Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 10-27-2017, 12:41 PM   #1
jrinker
Member#: 459950
Default 07 impreza need advice on replacement parts
So my impreza I think has a bad head gasket, I've ran all of the tests hoping it wasn't. This will be the 2nd gasket thats been put in, 212,000 miles
Anyways I plan to do the job myself and was looking for recommendations on what else I should replace while i have it apart?
I already replaced waterpump, timing belt, pulleys, thermostat, and radiator.
And I know it needs valve stem seals
jrinker is offline   Reply With Quote
Old 11-10-2017, 01:37 AM   #2
KennyMW
Member#: 477462
I would check to make sure none of your hoses are dry rotted or turned into solid plastic. I don't know if you have that kind of issue where you are from. It sounds like you'll be removing a lot of lines in the process so be careful of any old brittle parts.
KennyMW is offline   Reply With Quote
Old 11-22-2017, 01:20 AM   #3
IanT-EJ22
Member#: 477892
2000 Impreza Wagon
Accessory drive belts? A/C and P/S, Alt Belts. It also doesn't hurt to maybe consider cylinder head bolts. Factory bolts are technically only to be re-used so many times. As you might know they tend to stretch and cause improper torque on the head. Also, always have your heads decked/re-surfaced and check the block for flatness while the heads are off, at least during your first head gasket change or once in the motors lifetime.
IanT-EJ22 is offline   Reply With Quote
Old 11-22-2017, 11:55 PM   #4
Beltfed
Member#: 478123
Cam shaft seals. Your on the right track
Beltfed is offline   Reply With Quote
Old 11-22-2017, 11:56 PM   #5
Beltfed
Member#: 478123
Get a full gasket set will have everything you need plus extra
