03-10-2011, 12:39 AM | #2451 |
Member#: 255153
TXIC
Vehicle:'02 Corn fed bugeye '11 forester 2.5X SWP |
Well as of right now on the airboy dyno Im making 280awhp/260tq on my first tank of e85. And this is with my timing in the basement as my tuner said. Hoping for 300/300 with some more timing and boost.
03-10-2011, 09:16 AM | #2452 | |
Member#: 82146
South East
Vehicle:2005 Legacy GT OBP |
(thus requiring a clean up-bore) |
03-13-2011, 11:19 AM | #2453 |
Member#: 139385
I got the 1400 FIVE O motorsport injectors the other day. soon to have results on 93 and e85. just thought i would share going in my 06 WRX at the same time as the DW300 fuel pump. Phatron Phatbotti tune of course. sorry about the crummy iphone pics.
Uploaded with ImageShack.us Uploaded with ImageShack.us |
03-13-2011, 11:48 AM | #2454 |
Member#: 163648
Vehicle:2002 WRX V9 6mt R180 Brembos |
Yeah those five-o's are the best deal on injectors period. Fic treated me well on the Bosch 2200's but five o just sells them for nothing it seems. Giving the damn things away!
03-13-2011, 01:16 PM | #2455 | |
Member#: 190729
03-13-2011, 01:51 PM | #2456 |
Member#: 241600
Vehicle:2004 WRX STi like a million whp |
quick question for someone who can answer this well.
Right now I'm still on stock turbo (VF39) and planning on getting tuned for E85. I'm currently running 850cc injectors which i'm having problems with, so I'm going to buy Five-O injectors. After I get my tune I plan on upgrading my turbo....question is, should I buy 1000cc injectors or 1200cc injectors? Five-O makes both in sidefeed, so that's not an issue, but is 1200cc a bit overkill or is that a good match up with say, FP red, HTA86, DOM3, TD06 20g etc...? |
03-13-2011, 02:01 PM | #2457 |
Member#: 211113
Vehicle:2004 STI WRB |
It's not an overkill. Just get the 1200's
03-13-2011, 02:15 PM | #2458 |
Member#: 77470
Vehicle:04 sti 10.41@141 on e85@ 30psi--spinning |
The 1200's will be fine up to like a 54lb turbo anything bigger than that(35r,hta86,etc.)will require switching to topfeed and going bigger(fic,five-0,or id 2000's) if you plan on running e85.You may need a bigger fuel supply also.
03-13-2011, 02:35 PM | #2459 |
Member#: 241600
well to be perfectly honest, going much bigger than that will require me to rip out and build the engine, and this is my DD so i doubt that's a possibility what with me being a college student & attempting to work full time
03-13-2011, 02:37 PM | #2460 | |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
My 1200cc injectors are almost maxout with my OG green 49lb/min, please look at the first page for the recommended injector sizing |
03-13-2011, 02:58 PM | #2461 |
Member#: 241600
will do, thanks guys!
03-14-2011, 07:55 AM | #2462 |
Member#: 261612
Vehicle:2002 WRX - 750WHP 9.5s @ 150mph |
I have 1200's with a VF52. "Overkill" for my setup, but no issues, so I don't see why not.
03-14-2011, 08:23 AM | #2463 |
Member#: 149114
Get the 1200's
He'll im runing 1000cc on a VF37, granted im still in break in but my IDC's are less then 20% now, haha. Kinda wish i didnt convert to top-feed, the five0 side feed would have saved me some $$ |
03-14-2011, 08:34 AM | #2464 |
Member#: 159243
Vehicle:5/01 bugeye Hakt Ecu is back! |
even with the big 2000cc injectors, tuners such as ron and mike are not having any issues safely controlling the flow with them turned down for smaller turbo applications.
