#1 |
Member#: 90353
Vehicle:Sold '95 22T Impreza '99 EJ205 L, AE86 GVR4 |
![]() I am young (17) and really dont know very much, but im really excited about doing this swap with the help of some friends. (94 legacy ss motor into my 95 ej18) We have faith that we could swap the engine in with no problem, bolt everything up fine, but wiring the thing and getting it running properly could become a problem... How easy/hard is it? if i got online help could i do it? also, what would i need electrically, the ecu and full wiring harness?
also, i know i need a turbo crossmember, and swaybar, along with better cooling eventually, but anything else you can think of? i appreciate any help i can get! (i know this prolly has been done alot and ill keep searching around the forums) thanks! ![]() -nathan Last edited by Natoe; 07-06-2005 at 04:40 PM. |
#2 |
Member#: 90003
Vehicle:2005 STi OBP |
![]() Well, im just starting a ej22 into my 95 ej18. Since all those motors are the same, but in different models, you should be able to just swap and plug into your old wiring harness with an ecu swap for the new motor as well.
#3 | |
Member#: 2780
Vehicle:junk yards rule! Project FrankenSTien |
![]() Quote:
#4 | |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
![]() Quote:
Anyways, the easy way to do this is how we did Bugman's car. Use the Ej18 engine/intake manifold harness on the Ej22T (The G was found only in the 22B) and it will plug right in. Then, to control boost, timing, and fuel get an E-manage to tune it. This is the simplest approach... |
#5 | |
Member#: 2780
![]() Quote:
#6 | |
Member#: 90353
![]() Quote:
#7 |
Member#: 32609
Vehicle:2005 saab 9-2x rhd ej20tt sold... |
![]() if its the wiring your worried about why don't you swap just the block and heads from the 2.2 and bolt everything else from the 1.8 to it.
#8 |
Member#: 832
RMIC
#9 |
Member#: 58908
Vehicle:'07 STI silver |
![]() i just put a 2002 ej20 in my 2002 rs. i thought the harensses might be really similar seeing as they are from the same year/body style. ended up having to swap all the wiring. i doubt it will be plug -n-play on the older cars either.
#10 |
Member#: 89599
RMIC
Vehicle:1995 95 Impreza red |
![]() I am in the middle of this exact swap right now. I have the motor, tranny and front brakes in.
For eng. management, I used the stock EJ 18 harness with the Rallitek Perfect power. I have yet to start the car and am still figuring out some bugs. If you use the 2.2 intake manifold and throttle body, you will have to swap over the TPS from the legacy. Make sure to solder. Also, the problem I am trying to figure out right now is the wiring for the MAF sensor is slightly different between the two Cars. If any one has a diagram of this( Josh I am begging you!!!!!!!!!) that would help. If you plan on intercooling, find an old slant style intercooler of of an early european WRX. I am doing it with the USDM wrx inter cooler, and had to cut the metal around the Pitching stopper mount on the fire wall, as well as hammer the firewall in a bit. Finally, I have to install the intake manifold and the intercooler at the same time. You have to buy a longer hose to go between the turbo and intercooler. You also need to swap over the entire pedal assembly from the Leg so you can have a hydraulic clutch. You need the crossmember from the Leg as well as the rear diff. YOu may need the rear dif carrier and I will find that one out on thursday. You will get rid of cruise control because there are some parts that will interfere with the routing of your exhaust. Just a few things to think about before you embark. I am also young (21) and took a semester off from school to pay for this swap, and I am doing it my self. I started gather parts, cleaning, and repairing two weeks into september 2004. I put the motor in last saturday!!!! Be patient or beg your parents for some fundage. |
#11 | |
Member#: 2780
![]() Quote:
#12 |
Member#: 90353
![]() so bmxpunk, when you did it did you just swap the longblock? if i was to do just that (use all of the ej18 stuff as i could) would that make wiring it to the legacy ecu easier?
But if i had the legacy ecu then the sensors like the TPS and MAP from the legacy would plug right in i hope. If i took the car with the engine swapped but not wired to an auto electric shop how much do you think they would charge to wire it? or would they even do it? also, does anybody know if the 91-94 turbo ecu's are all the same or do you have to get one thats engine year specific? thanks a BUNCH for all the help guys, im sure ill have more questions as i get going on this. -nathan |
#13 |
Member#: 89599
RMIC
![]() The carriers are the same ? I thought so. A guy at rallispec said they were different. I don't trust them Like I do other vendors.
