Welcome to the North American Subaru Impreza Owners Club Saturday February 24, 2018
Old 04-30-2004, 03:01 AM   #1
Rev1
Member#: 51240
08 Lexus IS350
Talking Braille lightweight battery installed
Very cool ... weighs 11.5lbs ... vs 31lbs stock battery
Rev1 is offline   Reply With Quote
Old 04-30-2004, 03:22 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
You should put a heat shield to block radiant heat on it so it lasts longer.
The heat will kill it....that's why I put my PC680 under the passengers seat....it's cooler than the engine compartment
Old 04-30-2004, 10:22 AM   #3
Davenow
Member#: 23676
where from? how much?
Old 04-30-2004, 11:44 AM   #4
cnk
Member#: 10757
2013 BRZ Limited 6MT
Found this in the vendor's forum: http://forums.nasioc.com/forums/show...hreadid=549782
Uncle Scotty: What type of heat shielding would you recommend? Maybe a battery box?
Calvin
cnk is offline   Reply With Quote
Old 04-30-2004, 11:46 AM   #5
Rev1
Member#: 51240
08 Lexus IS350
http://www.imprezawrxsti.com/postnuk...018&highlight=
This guy goes for $125 shipped
Old 04-30-2004, 12:20 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
You could fab a heat shield out of just about anything that would be usable to 250F. I would go to a bone yard and find a suitable piece of material....metal or plastic......and work it to suite the need. It would only need to block the 2 short sides and the side closest to the engine, as installed in STi_Thunder's pics making sure that there is an air gap and the shield extends over the top of the battery by a bit.
The Hawker Odyssey PC680 can be had off a reputable ebay vendor for $65.50 shipped with posts.
The PC680MJ(metal jacket), which is what I have, is a bit more at ~$85shipped with posts. The MJ has a higher operating temperature range.
Hawker is a very large and reputable battery manufacturer, and after MUCH research into my battery relocation project, I'm sure that I made the right choice in battery for my needs.
Mine has seen daily use since SEP03 without any problems.
Old 04-30-2004, 12:29 PM   #7
Rev1
Member#: 51240
08 Lexus IS350
Fortunately, the stock battery holder posts extend quite a bit from the nylon spacers and the nuts, maybe something can be done from there.
Or maybe reutilizing the stock plastic battery holder, it'll probably fit.
Old 04-30-2004, 07:28 PM   #8
G-force
Member#: 14104
UBER ILikeItLongAndH
ardDeepandSmoothEverSoCoo
Could you please explain what process/wires/tools were needed to relocated the battery to the under-passenger seat? Got pics plz? TIA!
G-force is offline   Reply With Quote
Old 04-30-2004, 07:59 PM   #9
bemani
Member#: 5673
16 Hellcat
05 LGT, 02 bug eye
Calvin
Just go and put the stock one back on.
bemani is offline   Reply With Quote
Old 04-30-2004, 09:15 PM   #10
cnk
Member#: 10757
I'm running the stock one right now. It's getting pretty cramped in that corner now though with my FMIC piping and oil catch can.
Calvin
Old 05-01-2004, 01:40 AM   #11
BIGSKYWRX
Member#: 7958
09 GH B+
Heat is the enmey of these little batteries- one of the reason I also opted for the metal jacket 680. I fabbed a aluminum heat shield backed w/ thermo tec adhesive material- also added some to the metal jacket of the battery
Old 09-10-2004, 10:31 PM   #12
Versus
Member#: 3575
02 bugeye - sold
05 S2000
did you have to modify anything to fit this battery? cable length or etc?
Versus is offline   Reply With Quote
Old 09-15-2004, 12:40 AM   #13
WRXVII
Member#: 15854
VF34'd...
did you have to order the terminals? I ordered Hawker 11.5lbs battery for around $90 shipped....
WRXVII is offline   Reply With Quote
Old 09-15-2004, 11:13 AM   #14
BIGSKYWRX
Member#: 7958
09 GH B+
With mine laying flat (felt this was the most secure way for the little battery to ride) I just "lengthened" the cables by undoing a clip or two where they were bundled w/ other wires. IIRC I also sligthly rerouted one of the cables.
The top mounting I don't think you'd have to do anything.
Big Sky
Old 09-17-2004, 03:23 AM   #15
InfamousDX
Member#: 25413
Yea I'm probably getting the PC680MJ and was wondering... you have to buy terminals right?
I just don't have the $$$ to spend on a Braille, although it does look DAMN nice!
EDIT: Nevermind found an auction WITH terminals from the same vendor.
Old 09-17-2004, 11:38 AM   #16
Wolfen42
Member#: 33060
2006 WRB WRX Wagon
I turbocharge campfires.
Angry
Heh... I just checked... one of the venders has one up now... but it's a 5 day auction w/ no buy it now... bleh...
Wolfen42 is offline   Reply With Quote
Old 09-21-2004, 06:01 PM   #17
InfamousDX
Member#: 25413
Old 10-05-2004, 03:22 AM   #18
InfamousDX
Member#: 25413
My braille is in... now to mount it - upright or on its side?
Old 10-05-2004, 11:38 AM   #19
cnk
Member#: 10757
Aren't you concerned about it's performance in the winter here in NJ? I'm debating between a battery like the Braille or a Optima 51R yellow top.
Calvin
Braille Lightweight Battery calworld Private 'For Sale' Classifieds 3 05-26-2005 01:34 PM
March Madness: $25 off the Braille Lightweight Battery (only 11.5 lbs) King Of Imports SCIC Vendor Classifieds 3 03-29-2005 06:46 PM
VA: Braille Lightweight Battery or something along those lines 15secWRX Private 'Wanted' Classifieds 1 12-17-2004 06:14 PM
Braille Lightweight Battery? stefano General Community 10 02-09-2004 04:07 AM