i would consider staying fairly close to your established goals though, you don't need id or five0 2000s to push a 30r on pump but will need injectors that big to push e85 which requires 30% more fuel. e85 will also require some fuel system upgrades like john has stated. And remember that getting bit by the power bug can be quite addictive. you upgrade from a td04 or a vf30/43/52, to a 30r, and you soon find yourself wondering how you were even impressed by your first test drive. once you go turbo, forget about N/A right? lol. i know there is a line that gets crossed, but if you should establish a power goal and stick to it. if you start buying parts and change you mind mid-build, you may end up losing money on parts that are under sized. def do the research, dont impulse buy. don't buy cause its trendy. there are a lot of kind gentleman on here that would be happy to advise any of us with suggestions, and success failure stories. don't be afraid to post questions or even pm the guys that seem to make sense to you. thats what this is really all about. don't be disheartened by some of the rude people on the intrawebs. there are plenty of straight up big power subarus right in this thread that would be happy to help out...including myself. i help where/when i can. i could use a lil help myself right now! lol. |
03-14-2011, 09:08 AM | #2465 |
Member#: 7962
Vehicle:08 335i TwinTurbo PSM 02WRX, 97 Dipped CRV |
inj
Just woke out of my winter hibernation (yawn) driving the crv
My ID2200's and 30R at 22psi for DD is hilarious looking at the duty cycles at WOT lol, go big I've had JE pistons with no issues for a long time -TDAGEN knows his stuff! Question/trouble shooting= anyone have a bad coilpack cause a misfire at WOT on E85, or maybe lead wire? I know I still need the Boost a Spark for $229!! bump from 12v to 20v muahaha http://www.kennebell.net/KBWebsite/P.../PriceList.pdf **This thread is the best one on this whole site IMO lol** Last edited by Greenracer6; 03-14-2011 at 11:37 AM. |
03-14-2011, 10:48 AM | #2466 |
Member#: 139385
There is much about plug heatrange and gap on this thread about misfires
03-14-2011, 11:40 AM | #2467 |
Member#: 7962
03-14-2011, 11:47 AM | #2468 |
Member#: 163648
03-14-2011, 11:59 AM | #2469 |
Member#: 82146
South East
Stick with big side feeds or go top feed conversion??
03-14-2011, 12:06 PM | #2470 |
Member#: 163648
Greeracer , I have had big misfires... To much E85 will drown that spark right out! I think it was 25 psi on the 91-79, that happened on. I'm sure if you had a bad coilpack it would kind of go the same way. Fuel finds the next hottest thing to light off besides the blown out/not sparking plug, problem is it lights at the wrong time. In my hybrid I am pretty sure the fuel was lighting off of the sharp overhang of the 2.0 heads on the 2.5L when my spark plug was drown/blown out. I installed a Kenne bell boost-a-spark and I have not had any issues since... If you take your coilpacks out it's pretty easy to see if they are shot. From what I've researched they will actually melt/deform a bit and or get cracks. .024 gaps ftw too...
03-14-2011, 12:09 PM | #2471 |
Member#: 159243
wow .024 gap of what plug?
i decided to run .030 on ngk coppers. why would you want to lessen the gap? is that an e85 gap? |
03-14-2011, 12:14 PM | #2472 | |
Member#: 133146
03-14-2011, 12:33 PM | #2473 |
Member#: 163648
Ngk coppers, yeah since there is so much more fuel being thrown in the cylinder with E85 you gotta drop the gaps with bigger turbos, iirc .026-.024 is what I ran with the 30r. The smaller the gap the easier it is for them to spark, bigger gap is a bigger distance for the spark to jump and it makes it easier to blow out...Even big turbos on gasoline need the gaps dropped. Unless you have a mean ignition system ...
03-14-2011, 01:03 PM | #2474 | |
Member#: 7962
How do you like the boost a spark???!! (Awesome btw) ALL OUT |
03-14-2011, 02:53 PM | #2475 |
Member#: 159243
i have heard guys running the shorter gap, and thought it was about blowing the spark out. then my local napa brother explained that i would want the spark to be long so that it would ignite and not blow out.
gap for my build on 93 pump? should i switch out the 2$ ngk copper for a 10$ irridium? |
Similar Threads | ||||
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY | Motion Lab Tuning | Proven Power Bragging | 125 | 04-12-2010 02:57 AM |
jid2 Track Car - e85 ARMY | jid2 | Member's Car Gallery | 38 | 01-22-2010 10:44 PM |
The Honduran army is the bravest in the world... | wrxcelent | Off-Topic | 36 | 07-07-2009 08:21 AM |
Spacific E85 Tuning thread Here ? | discopotato03 | Engine Management & Tuning | 1 | 09-09-2008 11:01 AM |
Did anyone hear the one about the Italian army and the IRAQI satiation? | Asinine | Off-Topic | 3 | 09-20-2005 07:06 PM |