Any way. To wire the car, again, Rallispec saidthey could splice the harnesses for me to just drop into the car for $1000. I believe that all 91-94 turbo ECUs are the same. In fact I have a guy at autronic looking to see if the pins are the same for the 95 euro wrx are the same. If you use the Legacy's harness you wont have a problem. I used the 95 Imprzas harness and that is why I had to swap over throttle position sensor and Maf sensor plugs. I am still in some of the inital stages of the swap. I am going to put some mre stuff together tonight. and I will let you know. I will tell you I have had good luck and received good advice from THe guys at rallitek and Dale at Boxer4racing. |
#14 | |
Member#: 90353
![]() Quote:
thanks |
#15 |
Member#: 832
RMIC
![]() BMX punk, the pinouts are the same with one major exception, the early WRX's used coil on plug ignition and a four channel ignitor. There's extra wiring there, and two extra sensor wires into the ECU. OTherwise USDM Legacy turbo wires like an early WRX...
#16 |
Member#: 89599
RMIC
![]() Thats what I thought but also, you have to use the crank and cam wheels from a wrx because our 2.2t triggers are different and the computer wont read it.
In theory, that would be the best way to go. Wire it up using the legacy turbo harness. replace the toothed crank sproket from a current wrx and buy the tunable autronic. I jsut might do that if my perfect power isn't, well, perfect. |
#17 |
Member#: 90353
![]() this is excellent information, wiring is definetly the most intimidating part. keep me up on how its goin.
so there is no way to use the EJ18 ECU in this swap? even if you got a seperate boost controller and knock sensor units since of course the EJ18 doesnt have? if i put ej18 intake manifold and heads on the 2.2, then used the EJ18 wires and ECU along with aftermarket boost controller would that work? thanks a bunch |
#18 | |
Member#: 832
RMIC
![]() Quote:
#19 | |
Member#: 90353
![]() Quote:
at this point, i will just want something that works, and that way i can improve on it later. running on wastegate, does that hurt anything? what exactly is it doing? just letting the wastegate dump excess boost by itself? and it has everything necessary for that i hope. thanks guys |
#20 |
Member#: 89599
RMIC
![]() Talking to Legacy777, we are thinking my setup isn't going to work. I get the last hoses I need today so I might try to startit first to see whats up, but I may have to rewire the car
![]() Any way the Intake manifold is different between the two cars. THe runners or legs from the 1.8, as well as the throttle body are noticibly smaller!!!! However that setup might work better than mine since all of the sensors match. I will try really hard to see if my car will actually start tonight. |
#21 | |
Member#: 832
RMIC
![]() Quote:
#22 |
Member#: 832
RMIC
![]() Natoe,
You need some sort of downpipe, which is not to be found on your Ej18. I've got a Legacy Turbo one in my garage. $25+ freight and it is yours. Then you will need to get a mid-pipe cut to mate up in the right position... If you use your Ej18 manifold, all your sensors and accessories will wire right up with no splicing at all. The only thing you will need to mess with is putting in the little mini fuel rail with injectors from the Ej22t. Last edited by Matt Monson; 07-07-2005 at 01:51 PM. |
#23 |
Member#: 832
RMIC
![]() Nope, no sensors in the headers. I've got a set of those as well. Add another $35 to the deal for them, plus freight. Sorry, no crossmember. Legacy777 got my last one, and it ships today...
#24 |
Member#: 82273
Vehicle:97 impreza L now with wrx brake love!! |
![]() wish I could find a 2.2t...wish I had the green for a 2.2t
#25 | |
Member#: 90353
![]() Quote:
v3 STi swap, 95 impreza coupe - Here goes nothing | elislider | Subaru Conversions | 202 | 01-05-2011 07:41 PM |
FS: Ver. 5 STi swap and 95 impreza coupe | pinter | NWIC Private Classifieds | 7 | 08-28-2007 01:07 AM |
95 impreza coupe!!! MINT 04 WRX SWAP | STi in ur face | Private Vehicle 'For Sale' Classifieds | 45 | 08-13-2007 01:35 AM |
WTT: 95 Impreza Coupe for 95 Impreza Sedan | bigboss | MWSOC Private Classifieds | 9 | 02-18-2007 04:40 AM |
FS: 95 Impreza Coupe swapped w/ Ver.2/3 | AWDsub | NWIC Private Classifieds | 12 | 12-06-2006 10:53 PM |
