Welcome to the North American Subaru Impreza Owners Club Saturday July 12, 2025
Old 10-20-2007, 10:17 PM   #76
0r161nal_r
Member#: 137268
2007 Impreza 2.5i
Newport Blue Pearl
I recently bought and installed the interconnecting cable from Tim-M to connect the astray AUX to the '07 Subaru Clarion changer and it worked perfectly!!!
0r161nal_r is offline   Reply With Quote
Old 10-20-2007, 10:31 PM   #77
aksti
Member#: 134303
2006 STI
Me too. Very pleased!
aksti is offline   Reply With Quote
Old 10-20-2007, 10:32 PM   #78
Misterkt
Member#: 154837
2006 WRX Sport Wagon
Crystal Gray Metallic
How did you connect the cable to the ashtray aux? Did you have to cut the connector off the harness on the ashtray auxiliary box and solder the cable you bought? -or was it plug and play??
Misterkt is offline   Reply With Quote
Old 10-21-2007, 01:42 PM   #79
Tim-M
Member#: 159890
Misterkt,
It is almost plug and play on the ashtray end.. the cable has individual insulated female pins that you just match the colors up to the 5 pins on the ashtray connector.
Cheers,
Tim
Tim-M is offline   Reply With Quote
Old 10-21-2007, 02:16 PM   #80
AaronBBrown
Member#: 12004
2006 WRX Ltd Wagon
Anyone know if the 2006 OEM changer from a WRX is plug and play with a 1997 Legacy?
AaronBBrown is offline   Reply With Quote
Old 10-22-2007, 07:44 PM   #81
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by Tim-M View Post
There is no need for an external ground wire, the upper left pin in the 8 pin connector that supplies this.
Tim- glad to hear your connector works. Many people have been looking for that.
Subaru's aux box makes a point of grounding the "aux enable" input to chassis ground and not to the aux audio ground, so I think it would be a good idea to do the same.
Yes, using the audio ground works, but that may introduce unwanted noise.
Yes. While the 1993 and 1994 USDM Legacies continued using the previous years' (different) radio connector, the 1995 and up Legacy radios use the same connector as all other "modern" Subarus do now. [EDIT: corrected years]
See this thread for pictures and more info:
Stock head unit information -- pin-outs, subwoofer, aux inputs, and more
SVXdc is offline   Reply With Quote
Old 10-22-2007, 11:23 PM   #82
Tim-M
Member#: 159890
SVXdc,
I'm not using the audio ground (it's electronically ground loop isolated, so it won't provide enough ground anyway ). Pin 4 is a chassis ground (labeled as "No Connect?" in your link), it is the same pin Subaru uses for the OEM AUX cable . If you look closely at the picture of the harness that connects to the radio, you will see there are 5 wires in use, not 4..
Cheers,
Tim
Old 10-26-2007, 05:02 PM   #83
Dynamite59487
Member#: 155455
2007 Impreza 2.5i
I need this wire the guy I bought it from forgot to provide it for me.
Dynamite59487 is offline   Reply With Quote
Old 11-09-2007, 04:27 PM   #84
Misterkt
Member#: 154837
Default Auxiliary Cable Pics
I purchased the auxiliary cable from Tim-M and this is what I got (Cable and Plug Diagram):
This cable works great and the installation was simple. Here is a pic of the auxiliary box harness and the cable I purchased:
I modified the back of the panel that houses the auxiliary box so that the cable coming from the box could pass through easier, I did this by drilling a hole and cutting out a slot:
Old 11-14-2007, 08:57 AM   #85
babs07fxtltd
Member#: 144864
This kit looks great..
Tim you're kit is getting some press (by me) over at the Forester forum:
http://www.subaruforester.org/vbulle...d=1#post281036
I want to make sure I'm telling those guys correctly that they can get your kit to fit an existing plug at the ashtray (like above) or completely from head-unit out to the stereo-mini-jack they could mount anywhere.. correct?
... Sorry I reread the PM you sent me about the two styles. Answered my question.
babs07fxtltd is offline   Reply With Quote
Old 11-24-2007, 10:54 AM   #86
Tim-M
Member#: 159890
Just a quick update..
I've found out that the Forester stereo AUX connector is not the same as the Impreza
The Impreza AUX connector supplies ground from pin 4 to pin 6 in order to activate the AUX button (this is the wiring configuration Subaru uses for the ash tray AUX adaptor).
On the Forester radio, pin 6 still needs to be grounded, but pin 4 does not supply it, so Forester stereo's will need an external ground (as originally posted by SVXdc).
Pin 7 is the ground for the steering wheel remote audio control switch, but I'm not sure if it is a safe ground to use for the Forester, so I'll be using an external ground for all of my future AUX cables.
The ground can be attached to the screw that is right beside the AUX plug on the back of the radio.
Many thanks to JP in Ottawa for helping me sort this out
Cheers,
Tim
Old 12-01-2007, 02:11 PM   #87
[email protected]
Member#: 111556
2006 STI
anyone have a 07 headunit FS?
xerox445@yahoo.com is offline   Reply With Quote
Old 12-17-2007, 01:29 PM   #88
cmatter
Member#: 138603
Default what is stock oem output watts per channel?
