-2018, 11:38 PM | #19 | |
Member#: 395793
Have you flow tested these by any chance? I'm getting myself an older Impreza to turn into my track specific car and am thinking about an EJ20x/y for it. I know they spin to 7500 and have a forged crown/cast piston and according to a few Aussie posts that they do flow better then the S20 heads. But since you have them in hand, any specific differences that stand out to you? Last edited by snow_bound26; 10-17-2018 at 08:53 AM. |
10-17-2018, 12:05 PM | #20 |
Member#: 33782
I haven't compared them. One set of heads were development heads and the the other set is still part of an assembled EJ20X, that will be going up for sale.
10-19-2018, 01:08 AM | #21 |
Member#: 333468
RMIC
Vehicle:93 SS - 06 OB XT 03 WRB GD 205/22T 20G-XT |
I get about 360 whp out of my 22T/205 hybrid with stock heads running a Blouch 20G-XT. I did chamber match them for the 22T bore and threw in some STi cams, but other than that they are stock and work great. Like others have said, no need for head work to reach those power goals. If you can afford it and want to do it, that's another story.
10-19-2018, 09:01 AM | #22 | |
Member#: 258151
I don't have a 1d simulation that I trust the output of so I won't go much further into it other than the very basics. Besides, we both know despite the stuff I'm messing with for fun, you've done a lot more stuff focused on modern engine packages. Anyway, quickie guide for those in the audience, for a given amount of air trapped in the cylinder (volumetric efficiency) the more air the ports flow, the less time you need the valves open. The less time you need the valves open the less you compromise part of the powerband by having them open at times you don't want. AVCS is sort of another way of doing that, but for something that makes power at high RPM, you're still going to be basically saying "OK, at this point do I want the valve to open too early or close too late?" On the other hand, it gets to be a challenge to have ports that flow well but still produce good in-cylinder motion (just hogging out to big holes isn't necessarily the best) but it'd be a boring world if it was easy. If I had a big budget for an "ultimate" street EJ, I'd probably reshape the ports a lot (might not fit in the stock castings) and go with cams with a lot of lift but relatively mild duration. OK, for a given horsepower level (300-350 at the wheels, whatever) you can just throw more boost at it to get there, but I feel like by reworking more you can get a lot more out of the engine at a given boost level. |
10-19-2018, 11:28 AM | #23 |
Member#: 33782
Yeah, I wished I'd just forked over the money for +1 valves on this street set up but my Bugeye is the beater, so it was mostly hand me down parts.
I was going for good flowing heads and small cams to keep a more livable powerband, idle, and better fuel economy. Thanks tiny overlap and little cams. Went with the larger STi exhaust cam to see how it behaves with the torque curve. I think it'll help mid range. |
