Welcome to the North American Subaru Impreza Owners Club Sunday July 15, 2018
Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Private Classifieds
Old 09-05-2017, 03:42 PM   #1
BlobeyeSTi
Member Sales Rating: (35)
Member#: 187877
OMGHi2U WV: 1999 & 2000 RS Coupe Part Out
Parts list & pictures updated: 7/13/18
Parts are from 1999 and 2000 RS coupe both 5 speeds.
Located in Fairmont WV & shipping isn't a problem just message me for a quote. If you want pictures of a certain part just ask.
Thanks,
Tony
*Links to albums of individual pictures of each part are located beside each group*
GC Parts
Engine & Drivetrain Pics: https://imgur.com/a/F23PkWq
• Main pulley $15
• Intake manifold $50
• Engine harness $50
• Rear subframe $40
• Front subrframe $80
• Rear differential carrier 'T' subframe $50
• Rear differential $75
• Transmission subframe $25
• RWD converted 5 speed transmission $400
• Transmission mount $20
• Purge valve solenoid $15
• Air assist injector #16632AA001 $15
• Gas cap $10
• Fuel pump assembly with pump # $20 (1 piece broken)
• Fuel lines $50
• Injectors $40 set
• DW200 $50
• Clutch master $30 (2 available)
• Slave cylinder $30
• Steering rack $75
• Throttle cable $10 (2 available)
• Alternator $40 (2 available)
• Power steering pump $70
• Power steering reservoir $15
• Power steering reservoir bracket $5
• Ignition coil $20
• Coil packs $40 set
• Throttle body $20
• Oil fill neck and cap $15
• Cam gears $10
• Axle with one busted joint $25
• Intake silencer $10
• Coolant overflow tank $10
Suspension & Brakes Pics: https://imgur.com/a/vaSJf0R
• Struts & springs $200
• Sway bars $40 each
• Lateral links $20 each
• Trailing arms $40 set
• Endlinks $20 set
• Control arms $25 each
• Brake booster and master $40
• WRX rear calipers $50
• ABS module $40
• Front ABS sensors $15
• Front brake caliper mount $5
Exterior Pics: https://imgur.com/a/l3wK1sO
• Depo glass driver side headlight $100
• Hood hinges $20 set
• Scoo $75
• Hood vents $40
• Vent tray $15
• Doors $100
• Rear bumper $100 (2 available)
• Rear bumper beam $50
• Front bumper beam $75
• Black trunk with small wing (no dents needs repainted) $50
• Blue trunk with small wing (has few dents) $50
• Passenger fender (dent behind headlight) $25
• Inner fenders $10
• Door windows $40 each
• Hood release cable $10 (2 available)
• Roof trim $40 each
• Wiper cowl $40
• Wiper motor & linkage $40 (2 available)
• Sunroof $100
• Taillights $80
• Taillight trim $25 set (2 available)
• Quarter panel trim $10 each
• Blue gas lid $15
• Hood prop $5
Interior Pics: https://imgur.com/a/zlSelwm
• Rear Dash $40
• Radio & HVAC trim $25
• Steering Wheel $20
• Driver airbag $40
• Dash bar $50 (2 available)
• Trunk side panels $15 each
• Rear seats $50
• Hood release handle $5 (2 available)
• ECU cover $10
• Ebrake handle $20
• Door kick panels $10 each
• Wire covers for inside door kick panel $10 side
• Fuel pump cover $5
• Gas pedal $20
• Blower motor $50
• Dash cup holder $10
• Rear view mirror $20
• Interior lights $10 each
• Seatbelts $40 (no driver front but have the rest)
• Steering column $50
• Speaker brackets $5 set (2 available)
• Weatherstripping $5
• Tweeter cover $10 each
• Door handle trim and pocket $10 set
• Visor clips $5 set
• Jack $10
• Shift knob $10
• Door panel bolt covers $5 set
• Door panel brackets $10 each
• Door mirror cover $5
• Gauge cluster trim $10
• Seat bolt covers $10 set of 4
• Rear speaker covers $10 set
• Passenger A pillar $15
• Rear heat vents $20 set (2 available)
Electronics Pics: https://imgur.com/a/3779vWz
• Knock sensor $10 (2 available)
• Sunroof harness $10 (2 available)
• Cruise control unit #87022FA110 $20
• Interior fuse box $20
• Ignition with key $40
• Engine bay fuse box $20
• Door ajar sensor $10
• Fog light switch $10
• Horn and cruise control steering wheel switch $20
• Cruise control dash switch $10
• Hazard switch $10
• Antenna with screws $25
• Headlight switch $20
• Wiper switch $20
• Airbag sensors $10 each
• Airbag harness $25
• Airbag control unit $25
• Main harness $50 (cut by driver headlight)
• Alternator to battery cable $10 (2 available)
BlobeyeSTi is offline   Reply With Quote
Old 09-05-2017, 03:43 PM   #2
BlobeyeSTi
Member#: 187877
Old 09-05-2017, 03:43 PM   #3
BlobeyeSTi
Member#: 187877
bump.