I searched and searched and could not find what is the output power to each of the four door speakers in the 07 STi Limited with 6-disk in-dash changer?
cmatter is offline   Reply With Quote
Old 12-17-2007, 02:44 PM   #89
seattle944t
Member#: 18308
2005 WRX STi
Subaru says its a 120 watt deck (30x4) that is peak output. Realistic RMS is probably half that, so 15 per channel at best.
seattle944t is offline   Reply With Quote
Old 12-18-2007, 07:51 AM   #90
cmatter
Member#: 138603
Default will 240W in-dash changer work in STi Limited?
I had heard of both a 120W and 240W in-dash changer, so I guess the 240W is in some other Subaru model? Would I be able to install the 240W version in my 07 STi Limited without major mods? I also have the under-seat subwoofer.
Old 01-02-2008, 11:43 AM   #91
babs07fxtltd
Member#: 144864
http://www.subaruforester.org/vbulle...t=16720&page=2
Hadn't been in here for a while.. to answer your question.. yep.. 07 FXT oem for sale I guess.. just haven't been too agressive about it as I don't have the budget allocated to pour into the audio system I want to yet.. This is the one that also powers the forester oem 6x9" sub in back. Works great, sounds great.. should on paper work fine with Tim's cable kit.
Old 01-02-2008, 03:16 PM   #92
Paulius
Member#: 141803
2002 Impreza WRX STi
Question
Cheers,
Tim
Could you be so kind, to tell us part number of AUX cable of 07 impreza?
Paulius is offline   Reply With Quote
Old 01-06-2008, 10:29 AM   #93
gregnauman
Member#: 97453
2013 STI Hatch
Satin White Pearl
Tim
I have a 2005 LGT that I put the 2007 Spec B/Legacy GT radio in.
Do you know if the the "legacy" Aux in is the same as the impreza.
I see you posted that the Forrester is a bit different. Is there anyway for you to check the legacy aux in wiring?
Thanks in advance
gregnauman is offline   Reply With Quote
Old 01-06-2008, 10:45 AM   #94
gregnauman
Member#: 97453
2013 STI Hatch
Satin White Pearl
Originally Posted by atech_rallyrs View Post
For what its worth, the aux box does not fit properly in the tray of an 2005 wagon dash. It fits, and fits perfectly, but does not have the extra plastic on the top of the ashtray section which the aux unit plugs into. I havent figured a good way yet to make it "stay put" without glue or the like.
I think the legacy wagons and sedans aux in are in the console storage bin right by power plug. I wonder if this would work for the impreza somehow.
Old 01-23-2008, 11:24 PM   #95
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
07 STI 6-Speed Goodness!
I've got an 04 WRX with the upgraded sound system and underseat subwoofer. I just picked up an 07 STI HU with the aux connector. Anyone know the part# for the t harness that will let me connect my subwoofer back up as well as the aux adapter?
ScoobyNubieToo! is offline   Reply With Quote
Old 01-26-2008, 03:35 PM   #96
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Do you still have the original subwoofer T-harness from your 2004? That should work just fine with the new radio.
Or does your T-harness have the extra 8-pin plug (at the HU end)? There's an easy mod to bypass that plug so your harness uses only the 14-pin connectors — Take a look at this thread:
in the section on subwoofers, see the link to the thread "stock sub w/ aftermarket hu."
Old 01-26-2008, 07:28 PM   #97
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
Sweet! Thanks! As far as the original sub woofer t-harness, whatever SOA put in there should still be in thee as I have done no mods to the original radion since I bought the car (other than adding an amplified 10" Bazooka tube)
Old 03-06-2008, 10:58 PM   #98
DiuSee
Member#: 151616
2007 Impreza
Obsiden Black Pearl
I took my 07 radio out, and put in an AVIC-D3, and since I dont need the aux port anymore, I want to put an ashtray in it and perhaps have more storage space. Anyone have clear instructions on how to get the actual aux port out of the bezel.
DiuSee is offline   Reply With Quote
Old 03-10-2008, 06:07 AM   #99
hater06
Member#: 139699
2011 WRX STi Limited
omgbump i was just about to ask the same thing!
hater06 is offline   Reply With Quote
Old 10-25-2008, 07:22 PM   #100
JOHN16V
Member#: 21491
2000 Subaru Impreza
2.5RS BRP Sedan
Anybody know why when I plug a 07 OEM CD player in (00's RS) it flash "System Check"? Is this normal? Also when I hit the load button it flash "push eject"? Then nothing happen and it automatically switch back to radio?
Is all the plug from 00-07 the same? Just checking.
JOHN16V is offline   Reply With Quote
WTB: 2007 WRX OEM cd-changer pj_cab NWIC Private Classifieds 1 03-14-2013 08:14 PM
FS: OEM CD Changer from 04 WRX Leprakkon Interior/Dressup/Audio & Security 0 09-02-2009 01:09 PM
WTB 2007 OEM CD Changer jaWn Private 'Wanted' Classifieds 0 11-25-2007 05:02 PM
FS: 6 Disc CD/MP3 Changer from 2007 Impreza 2.5i, with AUX Input Jack tarp Interior/Dressup/Audio & Security 3 08-27-2007 03:58 PM
FS: OEM 6 CD changer from 04 Forester XT SzGuy Private 'For Sale' Classifieds 0 10-23-2005 10:05 PM