Old 09-07-2017, 03:48 PM   #4
BlobeyeSTi
Member#: 187877
bump.
Old 09-08-2017, 05:12 PM   #5
Gc8Nice
Member Sales Rating: (28)
Member#: 298068
2003 WRX Wagon
U got an rs front bumper and crash bar
Gc8Nice is offline   Reply With Quote
Old 09-08-2017, 10:27 PM   #6
BlobeyeSTi
Member#: 187877
none for sale sorry
Old 09-08-2017, 10:41 PM   #7
MD04WRX
Member Sales Rating: (131)
Member#: 72891
2018 Type RA -
99 2.5RS 2dr - 2017 XV
Looking for the following. 99 front axle, defroster switch, left roof molding, and trunk floor carpet. Maybe a few other things.
MD04WRX is offline   Reply With Quote
Old 09-08-2017, 10:44 PM   #8
MD04WRX
Member#: 72891
2018 Type RA -
And the rear spats
Old 09-08-2017, 10:51 PM   #9
BlobeyeSTi
Member#: 187877
And the rear spats
I got all that except for the trunk carpet. Picked up or shipped?
Old 09-08-2017, 10:57 PM   #10
MD04WRX
Member#: 72891
2018 Type RA -
Pm sent
Old 09-13-2017, 05:08 PM   #11
BlobeyeSTi
Member#: 187877
Bump...
Old 09-16-2017, 07:31 PM   #12
BlobeyeSTi
Member#: 187877
Bump!
Old 09-18-2017, 05:19 PM   #13
BlobeyeSTi
Member#: 187877
Bump!
Old 09-22-2017, 07:07 PM   #14
BlobeyeSTi
Member#: 187877
bump...
Old 09-26-2017, 11:16 AM   #15
BlobeyeSTi
Member#: 187877
Bump!
Old 09-29-2017, 03:09 PM   #16
BlobeyeSTi
Member#: 187877
bump!
Old 10-05-2017, 01:11 PM   #17
BlobeyeSTi
Member#: 187877
OP updated and decided I'm going to part out the rest of the blue RS.
Old 10-08-2017, 05:13 PM   #18
BlobeyeSTi
Member#: 187877
bump!
Old 10-13-2017, 11:07 AM   #19
BlobeyeSTi
Member#: 187877
bump!
Old 10-17-2017, 01:21 PM   #20
BlobeyeSTi
Member#: 187877
OP updated
Old 10-20-2017, 02:13 PM   #21
BlobeyeSTi
Member#: 187877
bump!
Old 10-23-2017, 05:45 PM   #22
BlobeyeSTi
Member#: 187877
Bump...
Old 10-25-2017, 05:07 PM   #23
Subimon
Member Sales Rating: (4)
Member#: 396565
1999 2.5 RS
Posting for feedback on Cabin filter cover form 2000 RS, Thanks Tony you da man!
Subimon is offline   Reply With Quote
Old 10-26-2017, 09:35 AM   #24
AJ711
Member Sales Rating: (11)
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Silver 5 spoke rims available?
AJ711 is offline   Reply With Quote
Old 10-27-2017, 04:45 PM   #25
BlobeyeSTi
Member#: 187877
Thanks man!
Ya PM sent
